It has been a month since I had my check engine light go off and I can't seem to figure out what's going on?
Symptoms: Rough Idle, some loss in power but not very noticeable, also has turned off when slowing down (clutch in) and reaching 600 rpms then turns off, I feel it's using more gas than usual
What I've done: changed sparks plugs and coils since I wasn't sure when the last person that owned the car did. Also check and found a pcv hose with a small crack in it (changed it), reset codes, all the same codes came back.
Codes:
Trouble codes:
P1297 - Connection charger-throttle valve Pressure drop Upper limit exceeded
static
P2279 - Intake Air System Leak Lower limit not reached
static
P0300 - Random/Multiple Cylinder Misfire Detected Implausible signal
Intermittent
P0302 - Cyl.2 Misfire Detected Implausible signal
Intermittent
P0480 - Cooling Fan 1 Control Circuit Implausible signal
Intermittent
P0691 - Cooling Fan 1 Control Circuit Low Lower limit not reached
Intermittent
P0299 - Turbo/Super Charger Underboost Lower limit not reached
static
P0011 - A Camshaft Position (Bank1) Timing over-advanced or System Performance No signal/communication
Intermittent
P0303 - Cyl.3 Misfire Detected Implausible signal
Intermittent
Any advice from experts or someone that has had a similar issue would be appreciated. Thank you!
