Page 2 of 4 FirstFirst 1234 LastLast
Results 41 to 80 of 152
Thread: S4 Mod Thread
  1. #41
    Apr 11 2012
    Quote Originally Posted by CreoSTi View Post
    I removed the black plastic rivet (top left) and was able to pull the bumper skin away from the car a bit to give me a little more room to remove/install the reflectors.
    Oh, nice! That inside bumper ridge was flexible so I just bent it to get tools in there, probably not the best way, but it worked!
  2. #42
    Veteran Member Four Rings CreoSTi's Avatar
    Feb 22 2004
    2016 Acura RDX
    West L.A.
    Quote Originally Posted by Yabi View Post
    The darker tones is my hesitation with the Tag reflectors. Did you have to take off the wheels to get to it? Iíve noticed most people have removed the bumper to install however Tag mentioned that while it would make install easier it wouldnít be necessary.
    Nope, I just turned the wheels to the sides.
    - - - Updated - - -
    Quote Originally Posted by will13k7 View Post
    Well, you can remove it that way when it's time to put the car back to stock...
    -Mike- : 2001 S4 → 2011 S4 → 2014 S6 → 2018 S4
    LendUS, LLC
  3. #43
    Jun 20 2011
    2012 and 2002 Audi S4
    Plano, TX
    I really like the mirrors and spoiler. This has me seriously considering them. I was on the fence for painted reflectors, but Iím thinking I may stick with the tinted overlays on mine for now (they are ok on my Daytona Gray).
    2018 S4 : Daytona Gray : Black Nappa : Carbon Atlas : S Sport : Black Optics
    Gone - 2012 S4 : Ibis White : Black Nappa : S-tronic : Sports Diff : MMI Nav : B&O : APR Stage II+ : AWE Exhaust : Alpha Coolant System : ECS Intake : AP Racing RadiCal BBK : H&R OE Springs/Bilstein Shocks : Hotchkis Sway Bars : BC Forged HB04 Wheels
    2002 S4 : Black : Black Leather : 6-Speed : Stage 2+ : Slowly Dying in My Driveway....
  4. #44
    Apr 11 2012
    S4 Mod Thread
    tinted reflectors for darker colored cars looks good imo too!
    Spacers on! Massive front calipers.
    Needs low even more now
  5. #45
    Senior Member Three Rings TurboQuattroPwr's Avatar
    Sep 28 2006
    Delaware
    Looks great. What size spacers?
    2018 Audi S4 3.0T
    18% Tint, CquartzPro Ceramic Coating
    2002 Audi A4 1.8TQM *Gone*
  6. #46
    Jun 13 2017
    Winnipeg/Manitoba/Canada
    bare bottom when taking off the spoiler yesterday:
    Did you chip or crack the old spoiler in the removal process....just asking because I had my dealer install the carbon fiber spoiler and asked for the old one back. I noticed there was a couple of chips out of it. Just want to know if it's normal for this or should I be complaining?
    Sent from my SM-G965W using Audizine mobile app
  7. #47
    Apr 11 2012
    Quote Originally Posted by danaeroS4 View Post
    the car and original spoiler have no damage, sounds like your installer used too much heat and/or tried to yank it off. I used just enough heat to warm the spoiler and dental floss to saw end-to-end, even through the middle section of the spoiler which has an extra strip of adhesive. I went through a lot of dental floss, but it only took about 30 minutes.
  8. #48
    Apr 11 2012
    Quote Originally Posted by TurboQuattroPwr View Post
    Thanks! Thatís 10mm all around.
  9. #49
    Jun 13 2017
    the car and original spoiler have no damage, sounds like your installer used too much heat and/or tried to yank it off. I used just enough heat to warm the spoiler and dental floss to saw end-to-end, even through the middle section of the spoiler with has an extra strip of adhesive. I went through a lot of dental floss, but it only took about 30 minutes.
    Thanks for reply I figured they should of removed old spoiler without damaging it. I asked for my old spoiler back before they started the job... so not like I didnt give them warning.
    I will seeking compensation for the damaged spoiler which is useless to me with the 2 chips in it.
  10. #50
    Jun 13 2017
    Yep
    Roughly how long did it take you to remove mirror caps? Any special tools?
