trying to nail down the issue here, and have some ideas - care to provide some suggestions?
initial issue: radiator fans do not come on unless i turn AC on
bonus issue that just appeared: cluster temp gauge drops to 0 or fluctuates between 1/2 and 1/4.
diag info:
- fans work, as when i put on the AC they both spin, high/low etc
- torque app reading temperatures as high as 235F(!!) and it seems to correspond with the running of the car (is low at start up, then increases)
- slight (half a gallon every 6 months) coolant leak from somewhere, i haven't been able to trace aside from leaky fins near the end-caps which eventually seal
work done so far:
- thermostat replaced 10K miles ago
- replaced both coolant temp sensors, though noticed that the lower one's connector doesn't fully engage, can potentially slip out
- replaced some coolant but not a through air bubble flush procedure
- checked relay 219, no obvious water ingress issues
questions:
- where does the ECU get it's temp reading from? i am guessing that is what torque is reading from
- is this pointing to a faulty FCM or wiring from CTS
- what else can i do to diagnose?
