Results 1 to 17 of 17
Thread: RS4 parts
    Account Terminated Four Rings
    Apr 30 2017
    RS4 parts
    RS4 instrument cluster (good upgrade for A4, has factory oil temp readout that displays on the bottom of the DIS, gloss black gauge trim, factory lap timer, higher rpm readout good for those with built motors and high rev range)
    RS4 rear ash tray (some damage see pics)
    $100 shipped
    Auto dimming rear view mirror
    $75 shipped
    Auto headlight switch
    $75 shipped
    Senior Member Three Rings Bob Marley's Avatar
    Jan 18 2016
    Queens NY
    What would be needed to get the cluster to work with my b6 s4? It would trigger Immoblizer no?
    Sent from my SM-N950U using Tapatalk
    Jan 19 2015
    Columbus%2C%20OH
    Those rotors new?
    Veteran Member Four Rings q_dubz's Avatar
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    Quote Originally Posted by Bob Marley View Post
    yes
    - - - Updated - - -
    Quote Originally Posted by gabriel.b View Post
    Those rotors new?
    seeing as it says.... 33.5mm thick vs 34mm being new......then the fact you can see it's been mounted....and there's pad wiping on them..... no lol
    Veteran Member Three Rings barbear1978's Avatar
    Jul 07 2016
    'murrca
    Just confirming rotors are OEM, correct?
    CURRENT: 24 A5 Sportback nbm (wife) - 21 RS6 Avant TE nbp - 17 VW Mk7 GTI sport nbm - 93 Civic 5-speed mr
    GONE: 10 R8 V10 sbp - 20 SQ5 mb - 08 RS4 ti sbp - 17 Sienna SE sw - 15 Macan S sbp - 15 S4 dgp - 08 .:R32 dbp
    Apr 30 2017
    Just needs to be cloned, I recommend http://www.speedosolutions.com/Audi-...vice_p_25.html
    Quote Originally Posted by barbear1978 View Post
    Yes, correct.
    Veteran Member Three Rings theguysinger's Avatar
    Nov 25 2017
    Ephrata, PA
    Does the mirror also have the compass?
    Apr 30 2017
    Quote Originally Posted by theguysinger View Post
    I believe all auto dimming B7 mirrors also have the compass, I could be wrong.
    Established Member Two Rings IbisRS4's Avatar
    May 10 2009
    RS4
    Do you have the rear trunk trim? The Aluminum coloured piece?
    Apr 30 2017
    Quote Originally Posted by IbisRS4 View Post
    Only have what is listed here, sorry.
    Apr 30 2017
    bump
    Apr 30 2017
    bump
    Veteran Member Four Rings dsgray16's Avatar
    Jun 11 2013
    Quote Originally Posted by funkypterodacty View Post
    Yes, correct.
    It should be noted that there are different immobilizer versions and that matching version clusters to ECU/Ignition is clone-able, but if they don’t match, they won’t talk. Ran into this issues with my RS4 swap. Just a heads up.
    Events: Time to register for Avantoberfest 2018!: www.avantoberfest.com
    Instagram: Audisport_Wagon
    Cars: Full B7 RS4 Avant swap http://www.audizine.com/forum/showth...S4-Avant-Build
    B7 RS4 sedan in Phantom Black - just a clean OEM+ daily driver
    Senior Member Three Rings k909068's Avatar
    Jul 21 2013
    The First State
    Quote Originally Posted by dsgray16 View Post
    Exactly, I’m sure the RS4 cluster has no way to pair any B6.
    Veteran Member Three Rings caliizaktiv's Avatar
    Dec 20 2010
    Used Oil
    East Coast
    those rotors are smoked...
    07 RS4 | 03 M5 | 24 RS6p
    May 01 2014
    99 vw golf waiting to have an 02 s4 motor put in it
    newburgh, ny
    Is the mirror still available for sale?
    Oct 16 2014
    are the rotors sold?
