    Veteran Member Four Rings drewgold's Avatar
    Sep 21 2004
    1981 Kawasaki KZ440 and too many bikes and skis!
    Rocky Mountains, Canada
    Has anyone installed an S4 rear knuckle/spindle? Is it a direct swap?
    Debating swapping out the rear knuckle/spindle. It's such a pain pressing out the rear wheel bearing on the A4's, wondering if the rear knuckle/spindle from an S4 that has the separate bearing assembly could be directly swapped with the A4 spindle? Worth the effort?
    It appears based on part #'s that the rear axle, control arms and tie rods are all the same, as well as the ABS sensor so seems that it should be a direct swap?
    Anyone tried this?
    2006 A4 Avant, 2.0TQM - JHM Stg 1 Tune - Unitronic HFC/3" Downpipe - 034 Street Mounts - APR Snub - S4 RSB - 034 Turbo Inlet - JHM Short Shifter - Porsche 345mm Brembo Front Brakes w/ceramic pads - S4 Rear Brakes - Stock Sport Suspension/B5 front cups - Black Alcantara Recaro Interior - RoadNav/S100 Headunit - Summer: 19" OEM S5 wheels, 19x8.5 ET32 - Winter: OEM 18" RS4 stye wheels, 18x8 ET43 w/ Nokian studded tires - Dolphin Grey FTW!
    Veteran Member Three Rings Osher67's Avatar
    Nov 03 2012
    California/so cal
    http://www.audizine.com/forum/showth...aring-housings
    You will need b7 rear brakes or s4.
    -Josh
    2002 01A Quattro
    K04-15 (Unitronic)
    Sep 21 2004
    Quote Originally Posted by Osher67 View Post
    Thanks for the link! The vehicle in question is a B7 so sounds like it’s a direct swap. Will have to give doing this some serious thought. Guessing my bearings don’t have all that much life left in them at over 200k kms.
    Nov 03 2012
    California/so cal
    Quote Originally Posted by drewgold View Post
    It's probably a good guess lol. I got some b6 s4 spindles for my a4 with s4 brakes. my a4 ones were leaking grease out of both bearings with 130k miles.
    One thing I was looking into was the quality of the replacement bearings. Seams skf is the original bearing supplier, so I made sure I got them over the others (there's lots of cheeper options or good ones I've heard like Timkin) was kind of my reassurance that they will last long.
    note: I don't know at the time don't know if you know or not but, when I did my front wheel bearings I set my car down without tightening the axles and that's a big no no. (Can mess up the bearing) So make sure you tighten the wheel hub bolt before putting back on the ground.
    -Josh
    2002 01A Quattro
    K04-15 (Unitronic)
    Sep 21 2004
    Yes, I'm told that SKF is the OE supplier for B7 bearings.
    And thanks for the tip for the axle bolt!
