    May 22 2012
    FAIRBANKS/AK/USA
    16805 - Warm Up Catalyst
    did a VAG scan.
    what is this and what is the fix? it is keeping my MIL on.
    16805 - Warm Up Catalyst; Bank 1
    P0421 - 001 - Efficiency Below Threshold - MIL ON
    I'm getting the code on both banks.
    2002 A4 3.0 MT
    Veteran Member Three Rings my_RS4's Avatar
    Apr 15 2016
    Beach Cruiser
    Venice
    Subscribed.. I've been getting this code on Bank 1. I clear it and it comes back next day. Clear it again, and it comes back a week later..
    Clear again, comes back 3 weeks later. Sometimes it goes away by itself. I def ain't buying a new catalytic converter for this car. Is there any way to solve this cheaply?
    O2 sensor spacers?? I dunno...
    IG @myRS4 | 2007 RS4 | Phantom Black | Ti Converted | Milltek'ed | KW H.A.S. kitted | Rotiformed (SPF DDT 19X10 +25) | PSSed 275/30/19 | LED DRL'ed + Citied + CC'd | H&R wheel spaced | 034 Density Line control armed | Hotchkis F + R Sway Barred | Apikol rear-diff mounted | JHM Lighweight Flywheeled | Ziza lit | Passport 9500ix hardwired | Dension Pro BT'ed | StopTech Brake Padded
    Jan 24 2010
    Paramus,NJ USA
    Replace catalytic converter(s).Unless you have 02 sensor faults that could throw the reading off.But you need to check which fault code sets first. 3.0 liter engine are known for having cats expire.Not so common on 1.8T's.
    Ziddy Autowerks
    Veteran Member Four Rings imnuts's Avatar
    Aug 12 2009
    '21 F-150 Powerboost Lariat & '14 Acura RDX
    Dirty Jerz
    Spacers on the rear O2 sensors can get rid of the codes as well, but doesn't fix the issue. Some ECU tunes also coffee this out, but you may or may not pass inspection depending on what your state checks and what tune you use.
    Sent from my Pixel 2 XL
    May 17 2018
    Garner nc
    How can you know if the time is right or what kind of replacements do you make with the bad cats?
