Originally Posted by
slowSfaux
A motor pull isn't "required" but getting at those banjo bolts (which is what you're calling a flange bolt) will be a nightmare. You'll need to either lower the subframe to get some room above the turbos, or unbolt the motor and trans mounts along with lots of other stuff, and pull the motor forward a few inches.
And once you have room, the real fun will begin. Getting all the lines removed off our turbos requires that you cut and grind a few wrenches, both 17mm and 19mm, open ended and box ends.
Good luck!
I figured this was going to be a nightmare when I tried to get at the banjo bolt...for some reason I was calling it a flange bolt lol
They make this insanely impossible to get at,I should have just went to tech school for these cars instead of joining the union lol
Thanks for your help man,appreciate it.
