Results 1 to 2 of 2
    Oct 02 2006
    Wadsworth,OH
    NEW! ECS 3.0T Supercharger Magnetic Drain/Fill Plug
    Interested in simple, effective, & affordable protection? This ECS Tuning Supercharger Magnetic Drain/Fill Plug attracts and holds small ferrous metal particles within the supercharger oil to prevent wear.
    Click HERE for your ECS Audi 3.0T Supercharger Oil Magnetic Drain/Fill Plug
    ECS Tuning's Magnetic Plugs are engineered in-house for a perfect fit and feature a permanent magnet fastened to the plug body.
    The press-fit magnet holds minute abrasive particles, preventing their circulation through the supercharger lubrication system to aid in improved longevity.
    Wondering how to install? Don't worry we've got you covered! Click HERE to view our in-depth install guide.*
    Relieve worry and prevent excessive wear with ECS Tuning's Magnetic Plugs.
    Click HERE for your Audi 4M Q7 Quattro 3.0T ('2017+) ECS Supercharger Oil Magnetic Drain/Fill Plug Upgrade
    Click HERE for your Audi A7 C7 3.0T ('2011+) ECS Supercharger Oil Magnetic Drain/Fill Plug Upgrade
    Click HERE for your Audi B8 S4 Quattro 3.0T ('2010 - '2018) ECS Supercharger Oil Magnetic Drain/Fill Plug Upgrade
    Click HERE for your Audi B8 S5 Quattro 3.0T Cabriolet ('2008 - '2018) ECS Supercharger Oil Magnetic Drain/Fill Plug Upgrade
    Click HERE for your Audi B8 S5 Quattro 3.0T Coupe ('2008 - '2018) ECS Supercharger Oil Magnetic Drain/Fill Plug Upgrade
    Click HERE for your Audi C7 A6 FWD V6 3.0T ('2012+) ECS Supercharger Oil Magnetic Drain/Fill Plug Upgrade
    Click HERE for your Audi C7 A6 Quattro V6 3.0T ('2012+) ECS Supercharger Oil Magnetic Drain/Fill Plug Upgrade
    Click HERE for your Audi D4 A8 Quattro 3.0T ('2011+) ECS Supercharger Oil Magnetic Drain/Fill Plug Upgrade
    Click HERE for your Audi Q5 3.0T ('2009 - '2017) ECS Supercharger Oil Magnetic Drain/Fill Plug Upgrade
    Click HERE for your Audi Q7 3.0T ('2017+) ECS Supercharger Oil Magnetic Drain/Fill Plug Upgrade
    Click HERE for your Audi SQ5 3.0T ('2013+) ECS Supercharger Oil Magnetic Drain/Fill Plug Upgrade
    Veteran Member Three Rings GilliamOS's Avatar
    May 26 2015
    2013 A6 3.0T Prestige | 2013 Elantra GT
    Mormon Country
    From Eaton wedsite :
    Q: How often do I need to change the oil in my supercharger?
    A: The sealed oil reservoir in a supercharger is designed to last the life of the vehicle. Changing the oil is not recommended unless you suspect contamination, leakage, or other issues like bearing failure. Also, if your vehicle has an abnormally heavy duty cycle, such as racing or towing, you could consider changing the oil at regular intervals such as 20k, 30k, 50k, or 100k miles depending on usage.
    Oil color usually means absolutely nothing, 500 miles it can get dark.
    Edit: I should add, to do this swap you're going to spend at least $300 in parts and fluids, and you're going to need the coolant vacuum tool too, so add another $80 to the tab.
    2013 A6 3.0T - Slightly better than poverty package.
    2009 A4 2.0T Avant - Totaled
    2000 A4 1.8T - Sold
    1999 Millenia S - Sold, though it should've been crushed 'n cubed
    1997 A4 1.8T - Totaled, repaired, sold years later better than before
    1990 Maxima - Totaled from hail dents
    1987 Maxima - Sold
    1986 Golf Diesel - Rusted and fell apart
