Hi there,
Longtime member and lurker... I have a weird problem. I had no heat in my 1.8T avant, after it was warm, checked the core hoses and the return wasn't very warm, the other very hot. So I thought, damn, heater core is plugged, etc. Proceeded to flush the heater core with CLR soaked in it for 1.5 hrs, then flushed/backflushed with hose until clear and clean. There was a fair amount of white dandruff looking flakes big and small that came out. Buttoned everything back up, am familiar with the proper bleed procedure (gravity feed coolant, wait for it to come out of bleeder on coolant pipe, then wait for it to get to the upper heater core hose. Let it get up to temp, drove it around, and proceeded to bleed from the screw, got a lot of air from there while never letting the coolant or air get back in, crack/close/pressure build up/repeat until mostly coolant) then I drove it around, came back and "burped" the upper core hose, then button up). I had the heat on hi once it was to temp.
The result was on the HI setting it was pretty damn hot when driving and didn't change much at all when at idle, so this was a great sign. THE KICKER, when I switch it to "84" which is one less on the temp spectrum, I hear the flapper mechanism make noise and then the air turns to room temp/barely warm if at all, and doesn't change much based on engine revs/acceleration etc.
So what could this be? Could it still be the heater core if it's doing great on high, and works like a champ, very hot. I'm thinking it could be something to do with the air flow adjustment in the dash? Or my control unit? It's just so weird I have really really good heat on HI at idle or driving and then nothing on the next setting down at idle or driving. Anyone run into this before? Thanks for the reading and the long post, this is driving me nuts haha!
