008852 - Fuel Pressure Regulator Valve (N276)
P2294 - 004 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 271984 km
Time Indication: 0
Freeze Frame:
RPM: 1187 /min
Load: 22.7 %
Speed: 0.0 km/h
Temperature: 79.0°C
Temperature: 51.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 11.938 V
012425 - Signal Line for Fuel Pump Electronics
P3089 - 002 - Electrical Malfunction - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 271984 km
Time Indication: 0
Freeze Frame:
RPM: 1090 /min
Load: 27.4 %
Speed: 0.0 km/h
Temperature: 79.0°C
Temperature: 45.0°C
Voltage: 13.716 V
Readiness: 0000 0000
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 271984 km
Time Indication: 0
Freeze Frame:
RPM: 1187 /min
Load: 22.7 %
Speed: 0.0 km/h
Temperature: 79.0°C
Temperature: 51.0°C
Voltage: 11.938 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 271984 km
Time Indication: 0
Freeze Frame:
RPM: 1090 /min
Load: 27.4 %
Speed: 0.0 km/h
Temperature: 79.0°C
Temperature: 45.0°C
Voltage: 13.716 V
I replaced the the low pressure pump and control module probably about a year ago. Also have some logs from the fuel rail (expected and actual), but I'm not smart enough to make sense of them...
Saturday,28,April,2018,09:05:13:48254-VCID:*********************,VCDS Version: Release 18.2.0,Data version: 20180212 DS287.0
8E0 910 115 P,ADVMB,2.0l R4/4V TFSI 0020,
,,G230,F0,G230,F1,G230,F2,G000,F0,G000,F0,G000,F0, G000,F0,G000,F0,G000,F0,G000,F0,G000,F0,G000,F0,
Marker,TIME,Group 230 - Field 0,TIME,Group 230 - Field 1,TIME,Group 230 - Field 2,,,,,,,,,,,,,,,,,,,
,STAMP,Rail Pressure - (specified),STAMP,Rail Pressure - (actual),STAMP,Rail Pressure - Difference,,,,,,,,,,,,,,,,,,,
,, bar,, bar,, bar,,,,,,,,,,,,,,,,,,,
,0.10,77.04,0.10,77.04,0.10,0.00,,,,,,,,,,,,,,,,,, ,
,0.23,77.09,0.23,77.09,0.23,0.00,,,,,,,,,,,,,,,,,, ,
,0.35,77.05,0.35,77.05,0.35,0.00,,,,,,,,,,,,,,,,,, ,
,0.49,77.06,0.49,77.06,0.49,0.00,,,,,,,,,,,,,,,,,, ,
,0.62,77.06,0.62,77.06,0.62,0.00,,,,,,,,,,,,,,,,,, ,
,0.74,77.06,0.74,77.06,0.74,0.00,,,,,,,,,,,,,,,,,, ,
,0.87,77.05,0.87,77.05,0.87,0.00,,,,,,,,,,,,,,,,,, ,
,1.01,77.05,1.01,77.05,1.01,0.00,,,,,,,,,,,,,,,,,, ,
,1.13,76.58,1.13,75.10,1.13,1.48,,,,,,,,,,,,,,,,,, ,
