Results 1 to 13 of 13
    Oct 10 2017
    Vibration in front seats after wheel change
    Could use some help with troubleshooting here...
    I put my summer wheels on last week, RSe102 19x9.0 +45, on stock staggered wheels (255/235) and have since noticed a ton of vibration around 100km/hr and up. The vibration can be felt heavily in the front seats, a bit in the steering as well.
    I used these tires briefly last summer (with stock wheels) when I purchased the car with no issue. I've double checked the tire pressure and torque settings on the lug nuts -- still no issue.
    I'm wondering if fitting the stock 255/235 tires to these wheels could have caused them to stretch, which could be producing a vibration?
    Any thoughts or troubleshooting tips?
    Veteran Member Four Rings a4000's Avatar
    Nov 30 2004
    Pittsburgh
    hub rings?
    '17 Audi S8 plus // DS1 // E40 // SRM TCU // SRM Flex // SRM Manifolds // SRM 3" Intakes // 034 HPFP // ARM Downpipes // Milltek Non-Res // Ibis // Black with Arras Red Stitching // Dynamic Package // Bang & Olufsen // Black Optics // Driver Assistance // Cold Weather // CETE ASC // 21x9 Ferrada FR8 // PS4S
    '19 Q7 3.0T Prestige // Audi Design Selection Murillo Brown // Luxury // B&O // Black Optics // Adaptive Chassis // Cold Weather // Tow // Night Vision
    Registered User Two Rings
    Apr 03 2018
    Los Angeles, CA, USA
    Most likely one/more wheel/tire is not balanced properly, get them road-force balanced at quality shop and check again. Also the wheel/hub are the same diameter, right?
    May 20 2010
    Could also be wear characteristics--if you swapped them side-to-side and you're not aligned correctly, one may be worn more than the other.
    2016 A6 TDI Prestige - Tornado Gray. Malone Stage 2, DPF Delete, EGR blockoff, S6 F&R brakes, 034 RSB, RSNav S4, P3 v3 TDI gauge
    2003 RS 6 - Misano Red. AMD ECU/TCU tune, KW V3s, Hotchkis sway bars, Phaeton brake ducts, red carbon fiber trim
    2005 allroad 6MT swap - Alpaca Beige
    2003 allroad 6MT - Highland Green Metallic / Fern Green & Desert Green interior (1 of 15 max) - WIP
    2003 allroad 6MT - SOLD like a dumbass
    2007 A4 2.0T quattro - Gone but not forgotten
    Nov 06 2017
    Vancouver
    This:
    Quote Originally Posted by macrs3 View Post
    Points to this:
    Quote Originally Posted by a4000 View Post
    hub rings?
    Oct 10 2017
    Quote Originally Posted by Potatohead_RS3 View Post
    This:
    Points to this:
    Thanks! It does sound like that could be the issue. The wheels indicate a center bore of 57.1mm, assuming I just need a hub ring to fit those specs? Anything else I need to account for?
    Junior Member Two Rings
    Dec 05 2017
    AB
    if your wheels have a 57.1 bore you should'nt need hubcentric rings.
    May 20 2010
    I'd take Grigore's suggestion and have them road force balance them rather than a simple spin balance. I've had wheels that did that and went I got them redone via RF balancing, any vibes went away. Also check to make sure a weight didn't fly away. I've seen this happen on several occasions.
    Nov 06 2017
    Vancouver
    Quote Originally Posted by LuckyBB View Post
    Correct. Probably going to need to visit a tire shop for a rebalance if this is the case. Definitely do Road Force, any decent tire shop has one now.
    Oct 10 2017
    Thanks for the all of the recommendations, I'll look into having them rebalanced.
    Veteran Member Four Rings S3DUDE's Avatar
    Aug 29 2017
    24' RS3, 23' RS3, 24' Colorado ZR2, 24' GR-86, 09' supercharged track SI
    Tucson, AZ
    If you want to save time on shooting your problem just do a quick search on my username (started threads). I had a similar issue on my S3 and it took several trips to various places to nail it down. I had 3 shops check my balancing and at the end it was the hub centric (plastic rings). Your balancing machine will NEVER pick the "out of balance vibrations", like I said, it ended up being the hub centric.
    I insist, save your time and search my post.
    8V RS3 [email protected] mph (ran a few 11.7s stock and ran 118+mph several times)
    8Y RS3 k&N filter ran [email protected] (ran 11.6 5 times and trapped 120+ several times)
    at 3100ft elevation
    May 20 2010
    After checking out the site for your wheels, I agree with the hubcentric rings.
    If you have the 19x9, this is what they say:
    Offset (E.T.): +45mm
    PCD (Bolt Pattern): 5-112
    Center Bore: 66.5mm / 57.1mm (with hub ring)
    Weight: 20.8 lbs.
    If they are only 19x8.5, then you would not need hubcentric rings.
    Oct 10 2017
    Confirmed that's the issue. I brought it in to the shop today to have it balanced. They said the issue is that the wheels do in fact require hubcentric rings.
    Problem solved. For anyone encountering the same issue, these are the wheel specs:
    Weight: 20.8 lbs.
    Thanks everyone!
