    Established Member Two Rings S3owner's Avatar
    Jun 16 2016
    Ontario
    What is this noise?
    Its been a few days that I hear kind of a weird noise when I turn the steering wheel. It only happens when it is approaching its max turn radius. Any idea what could it be?
    Here is a short video: https://drive.google.com/file/d/1hKN...w?usp=drivesdk
    Missano Red II S3 Quattro 2.0T - H&R Sport Springs - Spacers 10mm/17.5mm - Sound Enhancing Resonator Delete - USmillWorks tow hook bracket - Pinalloy carbon key fob cover - Carbon Fiber mirror caps - matte black diffuser
    Instagram
    Veteran Member Three Rings INYAUDI's Avatar
    Feb 21 2016
    Southern New Hampshire
    In this order check
    your front strut towers for loose/missing bolts
    Front suspension for same
    Cv axles, torn or damaged rubber boot
    Sounds like a loose strut mount from experience. My friend sheared a strut tower bolt on our friends wrx when I was installing coilovers. Did same sound and at full lock only.
    Instagram: TonyConQuattro
    Jun 16 2016
    Ontario
    I re-torqued the strut tower bolts and CV axel seems intact. Could it be the spring not seating correctly in position? or just the top bearing/bushings need some lubrication...
    ( the creaking noise only happens when I turn full left)
    Instagram
    Feb 21 2016
    Quote Originally Posted by S3owner View Post
    Could be either of those as well. Would imagine if the bearings are going bad that it’d be a more frequent noise. I know the viewing angle might be near impossible (maybe record with phone) and see if the spring moved from it’s original indentation.
    Feb 21 2016
    Figure I should mention, inspect your suspension components for any marks that may hint to interferences. Endlink or tierod play/bends comes to mind.