,1.26,78.42,1.26,73.20,1.26,5.21,,,,,,,,,,,,,,,,,, ,
,1.38,80.16,1.38,80.51,1.38,-0.35,,,,,,,,,,,,,,,,,,,
,1.52,82.15,1.52,80.55,1.52,1.59,,,,,,,,,,,,,,,,,, ,
,1.65,84.02,1.65,84.51,1.65,-0.50,,,,,,,,,,,,,,,,,,,
,1.77,85.60,1.77,85.44,1.77,0.16,,,,,,,,,,,,,,,,,, ,
,1.90,87.17,1.90,86.81,1.90,0.36,,,,,,,,,,,,,,,,,, ,
,2.04,88.89,2.04,89.31,2.04,-0.42,,,,,,,,,,,,,,,,,,,
,2.16,86.41,2.16,87.79,2.16,-1.39,,,,,,,,,,,,,,,,,,,
,2.30,84.56,2.30,84.50,2.30,0.06,,,,,,,,,,,,,,,,,, ,
,2.41,83.41,2.41,84.83,2.41,-1.43,,,,,,,,,,,,,,,,,,,
,2.56,82.80,2.56,84.59,2.56,-1.79,,,,,,,,,,,,,,,,,,,
,2.68,82.41,2.68,81.86,2.68,0.55,,,,,,,,,,,,,,,,,, ,
,2.82,81.99,2.82,81.58,2.82,0.41,,,,,,,,,,,,,,,,,, ,
,2.94,81.65,2.94,80.89,2.94,0.76,,,,,,,,,,,,,,,,,, ,
,3.09,81.25,3.09,80.97,3.09,0.28,,,,,,,,,,,,,,,,,, ,
,3.21,80.86,3.21,80.80,3.21,0.05,,,,,,,,,,,,,,,,,, ,
,3.33,80.53,3.33,81.25,3.33,-0.72,,,,,,,,,,,,,,,,,,,
,3.46,80.20,3.46,80.89,3.46,-0.70,,,,,,,,,,,,,,,,,,,
,3.60,79.81,3.60,80.87,3.60,-1.06,,,,,,,,,,,,,,,,,,,
,3.72,79.49,3.72,80.15,3.72,-0.66,,,,,,,,,,,,,,,,,,,
,3.85,79.16,3.85,79.62,3.85,-0.47,,,,,,,,,,,,,,,,,,,
,3.98,78.76,3.98,78.76,3.98,0.00,,,,,,,,,,,,,,,,,, ,
,4.13,78.84,4.13,78.84,4.13,0.00,,,,,,,,,,,,,,,,,, ,
,4.26,78.77,4.26,78.77,4.26,0.00,,,,,,,,,,,,,,,,,, ,
,4.38,78.77,4.38,78.77,4.38,0.00,,,,,,,,,,,,,,,,,, ,
,4.51,78.88,4.51,78.88,4.51,0.00,,,,,,,,,,,,,,,,,, ,
,4.65,78.88,4.65,78.88,4.65,0.00,,,,,,,,,,,,,,,,,, ,
,4.78,77.63,4.78,77.11,4.78,0.51,,,,,,,,,,,,,,,,,, ,
,4.90,77.03,4.90,74.06,4.90,2.96,,,,,,,,,,,,,,,,,, ,
,5.02,78.48,5.02,76.08,5.02,2.40,,,,,,,,,,,,,,,,,, ,
,5.16,80.48,5.16,78.36,5.16,2.12,,,,,,,,,,,,,,,,,, ,
,5.30,82.14,5.30,82.87,5.30,-0.73,,,,,,,,,,,,,,,,,,,
,5.41,83.75,5.41,84.55,5.41,-0.80,,,,,,,,,,,,,,,,,,,
,5.55,85.55,5.55,85.28,5.55,0.26,,,,,,,,,,,,,,,,,, ,
,5.68,87.34,5.68,87.76,5.68,-0.42,,,,,,,,,,,,,,,,,,,
,5.81,88.88,5.81,88.82,5.81,0.06,,,,,,,,,,,,,,,,,, ,
,5.93,90.41,5.93,90.35,5.93,0.06,,,,,,,,,,,,,,,,,, ,
,6.06,92.18,6.06,92.10,6.06,0.07,,,,,,,,,,,,,,,,,, ,
,6.21,93.93,6.21,94.23,6.21,-0.30,,,,,,,,,,,,,,,,,,,
,6.33,95.43,6.33,95.54,6.33,-0.11,,,,,,,,,,,,,,,,,,,
,6.46,97.08,6.46,96.87,6.46,0.21,,,,,,,,,,,,,,,,,, ,
