Results 1 to 6 of 6
    Veteran Member Three Rings K1196A's Avatar
    Feb 16 2007
    B9 S4, 2018 Q5, 2012 Tacoma TRD Sport
    DOVER, PA
    FUEL ISSUE? Feels like momentary drops under throttle. HPFP?
    Driving with high throttle I started experiencing some momentary stuttering yesterday, I pulled the codes and this is what i got (no CEL):
    008852 - Fuel Pressure Regulator Valve (N276)
    P2294 - 004 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 271984 km
    Time Indication: 0
    Freeze Frame:
    RPM: 1187 /min
    Load: 22.7 %
    Speed: 0.0 km/h
    Temperature: 79.0°C
    Temperature: 51.0°C
    Absolute Pres.: 1000.0 mbar
    Voltage: 11.938 V
    012425 - Signal Line for Fuel Pump Electronics
    P3089 - 002 - Electrical Malfunction - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 271984 km
    Time Indication: 0
    Freeze Frame:
    RPM: 1090 /min
    Load: 27.4 %
    Speed: 0.0 km/h
    Temperature: 79.0°C
    Temperature: 45.0°C
    Voltage: 13.716 V
    Readiness: 0000 0000
    I replaced the the low pressure pump and control module probably about a year ago. Also have some logs from the fuel rail (expected and actual), but I'm not smart enough to make sense of them...
    Saturday,28,April,2018,09:05:13:48254-VCID:*********************,VCDS Version: Release 18.2.0,Data version: 20180212 DS287.0
    8E0 910 115 P,ADVMB,2.0l R4/4V TFSI 0020,
    ,,G230,F0,G230,F1,G230,F2,G000,F0,G000,F0,G000,F0, G000,F0,G000,F0,G000,F0,G000,F0,G000,F0,G000,F0,
    Marker,TIME,Group 230 - Field 0,TIME,Group 230 - Field 1,TIME,Group 230 - Field 2,,,,,,,,,,,,,,,,,,,
    ,STAMP,Rail Pressure - (specified),STAMP,Rail Pressure - (actual),STAMP,Rail Pressure - Difference,,,,,,,,,,,,,,,,,,,
    ,, bar,, bar,, bar,,,,,,,,,,,,,,,,,,,
    ,0.10,77.04,0.10,77.04,0.10,0.00,,,,,,,,,,,,,,,,,, ,
    ,0.23,77.09,0.23,77.09,0.23,0.00,,,,,,,,,,,,,,,,,, ,
    ,0.35,77.05,0.35,77.05,0.35,0.00,,,,,,,,,,,,,,,,,, ,
    ,0.49,77.06,0.49,77.06,0.49,0.00,,,,,,,,,,,,,,,,,, ,
    ,0.62,77.06,0.62,77.06,0.62,0.00,,,,,,,,,,,,,,,,,, ,
    ,0.74,77.06,0.74,77.06,0.74,0.00,,,,,,,,,,,,,,,,,, ,
    ,0.87,77.05,0.87,77.05,0.87,0.00,,,,,,,,,,,,,,,,,, ,
    ,1.01,77.05,1.01,77.05,1.01,0.00,,,,,,,,,,,,,,,,,, ,
    ,1.13,76.58,1.13,75.10,1.13,1.48,,,,,,,,,,,,,,,,,, ,
    ,1.26,78.42,1.26,73.20,1.26,5.21,,,,,,,,,,,,,,,,,, ,
    ,1.38,80.16,1.38,80.51,1.38,-0.35,,,,,,,,,,,,,,,,,,,
    ,1.52,82.15,1.52,80.55,1.52,1.59,,,,,,,,,,,,,,,,,, ,
