Results 1 to 3 of 3
    Apr 26 2018
    7 Second Crank. Turn key off/on. Starts right up.
    Long story short. My fuel pump died. Got a new one put in and it still cranks awhile before starting. Had put in a new filter 8k miles ago. Runs fine once started.. until fuel is less than 1/4 tank. Then I run the risk of stalling. When disconnecting filter, I've never had fuel spray all over the place as some people describe. There is no pressure.
    1) what's the best way/thing to buy to check fuel pressure at rail cheaply.
    2) where is the valve to hold pressure in lines? Pump or filter?
    3) could a vacuum leak cause this?
    4) where else could cause fuel pressure leak? Injectors?
    2004 b6 1.8t Quattro w 170k miles. Going to put in another delphi pump today just to eliminate getting a bad pump. Also have silicone breather hose replacement from 034motorsports and MAF coming. (Unplugging MAF while running has 0 effect). Thanks. This car has been to mechanic twice in 110k miles mostly due to these forums.
    Senior Member Two Rings zach.odell's Avatar
    Feb 07 2017
    2015 A6 TDI Prestige, 2012 VW Touareg Exec, 2011 Chevy Silverado 5.3 LT
    Connecticut, US
    I had a similar issue and it ended up being the coolant temp sensor. Dealer tried to tell me the fuel pump, of course they didn’t look at the car I just stopped in quick to ask them what might be the case.
    Sent from my iPhone using [url=http://r.tapatalk.com/
    Nov 03 2011
    All Over!
    I would be looking at the fuel pressure regulator.
    A ruptured diaphragm would cause an excessive fuel return to the tank.
    1986 Type 85 Audi 90 quattro