,6.59,98.41,6.59,98.54,6.59,-0.14,,,,,,,,,,,,,,,,,,,
,6.73,99.90,6.73,99.85,6.73,0.05,,,,,,,,,,,,,,,,,, ,
,6.85,98.10,6.85,99.36,6.85,-1.26,,,,,,,,,,,,,,,,,,,
,6.98,94.88,6.98,96.09,6.98,-1.21,,,,,,,,,,,,,,,,,,,
,7.10,92.17,7.10,91.03,7.10,1.14,,,,,,,,,,,,,,,,,, ,
,7.24,89.86,7.24,90.42,7.24,-0.56,,,,,,,,,,,,,,,,,,,
,7.36,88.31,7.36,88.73,7.36,-0.43,,,,,,,,,,,,,,,,,,,
,7.50,87.44,7.50,89.54,7.50,-2.11,,,,,,,,,,,,,,,,,,,
,7.62,86.89,7.62,88.74,7.62,-1.85,,,,,,,,,,,,,,,,,,,
,7.76,86.36,7.76,85.41,7.76,0.95,,,,,,,,,,,,,,,,,, ,
,7.89,85.82,7.89,84.86,7.89,0.96,,,,,,,,,,,,,,,,,, ,
,8.01,85.36,8.01,85.20,8.01,0.16,,,,,,,,,,,,,,,,,, ,
,8.14,84.89,8.14,84.42,8.14,0.47,,,,,,,,,,,,,,,,,, ,
,8.28,84.35,8.28,84.05,8.28,0.30,,,,,,,,,,,,,,,,,, ,
,8.40,83.91,8.40,83.81,8.40,0.10,,,,,,,,,,,,,,,,,, ,
,8.53,83.40,8.53,83.64,8.53,-0.24,,,,,,,,,,,,,,,,,,,
,8.65,82.97,8.65,83.51,8.65,-0.54,,,,,,,,,,,,,,,,,,,
,8.79,82.45,8.79,82.34,8.79,0.11,,,,,,,,,,,,,,,,,, ,
,8.91,82.02,8.91,82.31,8.91,-0.30,,,,,,,,,,,,,,,,,,,
,9.04,81.58,9.04,81.66,9.04,-0.08,,,,,,,,,,,,,,,,,,,
,9.16,81.15,9.16,81.66,9.16,-0.51,,,,,,,,,,,,,,,,,,,
,9.32,80.60,9.32,80.60,9.32,0.00,,,,,,,,,,,,,,,,,, ,
,9.43,80.19,9.43,79.99,9.43,0.20,,,,,,,,,,,,,,,,,, ,
,9.56,79.78,9.56,80.03,9.56,-0.26,,,,,,,,,,,,,,,,,,,
,9.68,79.37,9.68,79.29,9.68,0.08,,,,,,,,,,,,,,,,,, ,
,9.84,78.83,9.84,77.54,9.84,1.29,,,,,,,,,,,,,,,,,, ,
,9.96,78.45,9.96,78.19,9.96,0.26,,,,,,,,,,,,,,,,,, ,
,10.08,78.07,10.08,78.39,10.08,-0.32,,,,,,,,,,,,,,,,,,,
,10.21,77.62,10.21,77.48,10.21,0.14,,,,,,,,,,,,,,, ,,,,
,10.35,77.00,10.35,76.53,10.35,0.46,,,,,,,,,,,,,,, ,,,,
,10.48,76.33,10.48,76.26,10.48,0.07,,,,,,,,,,,,,,, ,,,,
,10.60,75.55,10.60,75.36,10.60,0.19,,,,,,,,,,,,,,, ,,,,
,10.73,74.76,10.73,75.52,10.73,-0.76,,,,,,,,,,,,,,,,,,,
,10.87,73.83,10.87,74.73,10.87,-0.90,,,,,,,,,,,,,,,,,,,
,10.99,72.86,10.99,73.33,10.99,-0.47,,,,,,,,,,,,,,,,,,,
,11.11,71.99,11.11,71.60,11.11,0.38,,,,,,,,,,,,,,, ,,,,
,11.24,71.12,11.24,70.50,11.24,0.62,,,,,,,,,,,,,,, ,,,,
,11.38,70.54,11.38,70.74,11.38,-0.21,,,,,,,,,,,,,,,,,,,
,11.51,70.28,11.51,70.76,11.51,-0.48,,,,,,,,,,,,,,,,,,,
,11.63,70.13,11.63,70.35,11.63,-0.22,,,,,,,,,,,,,,,,,,,
,11.76,70.07,11.76,69.70,11.76,0.37,,,,,,,,,,,,,,, ,,,,