    ,1.65,84.02,1.65,84.51,1.65,-0.50,,,,,,,,,,,,,,,,,,,
    ,1.77,85.60,1.77,85.44,1.77,0.16,,,,,,,,,,,,,,,,,, ,
    ,1.90,87.17,1.90,86.81,1.90,0.36,,,,,,,,,,,,,,,,,, ,
    ,2.04,88.89,2.04,89.31,2.04,-0.42,,,,,,,,,,,,,,,,,,,
    ,2.16,86.41,2.16,87.79,2.16,-1.39,,,,,,,,,,,,,,,,,,,
    ,2.30,84.56,2.30,84.50,2.30,0.06,,,,,,,,,,,,,,,,,, ,
    ,2.41,83.41,2.41,84.83,2.41,-1.43,,,,,,,,,,,,,,,,,,,
    ,2.56,82.80,2.56,84.59,2.56,-1.79,,,,,,,,,,,,,,,,,,,
    ,2.68,82.41,2.68,81.86,2.68,0.55,,,,,,,,,,,,,,,,,, ,
    ,2.82,81.99,2.82,81.58,2.82,0.41,,,,,,,,,,,,,,,,,, ,
    ,2.94,81.65,2.94,80.89,2.94,0.76,,,,,,,,,,,,,,,,,, ,
    ,3.09,81.25,3.09,80.97,3.09,0.28,,,,,,,,,,,,,,,,,, ,
    ,3.21,80.86,3.21,80.80,3.21,0.05,,,,,,,,,,,,,,,,,, ,
    ,3.33,80.53,3.33,81.25,3.33,-0.72,,,,,,,,,,,,,,,,,,,
    ,3.46,80.20,3.46,80.89,3.46,-0.70,,,,,,,,,,,,,,,,,,,
    ,3.60,79.81,3.60,80.87,3.60,-1.06,,,,,,,,,,,,,,,,,,,
    ,3.72,79.49,3.72,80.15,3.72,-0.66,,,,,,,,,,,,,,,,,,,
    ,3.85,79.16,3.85,79.62,3.85,-0.47,,,,,,,,,,,,,,,,,,,
    ,3.98,78.76,3.98,78.76,3.98,0.00,,,,,,,,,,,,,,,,,, ,
    ,4.13,78.84,4.13,78.84,4.13,0.00,,,,,,,,,,,,,,,,,, ,
    ,4.26,78.77,4.26,78.77,4.26,0.00,,,,,,,,,,,,,,,,,, ,
    ,4.38,78.77,4.38,78.77,4.38,0.00,,,,,,,,,,,,,,,,,, ,
    ,4.51,78.88,4.51,78.88,4.51,0.00,,,,,,,,,,,,,,,,,, ,
    ,4.65,78.88,4.65,78.88,4.65,0.00,,,,,,,,,,,,,,,,,, ,
    ,4.78,77.63,4.78,77.11,4.78,0.51,,,,,,,,,,,,,,,,,, ,
    ,4.90,77.03,4.90,74.06,4.90,2.96,,,,,,,,,,,,,,,,,, ,
    ,5.02,78.48,5.02,76.08,5.02,2.40,,,,,,,,,,,,,,,,,, ,
    ,5.16,80.48,5.16,78.36,5.16,2.12,,,,,,,,,,,,,,,,,, ,
    ,5.30,82.14,5.30,82.87,5.30,-0.73,,,,,,,,,,,,,,,,,,,
    ,5.41,83.75,5.41,84.55,5.41,-0.80,,,,,,,,,,,,,,,,,,,
    ,5.55,85.55,5.55,85.28,5.55,0.26,,,,,,,,,,,,,,,,,, ,
    ,5.68,87.34,5.68,87.76,5.68,-0.42,,,,,,,,,,,,,,,,,,,
    ,5.81,88.88,5.81,88.82,5.81,0.06,,,,,,,,,,,,,,,,,, ,
    ,5.93,90.41,5.93,90.35,5.93,0.06,,,,,,,,,,,,,,,,,, ,
    ,6.06,92.18,6.06,92.10,6.06,0.07,,,,,,,,,,,,,,,,,, ,
    ,6.21,93.93,6.21,94.23,6.21,-0.30,,,,,,,,,,,,,,,,,,,
    ,6.33,95.43,6.33,95.54,6.33,-0.11,,,,,,,,,,,,,,,,,,,
    ,6.46,97.08,6.46,96.87,6.46,0.21,,,,,,,,,,,,,,,,,, ,
    ,6.59,98.41,6.59,98.54,6.59,-0.14,,,,,,,,,,,,,,,,,,,
    ,6.73,99.90,6.73,99.85,6.73,0.05,,,,,,,,,,,,,,,,,, ,
    ,6.85,98.10,6.85,99.36,6.85,-1.26,,,,,,,,,,,,,,,,,,,
    ,6.98,94.88,6.98,96.09,6.98,-1.21,,,,,,,,,,,,,,,,,,,
    ,7.10,92.17,7.10,91.03,7.10,1.14,,,,,,,,,,,,,,,,,, ,
    ,7.24,89.86,7.24,90.42,7.24,-0.56,,,,,,,,,,,,,,,,,,,
