Hi all,
So this morning it was raining pretty heavily and once i got off the highway after about a 30 mile highway commute, i noticed my windows start to fog up. I thought "thats weird, they usually don't do that" but didn't think much of it, parked the car and went into work. Come out of work (it is now 70 and sunny) jump in the car and get back on the highway. I look down and notice the AC button is off, and it will not stay on, so no cold air blowing from the vents. I get home check the codes with vagcom (please see below), and find a couple of weird faults that all seemed to happen around the same time. I cleared them and will see if they come back, but i'm curious if anyone had any insight or advice. I am still covered under Audi CPO warranty, should i get it looked at?
Edit: The AC did come back on once i got back into my driveway. I turned the car off and back on, that did not solve the issue. Turned the car back off, hooked up vagcom, scanned, turned car off. Turned car back on, and AC was back to normal, even before i cleared the codes.
Thursday,26,April,2018,16:47:12:62909
VCDS Version: Release 18.2.0 (x64) Running on Windows 10 x64
www.Ross-Tech.com
Address 08: Auto HVAC Labels: Redir Fail!
Control Module Part Number: 8K1 820 043 T HW: 8K1 820 043 T
Component and/or Version: KLIMA 3 ZONEN H04 0121
Software Coding: 6600228000
Work Shop Code: WSC 06325 000 00000
VCID: 392C2477A956C91F756-806C
2 Faults Found:
01592 - Air Quality Sensor (G238)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 229
Mileage: 124652 km
Time Indication: 0
Date: 2018.04.24
Time: 06:55:47
Freeze Frame:
Temperature: 7.0°C
00256 - A/C Pressure/Temperature Sensor (G395)
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 235
Mileage: 124721 km
Time Indication: 0
Date: 2018.04.25
Time: 07:04:32
Freeze Frame:
Temperature: 15.0°C
Temperature: 73.0°C
Load: 0.0 %
Absolute Pres.: 0.6 bar
RPM: 1200 /min
Speed: 0.0 km/h
Current: 0.000 A
Temperature: 27.0°C
Thursday,26,April,2018,16:47:48:62909
www.Ross-Tech.com
Address 09: Cent. Elect. Labels: 8K0-907-063.clb
Control Module Part Number: 8K0 907 063 DH HW: 8K0 907 063 DH
Component and/or Version: BCM1 1.0 H16 0103
Software Coding: 26000091803CAFE0210040C300003D0D0F9CD308A209022100 0008004000030100000030000000
VCID: 78AAE173D2DC10174A8-802C
1 Fault Found:
03020 - Local databus 2
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 229
Mileage: 124652 km
Time Indication: 0
Date: 2018.04.24
Time: 06:54:46