,11.90,70.03,11.90,70.01,11.90,0.02,,,,,,,,,,,,,,, ,,,,
,12.03,70.02,12.03,70.52,12.03,-0.50,,,,,,,,,,,,,,,,,,,
,12.15,70.01,12.15,70.55,12.15,-0.55,,,,,,,,,,,,,,,,,,,
,12.28,70.00,12.28,69.45,12.28,0.55,,,,,,,,,,,,,,, ,,,,
,12.42,70.00,12.42,70.09,12.42,-0.10,,,,,,,,,,,,,,,,,,,
,12.55,70.00,12.55,70.45,12.55,-0.46,,,,,,,,,,,,,,,,,,,
,12.66,70.00,12.66,70.15,12.66,-0.16,,,,,,,,,,,,,,,,,,,
,12.79,70.00,12.79,70.42,12.79,-0.43,,,,,,,,,,,,,,,,,,,
,12.93,70.00,12.93,69.86,12.93,0.14,,,,,,,,,,,,,,, ,,,,
,13.06,70.00,13.06,70.94,13.06,-0.95,,,,,,,,,,,,,,,,,,,
,13.18,70.00,13.18,70.95,13.18,-0.95,,,,,,,,,,,,,,,,,,,
,13.31,70.00,13.31,70.76,13.31,-0.76,,,,,,,,,,,,,,,,,,,
,13.45,70.00,13.45,68.03,13.45,1.97,,,,,,,,,,,,,,, ,,,,
,13.57,70.00,13.57,69.05,13.57,0.94,,,,,,,,,,,,,,, ,,,,
,13.69,70.00,13.69,69.05,13.69,0.94,,,,,,,,,,,,,,, ,,,,
,13.82,70.00,13.82,69.78,13.82,0.21,,,,,,,,,,,,,,, ,,,,
,13.96,70.00,13.96,70.18,13.96,-0.18,,,,,,,,,,,,,,,,,,,
,14.08,70.00,14.08,71.31,14.08,-1.31,,,,,,,,,,,,,,,,,,,
,14.21,70.00,14.21,70.35,14.21,-0.36,,,,,,,,,,,,,,,,,,,
,14.33,70.00,14.33,70.55,14.33,-0.55,,,,,,,,,,,,,,,,,,,
,14.48,70.00,14.48,70.38,14.48,-0.38,,,,,,,,,,,,,,,,,,,
,14.60,70.00,14.60,68.99,14.60,1.00,,,,,,,,,,,,,,, ,,,,
,14.72,70.00,14.72,70.23,14.72,-0.23,,,,,,,,,,,,,,,,,,,
,14.85,70.00,14.85,69.74,14.85,0.25,,,,,,,,,,,,,,, ,,,,
,14.99,70.00,14.99,70.01,14.99,-0.02,,,,,,,,,,,,,,,,,,,
,15.12,70.00,15.12,68.84,15.12,1.15,,,,,,,,,,,,,,, ,,,,
,15.25,70.28,15.25,69.48,15.25,0.80,,,,,,,,,,,,,,, ,,,,
,15.36,71.61,15.36,72.45,15.36,-0.84,,,,,,,,,,,,,,,,,,,
,15.51,73.77,15.51,73.15,15.51,0.61,,,,,,,,,,,,,,, ,,,,
,15.64,74.48,15.64,74.75,15.64,-0.27,,,,,,,,,,,,,,,,,,,
,15.76,74.83,15.76,73.69,15.76,1.14,,,,,,,,,,,,,,, ,,,,
,15.89,75.16,15.89,75.48,15.89,-0.32,,,,,,,,,,,,,,,,,,,
,16.03,75.22,16.03,76.01,16.03,-0.79,,,,,,,,,,,,,,,,,,,
,16.15,75.19,16.15,75.27,16.15,-0.08,,,,,,,,,,,,,,,,,,,
,16.28,75.12,16.28,74.70,16.28,0.42,,,,,,,,,,,,,,, ,,,,
,16.40,75.06,16.40,75.72,16.40,-0.66,,,,,,,,,,,,,,,,,,,
,16.54,74.98,16.54,74.97,16.54,0.01,,,,,,,,,,,,,,, ,,,,
,16.67,74.90,16.67,75.63,16.67,-0.74,,,,,,,,,,,,,,,,,,,
,16.80,74.84,16.80,74.24,16.80,0.59,,,,,,,,,,,,,,, ,,,,