    ,7.36,88.31,7.36,88.73,7.36,-0.43,,,,,,,,,,,,,,,,,,,
    ,7.50,87.44,7.50,89.54,7.50,-2.11,,,,,,,,,,,,,,,,,,,
    ,7.62,86.89,7.62,88.74,7.62,-1.85,,,,,,,,,,,,,,,,,,,
    ,7.76,86.36,7.76,85.41,7.76,0.95,,,,,,,,,,,,,,,,,, ,
    ,7.89,85.82,7.89,84.86,7.89,0.96,,,,,,,,,,,,,,,,,, ,
    ,8.01,85.36,8.01,85.20,8.01,0.16,,,,,,,,,,,,,,,,,, ,
    ,8.14,84.89,8.14,84.42,8.14,0.47,,,,,,,,,,,,,,,,,, ,
    ,8.28,84.35,8.28,84.05,8.28,0.30,,,,,,,,,,,,,,,,,, ,
    ,8.40,83.91,8.40,83.81,8.40,0.10,,,,,,,,,,,,,,,,,, ,
    ,8.53,83.40,8.53,83.64,8.53,-0.24,,,,,,,,,,,,,,,,,,,
    ,8.65,82.97,8.65,83.51,8.65,-0.54,,,,,,,,,,,,,,,,,,,
    ,8.79,82.45,8.79,82.34,8.79,0.11,,,,,,,,,,,,,,,,,, ,
    ,8.91,82.02,8.91,82.31,8.91,-0.30,,,,,,,,,,,,,,,,,,,
    ,9.04,81.58,9.04,81.66,9.04,-0.08,,,,,,,,,,,,,,,,,,,
    ,9.16,81.15,9.16,81.66,9.16,-0.51,,,,,,,,,,,,,,,,,,,
    ,9.32,80.60,9.32,80.60,9.32,0.00,,,,,,,,,,,,,,,,,, ,
    ,9.43,80.19,9.43,79.99,9.43,0.20,,,,,,,,,,,,,,,,,, ,
    ,9.56,79.78,9.56,80.03,9.56,-0.26,,,,,,,,,,,,,,,,,,,
    ,9.68,79.37,9.68,79.29,9.68,0.08,,,,,,,,,,,,,,,,,, ,
    ,9.84,78.83,9.84,77.54,9.84,1.29,,,,,,,,,,,,,,,,,, ,
    ,9.96,78.45,9.96,78.19,9.96,0.26,,,,,,,,,,,,,,,,,, ,
    ,10.08,78.07,10.08,78.39,10.08,-0.32,,,,,,,,,,,,,,,,,,,
    ,10.21,77.62,10.21,77.48,10.21,0.14,,,,,,,,,,,,,,, ,,,,
    ,10.35,77.00,10.35,76.53,10.35,0.46,,,,,,,,,,,,,,, ,,,,
    ,10.48,76.33,10.48,76.26,10.48,0.07,,,,,,,,,,,,,,, ,,,,
    ,10.60,75.55,10.60,75.36,10.60,0.19,,,,,,,,,,,,,,, ,,,,
    ,10.73,74.76,10.73,75.52,10.73,-0.76,,,,,,,,,,,,,,,,,,,
    ,10.87,73.83,10.87,74.73,10.87,-0.90,,,,,,,,,,,,,,,,,,,
    ,10.99,72.86,10.99,73.33,10.99,-0.47,,,,,,,,,,,,,,,,,,,
    ,11.11,71.99,11.11,71.60,11.11,0.38,,,,,,,,,,,,,,, ,,,,
    ,11.24,71.12,11.24,70.50,11.24,0.62,,,,,,,,,,,,,,, ,,,,
    ,11.38,70.54,11.38,70.74,11.38,-0.21,,,,,,,,,,,,,,,,,,,
    ,11.51,70.28,11.51,70.76,11.51,-0.48,,,,,,,,,,,,,,,,,,,
    ,11.63,70.13,11.63,70.35,11.63,-0.22,,,,,,,,,,,,,,,,,,,
    ,11.76,70.07,11.76,69.70,11.76,0.37,,,,,,,,,,,,,,, ,,,,
    ,11.90,70.03,11.90,70.01,11.90,0.02,,,,,,,,,,,,,,, ,,,,
    ,12.03,70.02,12.03,70.52,12.03,-0.50,,,,,,,,,,,,,,,,,,,
    ,12.15,70.01,12.15,70.55,12.15,-0.55,,,,,,,,,,,,,,,,,,,
    ,12.28,70.00,12.28,69.45,12.28,0.55,,,,,,,,,,,,,,, ,,,,
    ,12.42,70.00,12.42,70.09,12.42,-0.10,,,,,,,,,,,,,,,,,,,
    ,12.55,70.00,12.55,70.45,12.55,-0.46,,,,,,,,,,,,,,,,,,,
    ,12.66,70.00,12.66,70.15,12.66,-0.16,,,,,,,,,,,,,,,,,,,
