Supreme Power | P3 Gauges
RS3 8V OBD Multi Gauge & Analog Boost Gauge
**Pictures are from other 8V platform models but fit the RS3 8V Sedan & Sportback. The part included is in the first 2 pictures, it directly replaces the same section in the RS3 vent.**
Audi 8V - P3 OBD2 Multi-Gauge
SKU:UvP3A8VX
-Plug and Play install - just plug into your obd2 port and install into dash!
-Reads and clears OBD2 Codes
-OBD2 Data for Coolant Temp, Intake Air Temp, Exhaust Gas Temp, Throttle Plate, Vehicle Speed, RPM, Shift-light, Battery voltage, 0-60 timer
-Peak Recall on all functions
-Boost and Vacuum from OBD2 port (To read higher than 22.5 psi boost the analog sensor must be used)
-Optional 80 psi analog boost sensor
-Optional Auto-Dim or Manual dimmer
-2 x universal 0-5v linear analog inputs
-Includes digital display, custom OBD2 wire harness and control box
Track Pack software upgrade (GAS ENGINES ONLY)
-Adds Air/Fuel ratio through the OBD2 port
-Adds 0-100/60-130/60-0/100-0 timers
Optional 80psi boost sensor
-Allows gauge to read boost directly from intake/charge pipe
-Plugs directly into the OBD2 harness (no wiring required)
-Can be added/removed from the gauge at any time
-Required to read boost higher than 22.5psi
P3 Gauges offer a Multifunction gauge that gives you the information you need while maintaining a clean, OEM look. Starting at a price competitive to single feature old-school needle gauges, they offer unmatched feature to price ratio.
All Multi-Gauges include an on-the-fly configuration menu for setting units (BAR/PSI, Farenheit/Celsius MPH/KPH), Shift light, analog boost sensor calibration and more. See www.p3gauges.com/install for more details.
P3 Multi Gauge: $399
Add Track Pack: +$25
Add Analog Boost Sensor: +30
Audi 8V - P3 Boost Gauge
SKU:UbP3A8VX
-Hard-wires in to power and ground and requires analog tubing to be run and connected to intake / charge pipe (does not plug into OBD2 port)
-Boost and vacuum with peak recall
-Battery voltage readout and quick-check even when the vehicle is shut off
-Manual dimmer with optional auto-dim feature
-Can be configured for both constant power and switched power installations
-Includes digital display, power supply unit (with integrated 80psi analog boost sensor), vacuum tubing, wiring harness and related hardware (does not include boost tap)
P3 Boost Gauge: $239
Shoot me an email with any questions or to order: [email protected]