    My dealer wants $330 to remove and install carbon fiber ones.
    I am mechanically inclined and can do DIY stuff.
    Just worried about breaking mirror or housing.
  11. #51
    Apr 11 2012
    I used a T10 and pry tool. Took about a hour or so. I took my time and was patient, messing with it until it came apart, not forcing anything.
    (I didn't remove the center mirror mount like this video shows.)
  12. #52
    Jun 13 2017
    Great thanks for reply I didnt think it would take that long, I watched videos and picture instructions and didnt seem super hard. I bet it wouldn't take them more than an hour either.
    I'll prob buy the mirror caps from them then save the 330 and install myself.
  13. #53
    Established Member Two Rings GTburn's Avatar
    Jul 09 2017
    18' Ford Explorer (wifes)
    ft Lauderdale
    It really is really very easy. All you have to do Pop the mirror off, unplug 3 wires, remove 4 screws and pop off the cover. Disconnect Blind Spot Light and pop it out of the housing then put it all back together. It took me 10 min per mirror.
    AKA: gt5tang
  14. #54
    Apr 11 2012
    springs, sways, and endlinks will be on early next week. excited for the altitude adjustment!
    I also found the good stuff ("pro"-only ceramic coating), it didn't look any harder to install versus the consumer grade stuff, so I'm going to put this on in a few weeks. getting brave!
  15. #55
    Apr 11 2012
    Before the drop, cooling down.
  16. #56
    Apr 11 2012
    Needs a little fine tuning, all the way down all around right now, needs to settle, but bringing up the front to match the rear more tomorrow.
  17. #57
    Apr 11 2012
    Active Member One Ring CMA337's Avatar
    Apr 04 2018
    MA
    Looks great. What springs did you go with?
    2018 S4 Glacier white, ED springs, EMD carbon splitter, ECS rear carbon spoiler, RS4 grille.
  19. #59
    Apr 11 2012
    Quote Originally Posted by CMA337 View Post
    those are H&R VTF adjustable lowering springs. they are breaking in fast, it is already lower from the drive home, lol.
  20. #60
    Apr 11 2012
    how she sits right now
  21. #61
    Sep 28 2010
    '18 S4, '16 SQ5
    Boone, NC
    The drop looks awesome!!
    Mops On The Move
  22. #62
    Apr 11 2012
    ^^Thanks mops! 034 nailed it!
    I love the look, Iíll see how well it works out, I might need to come up 10-20mm all around worst case. I havenít rubbed or scraped yet though.
    Negative camber ftw! Would rub like crazy without it. Can barely get a finger in between the tire and fender.
    Ride isnít as good as coilovers, but not bad. The firmness is there, itís smooth most of the time, but big bumps will upset it, and the dampers will clamp down. They feel reactive! Probably better if raised some, but good enough for my daily driver, and I like it low. Might smooth out more after it breaks in more.
  23. #63
    Sep 28 2010
    '18 S4, '16 SQ5
    Boone, NC
    I'd prefer the overall look if it were up 8-10mm, but I think I'm getting old. Turned 37 this past Sunday 😂 My A5 was at least that low, and I LOVED the look.
    And yea, after I dropped mine the last time, the ride declined a bit. But I'm right there at the balance... low enough, fully usable, and the ride is still nice. The front bumper cover will work in your favor.... I'm betting you can drive it at that height with little hassle.
  24. #64
    Jan 08 2018
    18 S4, 18 Q5
    Minneapolis, MN
    I love the look too! Seeing the way your car looks makes me wish I'd done a similar setup over the 034 springs. Don't get me wrong, my drop is great with an even front rear gap that probably fits my age better, but I love that slightly tucked tire look.
  25. #65
    Jan 08 2018
    18 S4, 18 Q5
    Minneapolis, MN
    Happy birthday!!!
  26. #66
    Apr 11 2012
    not acting my age
    this car doesn't lean in the corners anymore, stays super flat around freeway loop ramps, and I don't notice the "track" spec swaybars degrading NVH any.
  27. #67
    Feb 22 2004
    2016 Acura RDX
    West L.A.
    Looks great!
