Results 1 to 4 of 4
    Veteran Member Four Rings Dasquade's Avatar
    Sep 07 2010
    Belgium
    how to remove intake tube for changing turbo coolant/oil seals
    :( okey so i wanted to renew the seals on my turbos for coolant and oil. Sadely dealer didnt provided the correct coolant inlet seals but will get it sorted. But i was checking how the hell one removes the bolt holding the outlet pipes?! It is burried deep between the intake pipes. I guess removing the rubber connection hose (turbo/throttle body) but then i still can reach the secobd bolt op the intake pipe on the left side (if you stand in front of engine). How the hell designed this stuff :s....
    Veteran Member Four Rings OlyS6's Avatar
    Nov 22 2016
    Olympia, WA
    Quote Originally Posted by Dasquade View Post
    Removing the throttle body will allow you to then access and remove the turbo inlets. Once the turbo inlets are removed, you should be able to access the bottom connections of the coolant and oil inlets.
    The oil separator might make things difficult for you. If you still cant gain enough access, the only way tonremove the oil separator is to take off the front bumper, crashbar, and headlights, which will allow you to move the radiator housing forward a bit, so you can then remove the bolts holding the charge air cooler housing, which has the oil separator attached to it. Congratulations! If you’ve made this far, you can now easily change the turbos as well, since you have perfect access to them.
    2016 S6, mythos black, RS7 turbos, MRC inlets |Akrapovic exhaust| AMS downpipes and intercooler |Eventuri intake| Loba HPFPs |Tial wastegates| Eurocode sways, end-links, and AK | Audi CCB| HRE P103, 20x10 | RS6 grille| Neidfaktor CF mirrors, diffuser, and steering wheel| Blackvue dashcams| Escort Max CI 360 | RS6 LED headlights, OEM Euro tails |Sound: Navtv Zen-v preamp, Helix DSP Ultra, JL HD900/5 driving JL10W3 sub and Hybrid Audio speakers.
    Sep 07 2010
    Belgium
    Quote Originally Posted by OlyS6 View Post
    INDEED!!!! :( phfff will try to find i different way (90degree tool...but affraid even that won't work).
    *tought it was an easy 1 2 3 job (inlet and oil are tough).
    But thanks for the info :).
    Jan 22 2017
    New York
    I haven't brought my S6 in for the (TSB) replacement seals. Are they replacing the bottom ones too? I was under the impression that only the seals at the turbo itself are being replaced.
