Results 1 to 2 of 2
    Jun 13 2017
    nowhere
    need some help/advice testing my fuel injectors off of the car already
    I am doing a headgasket job right now and i am in the process of reassembling... but I was having some misfire issues from the dreaded p0089 error code thread i started last year on this forum.
    I am wondering... what is the specifications for resistance for the fuel injectors?
    I did try using my cheapo multimeter on them and the resistance kept bouncing around between 16 and 2 ohms for every injector and it wouldnt settle.
    I have new seals and teflon rings... i didnt really want to buy new injectors until i can prove these are bad.
    thanks
    Veteran Member Four Rings Denio24's Avatar
    Jan 23 2013
    Chicago
    Take them to the shop and have them hook it up to an injector testing rig; they'll ultrasonic them and test them for the spray angle, among other things. You can check the resistance at home with a multimeter in Ohms setting. It should be between 12 & 20 ohms @20 degrees celcius between the two electrical pins. Usually if it goes to a lower value means that you're not getting a consistent reading. Try pressing a little harder on the pins until you get a consistent reading.
    Garage: 2008 Quartz Gray Audi A4Q 6MT
    Tuning: JHM Tuned Stage 2 93 Octane w/ IE HPFP
