Hello Everyone,
I am an owner of a 2012 Audi A5 2.0T Quattro which I've purchased 8K miles ago currently sitting at 60K miles. Yesterday on my way home from work, CEL decided to appear on the dash with the warning "Shut Off Engine! Oil Pressure Too Low". I plugged in my Carista and the codes are as follows:
P0507 - Idle Air Control System RPM Higher than Expected
P2279 - Intake Air System Leak
P2187 - System Too Lean at Idle bank 1
I then proceeded to reset the codes then fire up my car and the car was juddering. Shortly after, another code appeared on top of the previously mentioned codes..
P0300 - Random/Multiple Cylinder Misfire Detected(Cylinders 1 and 2)
Can you guys kindly advise on where or how should I even begin to address these issues as I am not too familiar with these German vehicles.
Any help is greatly appreciated. Thank you all in advance!