,16.92,74.76,16.92,74.85,16.92,-0.09,,,,,,,,,,,,,,,,,,,
,17.06,74.68,17.06,74.90,17.06,-0.22,,,,,,,,,,,,,,,,,,,
,17.18,74.58,17.18,74.38,17.18,0.19,,,,,,,,,,,,,,, ,,,,
,17.31,74.44,17.31,75.11,17.31,-0.67,,,,,,,,,,,,,,,,,,,
,17.43,74.34,17.43,73.51,17.43,0.82,,,,,,,,,,,,,,, ,,,,
,17.60,74.19,17.60,74.09,17.60,0.09,,,,,,,,,,,,,,, ,,,,
,17.73,73.99,17.73,73.87,17.73,0.12,,,,,,,,,,,,,,, ,,,,
,17.85,73.78,17.85,74.18,17.85,-0.41,,,,,,,,,,,,,,,,,,,
,17.98,73.56,17.98,73.14,17.98,0.42,,,,,,,,,,,,,,, ,,,,
,18.12,73.32,18.12,73.38,18.12,-0.07,,,,,,,,,,,,,,,,,,,
,18.24,73.08,18.24,72.87,18.24,0.21,,,,,,,,,,,,,,, ,,,,
,18.37,72.77,18.37,73.38,18.37,-0.62,,,,,,,,,,,,,,,,,,,
,18.49,72.49,18.49,72.54,18.49,-0.05,,,,,,,,,,,,,,,,,,,
,18.63,72.17,18.63,71.37,18.63,0.79,,,,,,,,,,,,,,, ,,,,
,18.76,71.87,18.76,71.62,18.76,0.25,,,,,,,,,,,,,,, ,,,,
,18.88,71.58,18.88,71.69,18.88,-0.11,,,,,,,,,,,,,,,,,,,
,19.01,71.32,19.01,71.48,19.01,-0.16,,,,,,,,,,,,,,,,,,,
,19.15,72.04,19.15,72.04,19.15,0.00,,,,,,,,,,,,,,, ,,,,
,19.28,72.09,19.28,72.09,19.28,0.00,,,,,,,,,,,,,,, ,,,,
,19.40,72.05,19.40,72.05,19.40,0.00,,,,,,,,,,,,,,, ,,,,
,19.52,72.09,19.52,72.09,19.52,0.00,,,,,,,,,,,,,,, ,,,,
,19.67,72.11,19.67,72.11,19.67,0.00,,,,,,,,,,,,,,, ,,,,
,19.81,72.14,19.81,72.14,19.81,0.00,,,,,,,,,,,,,,, ,,,,
,19.95,72.17,19.95,72.17,19.95,0.00,,,,,,,,,,,,,,, ,,,,
,20.07,72.16,20.07,72.16,20.07,0.00,,,,,,,,,,,,,,, ,,,,
,20.21,72.17,20.21,72.17,20.21,0.00,,,,,,,,,,,,,,, ,,,,
,20.34,72.17,20.34,72.17,20.34,0.00,,,,,,,,,,,,,,, ,,,,
,20.46,72.22,20.46,72.22,20.46,0.00,,,,,,,,,,,,,,, ,,,,
,20.59,72.22,20.59,72.22,20.59,0.00,,,,,,,,,,,,,,, ,,,,
,20.73,72.17,20.73,72.17,20.73,0.00,,,,,,,,,,,,,,, ,,,,
,20.85,72.24,20.85,72.24,20.85,0.00,,,,,,,,,,,,,,, ,,,,
,20.98,72.21,20.98,72.21,20.98,0.00,,,,,,,,,,,,,,, ,,,,
,21.10,72.29,21.10,72.29,21.10,0.00,,,,,,,,,,,,,,, ,,,,
,21.24,72.21,21.24,72.21,21.24,0.00,,,,,,,,,,,,,,, ,,,,
,21.37,72.24,21.37,72.24,21.37,0.00,,,,,,,,,,,,,,, ,,,,
,21.49,72.29,21.49,72.29,21.49,0.00,,,,,,,,,,,,,,, ,,,,
,21.62,72.29,21.62,72.29,21.62,0.00,,,,,,,,,,,,,,, ,,,,
,21.76,72.32,21.76,72.32,21.76,0.00,,,,,,,,,,,,,,, ,,,,
,21.88,72.31,21.88,72.31,21.88,0.00,,,,,,,,,,,,,,, ,,,,
