So I am going to try the below hacks on my Audi S4 P+. I should have the car in accessory mode when doing these changes, and then start the car, correct?
Also, has anyone every tried to have the map in the 7inch infotainment system? I don't have the virtual cockpit, and want to get the maps there if possible with obdeleven.
Needle sweep -
I tried the 'Needle Sweep' from the Q7 forums as well and it works.
-Module 17 (Instruments)
-Long Coding
-Byte 1
-Bit 0
High Beams -
Central Electronics (09) -> Coding -> high_beam_functions -> head_light_assistant
Front Sensor Driver Assistance System (A5) -> Coding -> AFS_coding_Light_Assist -> High_Beam_Assist
Central Electronics (09) -> Coding -> mmi_fla_glw_mxb -> active
Active Lane Assist –
UPDATE:
Security codes:
A5- 20103
ALL Coding:
A5 - Frt Sens. Drv. Assist
HC>Active Byte 16>Bit 7
EFP>Active Byte 12>Bit 3
17 - Dash Board EDIT:
Lane Assistant>Active Byte 4>Bit 6
Lane Change Assistant>Active Byte 5>Bit 3 - This should only be on if you have Audi Side Assist (blind spot monitor).
09 - Central Electrics
Heading Control Config>heading_control Byte 35>Bit 0
44 - Steering Assistance
Heading Control Assistant>Active Byte 2>Bit 7
ALL ADAPTATIONS:
5F - Information Electronics
Car_Function_Adaptations_Gen2>menu_display_Lane_De parture_Warning = Set Value to “Activated”
Car_Function_Adaptations_Gen2>menu_display_Lane_De parture_Warning_over_threshold_high = Set Value to “Activated”
Car_Function_List_BAP_Gen2>LDW_HCA_0x19> Set Value to “Activated”
Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus> Set Value to “Terminal 15”
BAP Personalization = Set Value to “Not Activated”
Personalization of lane dept. warning Cl. 15 on = Set value to “Last Setting”
System mode, lane depart. warn, = Set Value to “Selection via menu”
Switch-on condition, lane depart. warn. = Set value to “On” (I had to toggle this as this is the final step that I believe mimics pressing the button to actually activate it. You know it was successful when the Lane markings show up in the VC)
You can tweak the vibration intensity, warning time, and steering effort in these A5 adaptations:
UPDATE
Directional stabilization assist driver inact deactiv threshold (3 options)
Directional stab. assist.: intensity: steering wheel vibration (3 options)
Directional stab. assist.: intensity: power steering support (3 options)
