    Account Terminated Two Rings
    Nov 12 2017
    JHM oil pan adapters
    Purchased off another member but seemed to be missing JHM -12AN Conversion Oil kit
    Adapters for B7-RS4 Oil Cooler
    https://jhmotorsports.com/jhm-oil-co...or-b7-rs4.html
    The 2 metal adapters aren’t included but can be bought from JHM.
    $245 shipped
    Veteran Member Three Rings outsider6661's Avatar
    Jul 02 2007
    2008 RS4, 2016 S5 Black Optics
    Markham Ontario, Canada
    Quote Originally Posted by milanRS4 View Post
    Attachment 64164
    Easy part to obtain parts. I can help you locate.
    $245 shipped
    The is kit missing the
    These still available?
    Sent from my SM-G950W using Tapatalk
    Nov 12 2017
    Pm sent
    Oct 12 2008
    NW Washington
    Moved.
    May 29 2010
    2004 Audi S4, 2008 Audi RS4 Ti
    Phildelphia / Auckland
    If you want to use the circled adapters with the factory oil cooler, you’ll have to buy the -12AN flare to M26x1.00 Adapters separately that are only sold with JHM’s kit. You can see them attached to the end of the oil lines in the above pic. JHM won’t sell them separately so you’ll have to source them from another vendor. I had to buy the Goodridge units from Patrick Motorsports for a total of $83.14.
    http://www.patrickmotorsports.com/pa...o-26mm-female/
    If you elect for an aftermarket oil cooler, then everything is readily available in AN flare.