,22.01,72.32,22.01,72.32,22.01,0.00,,,,,,,,,,,,,,, ,,,,
,22.13,72.38,22.13,72.38,22.13,0.00,,,,,,,,,,,,,,, ,,,,
,22.27,72.35,22.27,72.35,22.27,0.00,,,,,,,,,,,,,,, ,,,,
,22.40,72.38,22.40,72.38,22.40,0.00,,,,,,,,,,,,,,, ,,,,
,22.52,72.41,22.52,72.41,22.52,0.00,,,,,,,,,,,,,,, ,,,,
,22.65,72.41,22.65,72.41,22.65,0.00,,,,,,,,,,,,,,, ,,,,
,22.79,72.38,22.79,72.38,22.79,0.00,,,,,,,,,,,,,,, ,,,,
,22.91,72.41,22.91,72.41,22.91,0.00,,,,,,,,,,,,,,, ,,,,
,23.04,72.41,23.04,72.41,23.04,0.00,,,,,,,,,,,,,,, ,,,,
,23.16,72.41,23.16,72.41,23.16,0.00,,,,,,,,,,,,,,, ,,,,
,23.31,72.43,23.31,72.43,23.31,0.00,,,,,,,,,,,,,,, ,,,,
,23.43,71.14,23.43,70.46,23.43,0.68,,,,,,,,,,,,,,, ,,,,
,23.56,70.68,23.56,70.84,23.56,-0.16,,,,,,,,,,,,,,,,,,,
,23.68,70.36,23.68,71.13,23.68,-0.77,,,,,,,,,,,,,,,,,,,
,23.83,69.88,23.83,70.70,23.83,-0.82,,,,,,,,,,,,,,,,,,,
,23.95,69.54,23.95,69.77,23.95,-0.24,,,,,,,,,,,,,,,,,,,
,24.07,69.20,24.07,69.42,24.07,-0.22,,,,,,,,,,,,,,,,,,,
,24.20,68.89,24.20,69.06,24.20,-0.17,,,,,,,,,,,,,,,,,,,
,24.35,68.49,24.35,68.67,24.35,-0.18,,,,,,,,,,,,,,,,,,,
,24.47,68.20,24.47,68.44,24.47,-0.24,,,,,,,,,,,,,,,,,,,
,24.60,67.93,24.60,67.94,24.60,-0.02,,,,,,,,,,,,,,,,,,,
,24.73,67.59,24.73,67.54,24.73,0.05,,,,,,,,,,,,,,, ,,,,
,24.88,67.23,24.88,67.37,24.88,-0.14,,,,,,,,,,,,,,,,,,,
,24.99,66.41,24.99,68.44,24.99,-2.04,,,,,,,,,,,,,,,,,,,
,25.12,65.50,25.12,68.32,25.12,-2.83,,,,,,,,,,,,,,,,,,,
,25.24,64.59,25.24,67.99,25.24,-3.40,,,,,,,,,,,,,,,,,,,
,25.39,63.40,25.39,66.00,25.39,-2.60,,,,,,,,,,,,,,,,,,,
,25.51,62.46,25.51,64.59,25.51,-2.13,,,,,,,,,,,,,,,,,,,
,25.63,61.45,25.63,61.40,25.63,0.05,,,,,,,,,,,,,,, ,,,,
,25.76,60.45,25.76,60.69,25.76,-0.24,,,,,,,,,,,,,,,,,,,
,25.90,59.30,25.90,59.00,25.90,0.30,,,,,,,,,,,,,,, ,,,,
,26.02,58.28,26.02,58.34,26.02,-0.06,,,,,,,,,,,,,,,,,,,
,26.15,57.02,26.15,56.44,26.15,0.58,,,,,,,,,,,,,,, ,,,,
,26.27,55.87,26.27,55.93,26.27,-0.06,,,,,,,,,,,,,,,,,,,
,26.41,54.56,26.41,54.85,26.41,-0.29,,,,,,,,,,,,,,,,,,,
,26.55,53.42,26.55,54.31,26.55,-0.89,,,,,,,,,,,,,,,,,,,
,26.66,52.29,26.66,53.70,26.66,-1.41,,,,,,,,,,,,,,,,,,,
,26.80,51.13,26.80,51.70,26.80,-0.58,,,,,,,,,,,,,,,,,,,
,26.93,50.68,26.93,46.53,26.93,4.14,,,,,,,,,,,,,,, ,,,,