    ,12.79,70.00,12.79,70.42,12.79,-0.43,,,,,,,,,,,,,,,,,,,
    ,12.93,70.00,12.93,69.86,12.93,0.14,,,,,,,,,,,,,,, ,,,,
    ,13.06,70.00,13.06,70.94,13.06,-0.95,,,,,,,,,,,,,,,,,,,
    ,13.18,70.00,13.18,70.95,13.18,-0.95,,,,,,,,,,,,,,,,,,,
    ,13.31,70.00,13.31,70.76,13.31,-0.76,,,,,,,,,,,,,,,,,,,
    ,13.45,70.00,13.45,68.03,13.45,1.97,,,,,,,,,,,,,,, ,,,,
    ,13.57,70.00,13.57,69.05,13.57,0.94,,,,,,,,,,,,,,, ,,,,
    ,13.69,70.00,13.69,69.05,13.69,0.94,,,,,,,,,,,,,,, ,,,,
    ,13.82,70.00,13.82,69.78,13.82,0.21,,,,,,,,,,,,,,, ,,,,
    ,13.96,70.00,13.96,70.18,13.96,-0.18,,,,,,,,,,,,,,,,,,,
    ,14.08,70.00,14.08,71.31,14.08,-1.31,,,,,,,,,,,,,,,,,,,
    ,14.21,70.00,14.21,70.35,14.21,-0.36,,,,,,,,,,,,,,,,,,,
    ,14.33,70.00,14.33,70.55,14.33,-0.55,,,,,,,,,,,,,,,,,,,
    ,14.48,70.00,14.48,70.38,14.48,-0.38,,,,,,,,,,,,,,,,,,,
    ,14.60,70.00,14.60,68.99,14.60,1.00,,,,,,,,,,,,,,, ,,,,
    ,14.72,70.00,14.72,70.23,14.72,-0.23,,,,,,,,,,,,,,,,,,,
    ,14.85,70.00,14.85,69.74,14.85,0.25,,,,,,,,,,,,,,, ,,,,
    ,14.99,70.00,14.99,70.01,14.99,-0.02,,,,,,,,,,,,,,,,,,,
    ,15.12,70.00,15.12,68.84,15.12,1.15,,,,,,,,,,,,,,, ,,,,
    ,15.25,70.28,15.25,69.48,15.25,0.80,,,,,,,,,,,,,,, ,,,,
    ,15.36,71.61,15.36,72.45,15.36,-0.84,,,,,,,,,,,,,,,,,,,
    ,15.51,73.77,15.51,73.15,15.51,0.61,,,,,,,,,,,,,,, ,,,,
    ,15.64,74.48,15.64,74.75,15.64,-0.27,,,,,,,,,,,,,,,,,,,
    ,15.76,74.83,15.76,73.69,15.76,1.14,,,,,,,,,,,,,,, ,,,,
    ,15.89,75.16,15.89,75.48,15.89,-0.32,,,,,,,,,,,,,,,,,,,
    ,16.03,75.22,16.03,76.01,16.03,-0.79,,,,,,,,,,,,,,,,,,,
    ,16.15,75.19,16.15,75.27,16.15,-0.08,,,,,,,,,,,,,,,,,,,
    ,16.28,75.12,16.28,74.70,16.28,0.42,,,,,,,,,,,,,,, ,,,,
    ,16.40,75.06,16.40,75.72,16.40,-0.66,,,,,,,,,,,,,,,,,,,
    ,16.54,74.98,16.54,74.97,16.54,0.01,,,,,,,,,,,,,,, ,,,,
    ,16.67,74.90,16.67,75.63,16.67,-0.74,,,,,,,,,,,,,,,,,,,
    ,16.80,74.84,16.80,74.24,16.80,0.59,,,,,,,,,,,,,,, ,,,,
    ,16.92,74.76,16.92,74.85,16.92,-0.09,,,,,,,,,,,,,,,,,,,
    ,17.06,74.68,17.06,74.90,17.06,-0.22,,,,,,,,,,,,,,,,,,,
    ,17.18,74.58,17.18,74.38,17.18,0.19,,,,,,,,,,,,,,, ,,,,
    ,17.31,74.44,17.31,75.11,17.31,-0.67,,,,,,,,,,,,,,,,,,,
    ,17.43,74.34,17.43,73.51,17.43,0.82,,,,,,,,,,,,,,, ,,,,
    ,17.60,74.19,17.60,74.09,17.60,0.09,,,,,,,,,,,,,,, ,,,,
    ,17.73,73.99,17.73,73.87,17.73,0.12,,,,,,,,,,,,,,, ,,,,
    ,17.85,73.78,17.85,74.18,17.85,-0.41,,,,,,,,,,,,,,,,,,,
    ,17.98,73.56,17.98,73.14,17.98,0.42,,,,,,,,,,,,,,, ,,,,
