Results 1 to 10 of 10
Thread: Fuel problem
    Established Member Two Rings ava the a4's Avatar
    Mar 13 2018
    Newport News, Virginia
    Fuel problem
    Car starts, idles for a second or two and cuts off. Happens every once in a while, but not often. I’ve had it looked at and it’s been narrowed down to a fuel pump or something in the lobe. Also throws fuel regulator code but I’ve been told by a mechanic that’s not it. If anyone has any input i’d love to hear it.
    Veteran Member Three Rings Low and Behold's Avatar
    Feb 21 2015
    Rip City
    Better pull that HPFP/follower first and have a look. Start there
    Casey | @cshore | B7 A4 Avant 2.0T | B8 Q5 2.0T
    Mar 01 2016
    San Diego/CA
    What is the exact code you are getting? How many miles on the car?
    Mar 13 2018
    125k miles, don’t remember exact codes though.
    Dec 05 2016
    miami FL
    u check ur cam follower?
    Mar 13 2018
    Quote Originally Posted by ahotboy15 View Post
    A mechanic did mention something about it could be a cam but they wanted another 1000 to test before the cost of repairs. Wanted to see what i could look for on my own first.
    Dec 05 2016
    miami FL
    Cam follower not camshaft. Someone pls explain. You could have major thing going on
    Mar 13 2018
    Quote Originally Posted by hemantpd1 View Post
    Dec 05 2016
    miami FL
    did you have someone check the wear on your cam follower?
    Mar 01 2016
    San Diego/CA
    Looks like you have multiple issues:
    For P0089, your first step should be to check the cam follower. Here is the DIY: https://www.youtube.com/watch?v=2jCzoQcDEkQ
    For P0442, P0445, Check if the gas cap is loose or you can replace it.
    For P2181, while driving you are on a freeway if the engine temperature indicator needle is dangling towards left side from the middle, then your thermostat is bad. DIY: https://www.audizine.com/forum/showt...lacement-(DIY)