,27.07,51.56,27.07,49.75,27.07,1.81,,,,,,,,,,,,,,, ,,,,
,27.19,52.57,27.19,50.73,27.19,1.84,,,,,,,,,,,,,,, ,,,,
,27.32,53.66,27.32,51.72,27.32,1.94,,,,,,,,,,,,,,, ,,,,
,27.46,54.98,27.46,53.43,27.46,1.55,,,,,,,,,,,,,,, ,,,,
,27.59,56.15,27.59,55.56,27.59,0.58,,,,,,,,,,,,,,, ,,,,
,27.71,57.34,27.71,57.48,27.71,-0.15,,,,,,,,,,,,,,,,,,,
,27.83,58.17,27.83,59.10,27.83,-0.94,,,,,,,,,,,,,,,,,,,
,27.98,58.62,27.98,58.38,27.98,0.24,,,,,,,,,,,,,,, ,,,,
,28.10,58.97,28.10,58.62,28.10,0.35,,,,,,,,,,,,,,, ,,,,
,28.23,59.20,28.23,59.15,28.23,0.05,,,,,,,,,,,,,,, ,,,,
,28.35,59.37,28.35,58.92,28.35,0.45,,,,,,,,,,,,,,, ,,,,
,28.50,59.59,28.50,59.15,28.50,0.43,,,,,,,,,,,,,,, ,,,,
,28.62,59.78,28.62,59.60,28.62,0.17,,,,,,,,,,,,,,, ,,,,
,28.74,60.14,28.74,59.73,28.74,0.40,,,,,,,,,,,,,,, ,,,,
,28.87,61.24,28.87,60.83,28.87,0.41,,,,,,,,,,,,,,, ,,,,
,29.01,62.70,29.01,64.56,29.01,-1.87,,,,,,,,,,,,,,,,,,,
,29.13,64.01,29.13,64.05,29.13,-0.05,,,,,,,,,,,,,,,,,,,
,29.26,65.64,29.26,64.53,29.26,1.10,,,,,,,,,,,,,,, ,,,,
,29.38,67.07,29.38,66.27,29.38,0.79,,,,,,,,,,,,,,, ,,,,
,29.53,68.79,29.53,68.11,29.53,0.68,,,,,,,,,,,,,,, ,,,,
,29.65,70.29,29.65,70.01,29.65,0.27,,,,,,,,,,,,,,, ,,,,
,29.77,71.79,29.77,72.48,29.77,-0.70,,,,,,,,,,,,,,,,,,,
,29.90,73.52,29.90,73.31,29.90,0.21,,,,,,,,,,,,,,, ,,,,
,30.05,75.17,30.05,75.95,30.05,-0.78,,,,,,,,,,,,,,,,,,,
,30.18,76.70,30.18,75.83,30.18,0.86,,,,,,,,,,,,,,, ,,,,
,30.31,77.80,30.31,77.93,30.31,-0.13,,,,,,,,,,,,,,,,,,,
,30.43,78.68,30.43,79.70,30.43,-1.02,,,,,,,,,,,,,,,,,,,
,30.58,79.38,30.58,78.12,30.58,1.26,,,,,,,,,,,,,,, ,,,,
,30.71,79.92,30.71,76.09,30.71,3.83,,,,,,,,,,,,,,, ,,,,
,30.83,80.52,30.83,74.04,30.83,6.47,,,,,,,,,,,,,,, ,,,,
,30.96,81.26,30.96,76.80,30.96,4.46,,,,,,,,,,,,,,, ,,,,
,31.10,82.00,31.10,79.10,31.10,2.89,,,,,,,,,,,,,,, ,,,,
,31.23,82.62,31.23,81.83,31.23,0.79,,,,,,,,,,,,,,, ,,,,
,31.35,83.27,31.35,85.02,31.35,-1.76,,,,,,,,,,,,,,,,,,,
,31.48,84.03,31.48,86.10,31.48,-2.07,,,,,,,,,,,,,,,,,,,
,31.62,84.91,31.62,85.29,31.62,-0.38,,,,,,,,,,,,,,,,,,,
,31.74,85.81,31.74,86.08,31.74,-0.27,,,,,,,,,,,,,,,,,,,
,31.87,86.60,31.87,86.02,31.87,0.58,,,,,,,,,,,,,,, ,,,,
,32.00,87.43,32.00,88.37,32.00,-0.94,,,,,,,,,,,,,,,,,,,