    ,18.12,73.32,18.12,73.38,18.12,-0.07,,,,,,,,,,,,,,,,,,,
    ,18.24,73.08,18.24,72.87,18.24,0.21,,,,,,,,,,,,,,, ,,,,
    ,18.37,72.77,18.37,73.38,18.37,-0.62,,,,,,,,,,,,,,,,,,,
    ,18.49,72.49,18.49,72.54,18.49,-0.05,,,,,,,,,,,,,,,,,,,
    ,18.63,72.17,18.63,71.37,18.63,0.79,,,,,,,,,,,,,,, ,,,,
    ,18.76,71.87,18.76,71.62,18.76,0.25,,,,,,,,,,,,,,, ,,,,
    ,18.88,71.58,18.88,71.69,18.88,-0.11,,,,,,,,,,,,,,,,,,,
    ,19.01,71.32,19.01,71.48,19.01,-0.16,,,,,,,,,,,,,,,,,,,
    ,19.15,72.04,19.15,72.04,19.15,0.00,,,,,,,,,,,,,,, ,,,,
    ,19.28,72.09,19.28,72.09,19.28,0.00,,,,,,,,,,,,,,, ,,,,
    ,19.40,72.05,19.40,72.05,19.40,0.00,,,,,,,,,,,,,,, ,,,,
    ,19.52,72.09,19.52,72.09,19.52,0.00,,,,,,,,,,,,,,, ,,,,
    ,19.67,72.11,19.67,72.11,19.67,0.00,,,,,,,,,,,,,,, ,,,,
    ,19.81,72.14,19.81,72.14,19.81,0.00,,,,,,,,,,,,,,, ,,,,
    ,19.95,72.17,19.95,72.17,19.95,0.00,,,,,,,,,,,,,,, ,,,,
    ,20.07,72.16,20.07,72.16,20.07,0.00,,,,,,,,,,,,,,, ,,,,
    ,20.21,72.17,20.21,72.17,20.21,0.00,,,,,,,,,,,,,,, ,,,,
    ,20.34,72.17,20.34,72.17,20.34,0.00,,,,,,,,,,,,,,, ,,,,
    ,20.46,72.22,20.46,72.22,20.46,0.00,,,,,,,,,,,,,,, ,,,,
    ,20.59,72.22,20.59,72.22,20.59,0.00,,,,,,,,,,,,,,, ,,,,
    ,20.73,72.17,20.73,72.17,20.73,0.00,,,,,,,,,,,,,,, ,,,,
    ,20.85,72.24,20.85,72.24,20.85,0.00,,,,,,,,,,,,,,, ,,,,
    ,20.98,72.21,20.98,72.21,20.98,0.00,,,,,,,,,,,,,,, ,,,,
    ,21.10,72.29,21.10,72.29,21.10,0.00,,,,,,,,,,,,,,, ,,,,
    ,21.24,72.21,21.24,72.21,21.24,0.00,,,,,,,,,,,,,,, ,,,,
    ,21.37,72.24,21.37,72.24,21.37,0.00,,,,,,,,,,,,,,, ,,,,
    ,21.49,72.29,21.49,72.29,21.49,0.00,,,,,,,,,,,,,,, ,,,,
    ,21.62,72.29,21.62,72.29,21.62,0.00,,,,,,,,,,,,,,, ,,,,
    ,21.76,72.32,21.76,72.32,21.76,0.00,,,,,,,,,,,,,,, ,,,,
    ,21.88,72.31,21.88,72.31,21.88,0.00,,,,,,,,,,,,,,, ,,,,
    ,22.01,72.32,22.01,72.32,22.01,0.00,,,,,,,,,,,,,,, ,,,,
    ,22.13,72.38,22.13,72.38,22.13,0.00,,,,,,,,,,,,,,, ,,,,
    ,22.27,72.35,22.27,72.35,22.27,0.00,,,,,,,,,,,,,,, ,,,,
    ,22.40,72.38,22.40,72.38,22.40,0.00,,,,,,,,,,,,,,, ,,,,
    ,22.52,72.41,22.52,72.41,22.52,0.00,,,,,,,,,,,,,,, ,,,,
    ,22.65,72.41,22.65,72.41,22.65,0.00,,,,,,,,,,,,,,, ,,,,
    ,22.79,72.38,22.79,72.38,22.79,0.00,,,,,,,,,,,,,,, ,,,,
    ,22.91,72.41,22.91,72.41,22.91,0.00,,,,,,,,,,,,,,, ,,,,
    ,23.04,72.41,23.04,72.41,23.04,0.00,,,,,,,,,,,,,,, ,,,,
    ,23.16,72.41,23.16,72.41,23.16,0.00,,,,,,,,,,,,,,, ,,,,
    ,23.31,72.43,23.31,72.43,23.31,0.00,,,,,,,,,,,,,,, ,,,,
    ,23.43,71.14,23.43,70.46,23.43,0.68,,,,,,,,,,,,,,, ,,,,
