Results 1 to 20 of 20
    Oct 02 2006
    Wadsworth,OH
    NEW NEW NEW B8 S4 Supercharger Magnetic Drain/Fill Plug
    Interested in simple, effective, & affordable protection? This ECS Tuning Supercharger Magnetic Drain/Fill Plug attracts and holds small ferrous metal particles within the supercharger oil to prevent wear.
    Click HERE for your ECS Audi 3.0T Supercharger Oil Magnetic Drain/Fill Plug
    ECS Tuning's Magnetic Plugs are engineered in-house for a perfect fit and feature a permanent magnet fastened to the plug body.
    The press-fit magnet holds minute abrasive particles, preventing their circulation through the supercharger lubrication system to aid in improved longevity.
    Wondering how to install? Don't worry we've got you covered! Click HERE to view our in-depth install guide.*
    Relieve worry and prevent excessive wear with ECS Tuning's Magnetic Plugs.
    Click HERE for your Audi 4M Q7 Quattro 3.0T ('2017+) ECS Supercharger Oil Magnetic Drain/Fill Plug Upgrade
    Click HERE for your Audi A7 C7 3.0T ('2011+) ECS Supercharger Oil Magnetic Drain/Fill Plug Upgrade
    Click HERE for your Audi B8 S4 Quattro 3.0T ('2010 - '2018) ECS Supercharger Oil Magnetic Drain/Fill Plug Upgrade
    Click HERE for your Audi B8 S5 Quattro 3.0T Cabriolet ('2008 - '2018) ECS Supercharger Oil Magnetic Drain/Fill Plug Upgrade
    Click HERE for your Audi B8 S5 Quattro 3.0T Coupe ('2008 - '2018) ECS Supercharger Oil Magnetic Drain/Fill Plug Upgrade
    Click HERE for your Audi C7 A6 FWD V6 3.0T ('2012+) ECS Supercharger Oil Magnetic Drain/Fill Plug Upgrade
    Click HERE for your Audi C7 A6 Quattro V6 3.0T ('2012+) ECS Supercharger Oil Magnetic Drain/Fill Plug Upgrade
    Click HERE for your Audi D4 A8 Quattro 3.0T ('2011+) ECS Supercharger Oil Magnetic Drain/Fill Plug Upgrade
    Click HERE for your Audi Q5 3.0T ('2009 - '2017) ECS Supercharger Oil Magnetic Drain/Fill Plug Upgrade
    Click HERE for your Audi Q7 3.0T ('2017+) ECS Supercharger Oil Magnetic Drain/Fill Plug Upgrade
    Click HERE for your Audi SQ5 3.0T ('2013+) ECS Supercharger Oil Magnetic Drain/Fill Plug Upgrade
    Veteran Member Four Rings maty360414's Avatar
    Oct 13 2015
    SoFlo
    i never knew the oil on the S/C needed to be replaced
    '13 S4 | EPL DP E40 | EPL TCU | AEM W/M | Tampa Ported S/C | 75mm TB | JHM 187 | MercRacing HX/Divorced | Becker TestPipes | AutoTech HPFP | Roc Euro Intake | BFI Engine Mounts | ECS Trans Mount | ECS F/R Diff Mount | H&R Super Sport Springs | 034 Rear Sway Bar | CR-15 | Drilled & Slotted Rotors | StopTech SS | Vertini RF 1.3 | Indy 500 | Sport Diff | BFI Shift Knob | Quattro Grill | ECS Spoiler/Diffuser | RS4 Bumper | J-Code | CWA100 |
    Veteran Member Four Rings kjeeper10's Avatar
    Dec 07 2017
    2007 Jeep Wrangler JK
    Quote Originally Posted by maty360414 View Post
    Agree
    2015 Daytona S5 - Madico Ceramic Tint 35/20 - 6 Speed - Mods - Sprintbooster V3 - APR Stage II - Dual Pulley - CPS Cooler - Eurocode ST Shifter - EuroImpulse weighted knob - USP SS Clutch Line - 034 SD Engine Mounts - 034 Trans Mount Insert - 034 rear SB - CR-15 - ORT Coilovers - SPC Front CA’s - IE Non Res Downpipes - AWE touring w/ 102 tips - CTS intake - ECS Streat Shield - Deval CF Splwitter/Rear Valance - Signature SV901 Forged 19x10.5 wheels - 275/35 Mich PS4S Tires.