,32.13,88.42,32.13,87.88,32.13,0.54,,,,,,,,,,,,,,, ,,,,
,32.26,89.30,32.26,89.74,32.26,-0.44,,,,,,,,,,,,,,,,,,,
,32.38,90.21,32.38,89.45,32.38,0.76,,,,,,,,,,,,,,, ,,,,
,32.51,91.14,32.51,90.68,32.51,0.46,,,,,,,,,,,,,,, ,,,,
,32.65,92.09,32.65,92.06,32.65,0.03,,,,,,,,,,,,,,, ,,,,
,32.77,93.06,32.77,92.23,32.77,0.83,,,,,,,,,,,,,,, ,,,,
,32.90,94.07,32.90,93.71,32.90,0.36,,,,,,,,,,,,,,, ,,,,
,33.02,95.11,33.02,94.59,33.02,0.52,,,,,,,,,,,,,,, ,,,,
,33.16,96.04,33.16,96.16,33.16,-0.13,,,,,,,,,,,,,,,,,,,
,33.30,96.84,33.30,96.24,33.30,0.60,,,,,,,,,,,,,,, ,,,,
,33.41,97.52,33.41,96.35,33.41,1.17,,,,,,,,,,,,,,, ,,,,
,33.55,98.16,33.55,97.94,33.55,0.22,,,,,,,,,,,,,,, ,,,,
,33.68,98.81,33.68,100.53,33.68,-1.72,,,,,,,,,,,,,,,,,,,
,33.82,99.48,33.82,99.23,33.82,0.25,,,,,,,,,,,,,,, ,,,,
,33.94,100.07,33.94,100.91,33.94,-0.84,,,,,,,,,,,,,,,,,,,
,34.07,100.65,34.07,102.94,34.07,-2.29,,,,,,,,,,,,,,,,,,,
,34.21,101.33,34.21,101.72,34.21,-0.39,,,,,,,,,,,,,,,,,,,
,34.33,101.91,34.33,103.02,34.33,-1.11,,,,,,,,,,,,,,,,,,,
,34.46,102.58,34.46,103.10,34.46,-0.52,,,,,,,,,,,,,,,,,,,
,34.59,103.18,34.59,101.46,34.59,1.71,,,,,,,,,,,,, ,,,,,,
,34.73,104.05,34.73,104.31,34.73,-0.27,,,,,,,,,,,,,,,,,,,
,34.85,105.24,34.85,107.26,34.85,-2.02,,,,,,,,,,,,,,,,,,,
,34.98,106.66,34.98,108.06,34.98,-1.41,,,,,,,,,,,,,,,,,,,
,35.10,108.35,35.10,109.61,35.10,-1.26,,,,,,,,,,,,,,,,,,,
,35.25,109.21,35.25,110.75,35.25,-1.55,,,,,,,,,,,,,,,,,,,
,35.37,109.57,35.37,110.55,35.37,-0.98,,,,,,,,,,,,,,,,,,,
,35.49,109.77,35.49,109.15,35.49,0.62,,,,,,,,,,,,, ,,,,,,
,35.62,109.87,35.62,110.29,35.62,-0.42,,,,,,,,,,,,,,,,,,,
,35.76,109.94,35.76,111.88,35.76,-1.94,,,,,,,,,,,,,,,,,,,
,35.88,109.96,35.88,110.14,35.88,-0.18,,,,,,,,,,,,,,,,,,,
,36.01,109.98,36.01,109.67,36.01,0.30,,,,,,,,,,,,, ,,,,,,
,36.13,109.98,36.13,107.23,36.13,2.75,,,,,,,,,,,,, ,,,,,,
,36.27,109.99,36.27,109.05,36.27,0.94,,,,,,,,,,,,, ,,,,,,
,36.40,109.99,36.40,109.12,36.40,0.87,,,,,,,,,,,,, ,,,,,,
,36.52,109.99,36.52,107.41,36.52,2.58,,,,,,,,,,,,, ,,,,,,
,36.65,109.99,36.65,108.20,36.65,1.79,,,,,,,,,,,,, ,,,,,,
,36.79,109.99,36.79,109.40,36.79,0.59,,,,,,,,,,,,, ,,,,,,
,36.91,109.99,36.91,110.75,36.91,-0.76,,,,,,,,,,,,,,,,,,,
