Results 1 to 3 of 3
    Dec 12 2010
    Squeaky suspension/steering
    So my 2003 S6 has developed quite the loud squeak. It mainly occurs after having driven a few miles, and mainly while turning left (although a bit while turning to the right as well). It also can make a little noise when entering or exiting the vehicle. I'm assuming outer tie rods? Anyone think I should replace inners as well? I'll prob replace UCA's while I'm in there. Not sure if my lowers are still good, as I have 15 yrs and 130K on her...
    Veteran Member Four Rings PaperToast's Avatar
    Apr 29 2009
    Quadzilla
    Longmont, CO
    sounds like your on the right track with replacing all the c-arms, especially with the miles
    if the inner rods don't have play, leave 'em alone
    your squeak is prolly from on the of the upper arm bushings
    Rockin' the Rockies
    '01 allroad, 250k woot woot, still boosting on original turbos and tippy, slightly modified. . .
    Scotty@Advanced, "Push it off a cliff, when it hits the ground you should have a few thousand horsepower available for a brief second."
    Dec 12 2010
    Quote Originally Posted by PaperToast View Post
    Thanks for the input Papertoast. I've ordered outer tie rods and UCAs, I'll be sure to check the inners for play while Im in there.