    Apr 05 2016
    Portland, OR
    Oil is lifetime per Audi.
    I wouldn't trust that though. I had mine changed out with the new blower at 50k.
    Geoff
    Nov 28 2015
    Montreal, QC
    I though they were more gasket needed for a full services no ??
    S4 B8.5 no track, just enjoying spirited driving.
    Apr 05 2016
    Portland, OR
    Quote Originally Posted by waxxonMTL View Post
    The service kit is right.
    6 upper intake manifold gaskets
    2 for the PCV tube
    Geoff
    Veteran Member Four Rings Gberg888's Avatar
    Jun 16 2011
    996tt
    MA
    How do you fill the SC back up??
    Garage:
    04 996TT X50, 06 Boxster S, 88 911 Targa, 16 S3
    Veteran Member Three Rings wangshuo1989's Avatar
    Jan 09 2016
    Quote Originally Posted by Gberg888 View Post
    You need a pump to pump back the oil
    2013 S5 Misano Red, DSG, B&O, Sport Diff, MMI+, JHM 207mm crank pulley (7PK1370 Contitech belt), APR Stage II Dual Pulley, APR TCU tune, APR CPS, CR15, IE CAI
    2018 XC90 Inscription, B&W sound, Convenience Pkg, Air suspension
    2014 Mercedes E350 rwd
    2021 BMW 540i
    Jan 09 2016
    Great job on designing this and writing up the instruction
    2021 BMW 540i
    Jun 16 2011
    996tt
    MA
    No wonder its a life time oil... the fucking SC has to come off to do it right...
    Garage:
    Mar 21 2015
    ECS should've came out with a nice metal bleeder screw to add to this kit
    Apr 05 2016
    Portland, OR
    This is a lot easier to do than most people would think...
    1. Remove intake tube.
    2. Remove coolant lines from front of blower
    3. Undo electrical lines from the TB/MAPS/etc
    4. Remove the 3 screws that hold the metal plate on the back of the blower and slide it to the side.
    5. Undo the 6 bolts that hold down the blower.
    6. Pull up to remove the blower. (Remove the PCV breather hose on the bottom before setting it down)
    WAM BAM DONE!
    When I read the thread title that's what I was hoping it was.
    Geoff
    Veteran Member Four Rings tar's Avatar
    Jul 07 2009
    B8 S4, Orange B5 Avant
    Socal/IE
    I thought it was coolant bleeder also. This is borderline useless item as most chargers will never get a oil change and the ones that do it will only be done 1x or every 100k.
    2011 S4 6mt Black/ Magma/ Carbon
    HRE ff01 | Rotiform ind-t | AWE Touring | P3 | Roc Euro | PLM | Eurocode Sways | Apr Stage 2 | H&R Sport | Q5 ECS Wave F/R | CR15 | AK | Eurocode Inserts | 034 subframe Inserts | Ecs Carbon Diffuser | JHM CP | ECS Short Shifter |
    Oct 02 2006
    Wadsworth,OH
    We'll look into that.
    -James
    Apr 05 2016
    Portland, OR
    -James
    They are M8x1.0 btw :)
    Geoff
    Veteran Member Four Rings TFSI's Avatar
    Dec 16 2009
    Some car
    MD
    Can't the old fluid be sucked out using small tube with syringe and put back in the same amount?
    Veteran Member Four Rings JD S4's Avatar
    May 07 2016
    '18 S5, '94 Integra DB8 JDM, '20 Highlander Hyrbid
    Citrus Groves, Arizona
    Quote Originally Posted by tar View Post
    not useless. lots of us will port a blower and change the oil while in there. Great mod
    '18 S5 - BBS / EPL
    Veteran Member Three Rings street2gen's Avatar
    Oct 13 2013
    Whitewater, WI
    Quote Originally Posted by whiped View Post
    https://www.ecstuning.com/b-genuine-...lt/06e127535b/
    Ill buy it for ecs and even give them free shipping just to help us all out.
    But for real would sell a lot i would think, id be in for two.
    Oct 02 2006
    Wadsworth,OH
    whiped we're kinda already working on it.... just not fast enough for yall!
    -James
    Apr 05 2016
    Portland, OR
    Quote Originally Posted by street2gen View Post
    I made like 20 of them when I broke my plastic bleed screws and sent them out all over.
    Easy enough to make, it is just an m8x1.0 x 16mm bolt that you cut a slit in the side for bleeding :)
    Geoff
