Hey guys,
I've made a little progress on my sound deadening project. Specifically, I've "wrapped" my passenger wheel well with CCF stuck to MLV. MLV faces out; CCF faces existing, stock foam padding. Ultimately, I used (6) pieces of the combined CCF/MLV. Two approximately triangular shaped pieces reach up into the "outside portion of the wheel well. The first is narrow and reaches nearly to the point where the fuel door attaches. It is stuck at the top to the metal via velcro. The next piece overlaps a portion of the first one, but extends downward toward the fuse box area. That pice has velcro, and it is connected to another piece that straddles the divide between sides of the wheel well. It is also connected to a piece on the interior side of the wheel well. I have one large piece on the interior side of the wheel well and two stacked somewhat similar to the way in which I stacked the outside pieces.
Take a look and offer any comments - good, bad....etc.
Also, note that with summer tires, my avg. dB measurements have declined slightly (just less than 1 dB - from 62.4 to 61.5). That said, I have also placed MLV over the carpet in the trunk and I have stuffed HMF into the holes on the bottom side of the speaker deck and into the void behind the passenger seat side bolster (which has almost zero insulation/deadening material).
My general observations are that (1) the "wind" noise from the rear is much less discernible, making the project worth the time I've invested and that (2) I can now hear my engine and front tires more than I previously could. Go figure; I'm not focused on that noise from the rear.
Next, I'll remove the speaker deck and properly finished it with a combination of CLD (Dynamat Extreme), HMF, CCF and, where appropriate, MLV. I'll also do the driver side wheel well and rear seat side bolster. It will be interested to see if I get another dB in noise reduction with that -- somehow, I'd bet I'll see diminishing returns, however.
Once this nonsense is done, the sub will go in.
