Originally Posted by
FlyboyS4
I've put the transmission into gear, then raised one of the rear wheels so I can gently rock it forward and backward, that popped it free.
That sounds like the best method at this point. My front axles are already removed though so hopefully that doesn't give me an issue. Will try today
b7_Andy
How are you using the air hammer? I usually partially thread a driveshaft bolt in and then air hammer the bolt head parallel with the driveshaft toward the transmission while pulling the driveshaft back and that’s gotten the stuck ones for me every time.
Just perpendicular against the axle cup. Sounds like your basically air hammering the trans AWAY from the axle using the bolt so I'll look into that too
Monty23
I installed an AA single piece on my car. Then I removed it a week later due to bad vibrations. I took me about 3 hours of straight hammering with a 4lb mallet. I beat the crap out of those cv joints and completely destroyed them in the process because that was the only way they would come off. One of the most miserable experiences ever. And yes, the cv joints on those one piece ds are def on the higher side of the tolerance range which causes an interference fit. Good luck and prepare to beat the crap out of those cv joints. Smash, smash, turn a little, repeat till it comes off.
Yea, a lot of people seem to have complaints. I have had zero issues with the AA shaft though and am very happy with it , aside from this. Pretty simple part. Good point about replacing the c/v end, pretty easy to do if I end up completely wrecking this one.
Thanks for all the input guys, will try again today.
