So 6 months ago my car wouldn’t start when the engine was hot. Turned out to be the crank position sensor. 2 months ago I had the exact same problem so I swapped the cps out again which solved the issue. Now just today my car wouldn’t start after sitting overnight. With a cold engine it shows the same symptoms as before. Cranks strong but never shows signs of wanting to start. Is this the cranks sensor again!!!?? Maybe the coolant temp sensor?? I’m getting so fed up with this car I’m afraid of driving it anywhere now and then not being able to start it again.. I have vag com is there something I can look at on the measuring blocks?
