Results 1 to 13 of 13
    Feb 15 2018
    2009 Audi A6 3.0t Tune
    Hello,
    What is the most powerful and reliable tune to go with?
    I think I have pretty much every tuner, APR and GIAC in my local area.
    I have the 2009 A6 3.0T if that makes a difference.
    Also are there any transmission tunes that make the transmission more reliable?
    Thanks
    Jul 17 2011
    Sin City, USA
    Hi Nick. APR vs. GIAC is like Ford vs. Chevy. You will have fans on both sides that think their favorite is better.
    You can’t go wrong with either one to be honest. It boils down to what you want.
    As for power, both are pretty on par with each other for a box tune. In the past, they would leap frog each other as they continued to develop their tunes but they have done pretty much all the tweaking they are going to do for our platform.
    For me, the advantage is GIAC because they offer a switchable tune package; stock, pump and race. Whereas APR does not offer switching on the C6A6 tune.
    '09 C6.5 A6
    Senior Member Two Rings juniorcruzer's Avatar
    Sep 28 2014
    2007 Suburban
    Center City Minnesota
    Sin pretty much covered the differences. Also to note, there is no tranny tune for our platform unfortunately. With that said, the tranny in this car is a solid tranny, and not sure I have heard of anyone having an issue with the tranny yet.
    Jon
    2010 S4 3.0T, chipwerks stage I
    2010 A6 3.0T, APR Stage 2+, Roc Euro Intake, VMR V710 18x9.5 HyperSilver, 30% tint, A3 clear marker lights, LED Reverse lights, RS6 Grill
    Aug 24 2014
    Newport Beach, CA
    Do either of those tunes delete the EVAP related stuff in the car?
    2024 M3 Comp xDrive
    Senior Member Three Rings s4chiro's Avatar
    Dec 30 2011
    2011 VW TIGUAN
    chicago
    Quote Originally Posted by juniorcruzer View Post
    Jon
    the trannys are weak as fck...i have the APR 93 oct tune since 65k miles (now at 89k) and Ill get the delayed reaction clunk from the tranny in first gear rolling thru stop signs....
    2000 Imola B5 S4 /MeowIsFat TUNE/ SSAC 3"/ NEUSPEED EXHAUST/ NEUSPEED S/S/ H&R SPORT/ VMR 708s--SOLD :(
    2009 C6 A6 PRESTIGE/ APR STG 2 TUNE 93:100oct/ APR PULLEY/ 3" Custom Magnaflow/ USP CAI/ 19" Peelers
    Aug 24 2014
    Newport Beach, CA
    I have that clunk too but it's very subtle and got much better after replacing the trans filter and fluid, and this car has been stock its whole life. So likely not just a transmission longevity issue based on the car being tuned or not.
    2024 M3 Comp xDrive
    Feb 15 2018
    Does anyone know how the 2009 audi a6 3.0t engine compares with the new 3.0t engines?
    Will power results be the same with a tune across all of the 3.0t?
    Feb 15 2018
    Are there any differences between the 3.0t engines?
    Veteran Member Four Rings ichi d's Avatar
    May 10 2013
    Toronto,ON
    Quote Originally Posted by s4chiro View Post
    im stage 2 and i have no clunk maybe check your snub mount. and maybe u need the dealership to update your tcu. been tuned since 100km now at 240km
    C7 S6 / AWE Touring / -14mm / EuroTails /
    Sep 28 2014
    2007 Suburban
    I have nearly 170 thousand on my car, and 60 thousand of that tuned. Don't baby the thing at all, and tranny is still running strong.
    Feb 15 2018
    Makes me feel better about the transmission... That was my primary concern regarding the tune upgrade.
    I do notice some jerkiness from stand still for slow acceleration unless I go really slow.
    I just thought that it was normal with this car, I don't mind it.
    As long as something doesn't actually break..
    Does any one know if there is any horsepower difference between the 2009 3.0t and the new 3.0ts?
    Veteran Member Three Rings B. Rock's Avatar
    Jul 27 2008
    09 3.0T A6 Avant
    A quick look at the factory hp ratings from audi tells me there are likely differences, you'd have to do your own research to figure out what they are. I'm sure there's an article somewhere. The C6 tune #s are not what the B8 or newer tunes show, that's for sure.
    I am not overly worried about exact HP levels - these fall into the 'fast couch' category. Not race cars, but fun dailys. Tune it, enjoy it, don't think about it too much.
    Also....'solid tranny' sounds like a good band name.
    09 A6 Avant 3.0t
    06 E350 4x4 Cummins swapped
    01 WJ rock toy
    May 10 2013
    Toronto,ON
    if you aint tuned yet u better get tuned. skip stage 1 and go straight for stage 2, you will thank me later.
