Results 1 to 8 of 8
Thread: Bleeding brakes
    Feb 15 2018
    Sioux Falls/SD
    Bleeding brakes
    I just redid all my brakes (braided lines, caliper rebuild kits,etc) I've bled the brakes out 3 times and they still feel mushy. I also hooked it to vag and cycled the ABS and no change. Anyone fought 4th is battle and won?
    Mar 11 2008
    B7RS4 & e46Ms
    Power bleeder?
    FRRG AZ Ring
    Veteran Member Three Rings JayDog747's Avatar
    Mar 10 2010
    2007 S4,2015 Silverado,2023 WRX
    WI
    When changing over to the braids, did you plug up the lines or did the reservoir/master cylinder run dry?
    Feb 15 2018
    Sioux Falls/SD
    Quote Originally Posted by JayDog747 View Post
    The whole system was bled using a power bleeder.
    Nov 08 2017
    PHX
    Did you bleed the inside and outside of the front calipers? There are two separate bleeders.
    Dec 05 2006
    So. Cal.
    Are you r calipers on the correct side of the car? Nipples up high.
    Mar 11 2008
    B7RS4 & e46Ms
    Start from the farthest caliper out and work in. On the fronts do the inside bleeder first, tap the calipers with a dead-blow mallet to loosen any trapped air bubbles, and if you ran the system dry you may need to cycle the abs module a few times to get all the air out.
    FRRG AZ Ring
    Account Terminated Four Rings
    Dec 03 2009
    PNW, Washington
    Get the inside nipple on the fronts? I’ve seen a few guys miss that one thinking there’s only one on those calipers.