    I was rubbing on the rear fender liners/black plastic piece with the BBS LMs (ET38 with 255/30/20 Michelins) + 15mm spacers and -1.5 degrees of camber all around. I went down to 10mm and it's perfect now.
    I'm going to throw the 15mm spacers on the OEM Black Optic wheels, which should fit well.
    LendUS, LLC
  28. #68
    Established Member Two Rings DirtyDog--IRL's Avatar
    Mar 31 2015
    Columbus, Ohio
    S4 Mod Thread
    I removed the black plastic rivet (top left) and was able to pull the bumper skin away from the car a bit to give me a little more room to remove/install the reflectors. But like I said, next time I'm just going to a vinyl decal shop and seeing if they have a close enough match to the car...
    Still having trouble even after removing this rivet - itís a true pita! Any other advice ? Iím nervous of breaking or scratching something
    Btw love the car, looks so good with the mods !!
  29. #69
    Feb 22 2004
    2016 Acura RDX
    West L.A.
    Quote Originally Posted by DirtyDog--IRL View Post
    I was too, until 10 minutes in and my garage was about 90 degrees... If you cannot get the reflector out from the inside, once a corner or two were loose, I put a nylon trim tool in a couple of spots (from the outside of the bumper skin) to help break the bond of the tape. You can potentially scratch your bumper doing this, but I put some masking tape on the outside of the bumper cover and there was no damage that I saw once I was finished. These were a huge PITA to remove compared to the ones on my F80 M3.
    LendUS, LLC
  30. #70
    Mar 31 2015
    Columbus, Ohio
    Thanks Iíll give it another go this weekend.
  31. #71
    Apr 11 2012
    The reflectors cracked from the amount of pressure I was putting on them.
  32. #72
    Senior Member Two Rings NC_Detail_Garage's Avatar
    Jun 27 2015
    B9 S4
    Charlotte, NC
    lol that oem glue is no joke. i think i spent 30 mins per side just scraping the glue away
  33. #73
    Mar 31 2015
    Columbus, Ohio
    I saw that in your pic but didnít want to call you out haha
    I donít care about cracking that Iím more worried about the bumper, I tend to start out fine then 3 minutes in Iíll just want it over with and force it till I hear something snap...then spend the next 5 minutes saying ďno no...Ē :)
  34. #74
    Mar 31 2015
    Columbus, Ohio
    Finally got them in this weekend in 90deg heat - the rivet was the key to anyone trying to do this.
    Certain light the colour isnít 100% match but itís close enough - youíll never get factory match
    Thanks for all the helpful comments !
  35. #75
    Apr 11 2012
    I've been an ECS customer long enough that I caught on to their procedures, if you order something from them they don't have a picture of, when they get it in, they take a bunch of pictures to post on their website, then ship it to you the next day, so these should be pictures of my actual exhuast which just shipped today and should be here friday. Can't wait!
    This is the resonated version which comes with an extra silencer when compared to the non-resonated.
    I'm hoping to get between stock and non-resonated sound. My S3 is a bit obnoxiously loud during cold start and WOT (turbo-back exhuast), so I'm going for something more tame on the S4, but if it's too quiet, converting it to non-resonated is my backup plan.
  36. #76
    Apr 11 2012
    exhuast arrived! install is set for wednesday. tips go with the wheel color somewhat.
    Also put two coats of nanolex Si3D on. Super glossy now. I'll have to take some proper pics once the exhuast is on.
  37. #77
    Sep 28 2010
    '18 S4, '16 SQ5
    Boone, NC
    Love that finish on the tips! I wonder if coating them as well would assist in keeping them clean and free of staining? Many coat calipers, and they can exceed 300F while tips stay below 200F IIRC.
  38. #78
    Apr 11 2012
    oh yeah, forgot about this! I've seen youtube videos of people coating exhuast tips, thanks for reminding me! going to do this today. haha.
  39. #79
    Sep 28 2010
    '18 S4, '16 SQ5
    Boone, NC
    S4 Mod Thread
    Certainly canít hurt! Might should do it a few times per year but we like that detail oriented weirdo type piddling.
    Mops On The Move
  40. #80
    Apr 11 2012
    had exactly enough Si3D left to put one layer inside/out on each tip.