    ,23.56,70.68,23.56,70.84,23.56,-0.16,,,,,,,,,,,,,,,,,,,
    ,23.68,70.36,23.68,71.13,23.68,-0.77,,,,,,,,,,,,,,,,,,,
    ,23.83,69.88,23.83,70.70,23.83,-0.82,,,,,,,,,,,,,,,,,,,
    ,23.95,69.54,23.95,69.77,23.95,-0.24,,,,,,,,,,,,,,,,,,,
    ,24.07,69.20,24.07,69.42,24.07,-0.22,,,,,,,,,,,,,,,,,,,
    ,24.20,68.89,24.20,69.06,24.20,-0.17,,,,,,,,,,,,,,,,,,,
    ,24.35,68.49,24.35,68.67,24.35,-0.18,,,,,,,,,,,,,,,,,,,
    ,24.47,68.20,24.47,68.44,24.47,-0.24,,,,,,,,,,,,,,,,,,,
    ,24.60,67.93,24.60,67.94,24.60,-0.02,,,,,,,,,,,,,,,,,,,
    ,24.73,67.59,24.73,67.54,24.73,0.05,,,,,,,,,,,,,,, ,,,,
    ,24.88,67.23,24.88,67.37,24.88,-0.14,,,,,,,,,,,,,,,,,,,
    ,24.99,66.41,24.99,68.44,24.99,-2.04,,,,,,,,,,,,,,,,,,,
    ,25.12,65.50,25.12,68.32,25.12,-2.83,,,,,,,,,,,,,,,,,,,
    ,25.24,64.59,25.24,67.99,25.24,-3.40,,,,,,,,,,,,,,,,,,,
    ,25.39,63.40,25.39,66.00,25.39,-2.60,,,,,,,,,,,,,,,,,,,
    ,25.51,62.46,25.51,64.59,25.51,-2.13,,,,,,,,,,,,,,,,,,,
    ,25.63,61.45,25.63,61.40,25.63,0.05,,,,,,,,,,,,,,, ,,,,
    ,25.76,60.45,25.76,60.69,25.76,-0.24,,,,,,,,,,,,,,,,,,,
    ,25.90,59.30,25.90,59.00,25.90,0.30,,,,,,,,,,,,,,, ,,,,
    ,26.02,58.28,26.02,58.34,26.02,-0.06,,,,,,,,,,,,,,,,,,,
    ,26.15,57.02,26.15,56.44,26.15,0.58,,,,,,,,,,,,,,, ,,,,
    ,26.27,55.87,26.27,55.93,26.27,-0.06,,,,,,,,,,,,,,,,,,,
    ,26.41,54.56,26.41,54.85,26.41,-0.29,,,,,,,,,,,,,,,,,,,
    ,26.55,53.42,26.55,54.31,26.55,-0.89,,,,,,,,,,,,,,,,,,,
    ,26.66,52.29,26.66,53.70,26.66,-1.41,,,,,,,,,,,,,,,,,,,
    ,26.80,51.13,26.80,51.70,26.80,-0.58,,,,,,,,,,,,,,,,,,,
    ,26.93,50.68,26.93,46.53,26.93,4.14,,,,,,,,,,,,,,, ,,,,
    ,27.07,51.56,27.07,49.75,27.07,1.81,,,,,,,,,,,,,,, ,,,,
    ,27.19,52.57,27.19,50.73,27.19,1.84,,,,,,,,,,,,,,, ,,,,
    ,27.32,53.66,27.32,51.72,27.32,1.94,,,,,,,,,,,,,,, ,,,,
    ,27.46,54.98,27.46,53.43,27.46,1.55,,,,,,,,,,,,,,, ,,,,
    ,27.59,56.15,27.59,55.56,27.59,0.58,,,,,,,,,,,,,,, ,,,,
    ,27.71,57.34,27.71,57.48,27.71,-0.15,,,,,,,,,,,,,,,,,,,
    ,27.83,58.17,27.83,59.10,27.83,-0.94,,,,,,,,,,,,,,,,,,,
    ,27.98,58.62,27.98,58.38,27.98,0.24,,,,,,,,,,,,,,, ,,,,
    ,28.10,58.97,28.10,58.62,28.10,0.35,,,,,,,,,,,,,,, ,,,,
    ,28.23,59.20,28.23,59.15,28.23,0.05,,,,,,,,,,,,,,, ,,,,
    ,28.35,59.37,28.35,58.92,28.35,0.45,,,,,,,,,,,,,,, ,,,,
    ,28.50,59.59,28.50,59.15,28.50,0.43,,,,,,,,,,,,,,, ,,,,
    ,28.62,59.78,28.62,59.60,28.62,0.17,,,,,,,,,,,,,,, ,,,,
    ,28.74,60.14,28.74,59.73,28.74,0.40,,,,,,,,,,,,,,, ,,,,
