I was wondering is any engine gurus out there can help me out. Im replacing the intake camshaft and nicked the timing. Totally forgot to mark the cams before removing. Is the exhaust lobe of cylinder #3 timed exactly the same as the intake lobe of cylinder #1? This is when cylinders #1 and #3 are at TDC.
So based off my knowledge of engine theory, when piston #1 is TDC on intake stroke, the #3 piston is on BDC on exhaust stroke. My questions is: when the intake camshaft is starting to press the valve however many degrees before TDC on cylinder #1, is the exhaust valve on lobe on cylinder #3 pressing the valve down exactly at the same time? Or should it be one tooth on the sprocket back, or forward?