    ,28.87,61.24,28.87,60.83,28.87,0.41,,,,,,,,,,,,,,, ,,,,
    ,29.01,62.70,29.01,64.56,29.01,-1.87,,,,,,,,,,,,,,,,,,,
    ,29.13,64.01,29.13,64.05,29.13,-0.05,,,,,,,,,,,,,,,,,,,
    ,29.26,65.64,29.26,64.53,29.26,1.10,,,,,,,,,,,,,,, ,,,,
    ,29.38,67.07,29.38,66.27,29.38,0.79,,,,,,,,,,,,,,, ,,,,
    ,29.53,68.79,29.53,68.11,29.53,0.68,,,,,,,,,,,,,,, ,,,,
    ,29.65,70.29,29.65,70.01,29.65,0.27,,,,,,,,,,,,,,, ,,,,
    ,29.77,71.79,29.77,72.48,29.77,-0.70,,,,,,,,,,,,,,,,,,,
    ,29.90,73.52,29.90,73.31,29.90,0.21,,,,,,,,,,,,,,, ,,,,
    ,30.05,75.17,30.05,75.95,30.05,-0.78,,,,,,,,,,,,,,,,,,,
    ,30.18,76.70,30.18,75.83,30.18,0.86,,,,,,,,,,,,,,, ,,,,
    ,30.31,77.80,30.31,77.93,30.31,-0.13,,,,,,,,,,,,,,,,,,,
    ,30.43,78.68,30.43,79.70,30.43,-1.02,,,,,,,,,,,,,,,,,,,
    ,30.58,79.38,30.58,78.12,30.58,1.26,,,,,,,,,,,,,,, ,,,,
    ,30.71,79.92,30.71,76.09,30.71,3.83,,,,,,,,,,,,,,, ,,,,
    ,30.83,80.52,30.83,74.04,30.83,6.47,,,,,,,,,,,,,,, ,,,,
    ,30.96,81.26,30.96,76.80,30.96,4.46,,,,,,,,,,,,,,, ,,,,
    ,31.10,82.00,31.10,79.10,31.10,2.89,,,,,,,,,,,,,,, ,,,,
    ,31.23,82.62,31.23,81.83,31.23,0.79,,,,,,,,,,,,,,, ,,,,
    ,31.35,83.27,31.35,85.02,31.35,-1.76,,,,,,,,,,,,,,,,,,,
    ,31.48,84.03,31.48,86.10,31.48,-2.07,,,,,,,,,,,,,,,,,,,
    ,31.62,84.91,31.62,85.29,31.62,-0.38,,,,,,,,,,,,,,,,,,,
    ,31.74,85.81,31.74,86.08,31.74,-0.27,,,,,,,,,,,,,,,,,,,
    ,31.87,86.60,31.87,86.02,31.87,0.58,,,,,,,,,,,,,,, ,,,,
    ,32.00,87.43,32.00,88.37,32.00,-0.94,,,,,,,,,,,,,,,,,,,
    ,32.13,88.42,32.13,87.88,32.13,0.54,,,,,,,,,,,,,,, ,,,,
    ,32.26,89.30,32.26,89.74,32.26,-0.44,,,,,,,,,,,,,,,,,,,
    ,32.38,90.21,32.38,89.45,32.38,0.76,,,,,,,,,,,,,,, ,,,,
    ,32.51,91.14,32.51,90.68,32.51,0.46,,,,,,,,,,,,,,, ,,,,
    ,32.65,92.09,32.65,92.06,32.65,0.03,,,,,,,,,,,,,,, ,,,,
    ,32.77,93.06,32.77,92.23,32.77,0.83,,,,,,,,,,,,,,, ,,,,
    ,32.90,94.07,32.90,93.71,32.90,0.36,,,,,,,,,,,,,,, ,,,,
    ,33.02,95.11,33.02,94.59,33.02,0.52,,,,,,,,,,,,,,, ,,,,
    ,33.16,96.04,33.16,96.16,33.16,-0.13,,,,,,,,,,,,,,,,,,,
    ,33.30,96.84,33.30,96.24,33.30,0.60,,,,,,,,,,,,,,, ,,,,
    ,33.41,97.52,33.41,96.35,33.41,1.17,,,,,,,,,,,,,,, ,,,,
    ,33.55,98.16,33.55,97.94,33.55,0.22,,,,,,,,,,,,,,, ,,,,
    ,33.68,98.81,33.68,100.53,33.68,-1.72,,,,,,,,,,,,,,,,,,,
    ,33.82,99.48,33.82,99.23,33.82,0.25,,,,,,,,,,,,,,, ,,,,
    ,33.94,100.07,33.94,100.91,33.94,-0.84,,,,,,,,,,,,,,,,,,,
    ,34.07,100.65,34.07,102.94,34.07,-2.29,,,,,,,,,,,,,,,,,,,
    ,34.21,101.33,34.21,101.72,34.21,-0.39,,,,,,,,,,,,,,,,,,,
    ,34.33,101.91,34.33,103.02,34.33,-1.11,,,,,,,,,,,,,,,,,,,
    ,34.46,102.58,34.46,103.10,34.46,-0.52,,,,,,,,,,,,,,,,,,,
    ,34.59,103.18,34.59,101.46,34.59,1.71,,,,,,,,,,,,, ,,,,,,
    ,34.73,104.05,34.73,104.31,34.73,-0.27,,,,,,,,,,,,,,,,,,,
    ,34.85,105.24,34.85,107.26,34.85,-2.02,,,,,,,,,,,,,,,,,,,
    ,34.98,106.66,34.98,108.06,34.98,-1.41,,,,,,,,,,,,,,,,,,,
    ,35.10,108.35,35.10,109.61,35.10,-1.26,,,,,,,,,,,,,,,,,,,
    ,35.25,109.21,35.25,110.75,35.25,-1.55,,,,,,,,,,,,,,,,,,,
    ,35.37,109.57,35.37,110.55,35.37,-0.98,,,,,,,,,,,,,,,,,,,
    ,35.49,109.77,35.49,109.15,35.49,0.62,,,,,,,,,,,,, ,,,,,,
    ,35.62,109.87,35.62,110.29,35.62,-0.42,,,,,,,,,,,,,,,,,,,
    ,35.76,109.94,35.76,111.88,35.76,-1.94,,,,,,,,,,,,,,,,,,,
    ,35.88,109.96,35.88,110.14,35.88,-0.18,,,,,,,,,,,,,,,,,,,
    ,36.01,109.98,36.01,109.67,36.01,0.30,,,,,,,,,,,,, ,,,,,,
    ,36.13,109.98,36.13,107.23,36.13,2.75,,,,,,,,,,,,, ,,,,,,
    ,36.27,109.99,36.27,109.05,36.27,0.94,,,,,,,,,,,,, ,,,,,,
    ,36.40,109.99,36.40,109.12,36.40,0.87,,,,,,,,,,,,, ,,,,,,
    ,36.52,109.99,36.52,107.41,36.52,2.58,,,,,,,,,,,,, ,,,,,,
    ,36.65,109.99,36.65,108.20,36.65,1.79,,,,,,,,,,,,, ,,,,,,
    ,36.79,109.99,36.79,109.40,36.79,0.59,,,,,,,,,,,,, ,,,,,,
    ,36.91,109.99,36.91,110.75,36.91,-0.76,,,,,,,,,,,,,,,,,,,
    Dec 05 2016
    miami FL
    what is this crap?
    Feb 16 2007
    DOVER, PA
    Quote Originally Posted by ahotboy15 View Post
    what is this crap?
    Evidently over your head too.
    The fuel pressure logging to the rail. I didn't have a means to attach it short of multiple posts.
    Sent from my XT1575 using Tapatalk
    Active Member Four Rings EvolutionArmory's Avatar
    May 20 2017
    New Hampshire
    what is this crap?
    If you don’t understand what you’re looking at in a technical discussion, maybe you should excuse yourself from it. Pretty simple.
    Dec 05 2016
    miami FL
    please decyhper that then haha seek to amaze.
    Feb 16 2007
    DOVER, PA
    I think those codes might have been thrown when I did my cam follower replacement, and aren't actually related to the issue I had.
    I did check hoses and such for a vac leak and found that the hard evap hose had come loose from the valve cover connection so I relocked that one. I'll have to take it out and push it later to see if I can get the issue to repeat; not sure if that evap line being loose would cause that stuttering.
