Results 1 to 7 of 7
Thread: Wheel spacers
    Feb 15 2018
    Sioux Falls/SD
    Wheel spacers
    Wondering what you guys are running for spacers if any? I just put on coilovers and running stock wheels and tire sizing. Think I may need to bump out just a touch but don't want to roll fenders, etc...
    Veteran Member Three Rings my_RS4's Avatar
    Apr 15 2016
    Beach Cruiser
    Venice
    Wheel spacers
    H&R and MTM are pretty common.
    Most guys run 10s all around.. or I've seen 8 fronts & 10 rears. I ran 10 fronts & 12 rears..no issues -- but I was rolled..which I suggest you do to never worry about rubbing.
    IG @myRS4 | 2007 RS4 | Phantom Black | Ti Converted | Milltek'ed | KW H.A.S. kitted | Rotiformed (SPF DDT 19X10 +25) | PSSed 275/30/19 | LED DRL'ed + Citied + CC'd | H&R wheel spaced | 034 Density Line control armed | Hotchkis F + R Sway Barred | Apikol rear-diff mounted | JHM Lighweight Flywheeled | Ziza lit | Passport 9500ix hardwired | Dension Pro BT'ed | StopTech Brake Padded
    Active Member Two Rings vordurtech's Avatar
    Jan 14 2011
    NM
    Quote Originally Posted by RS4!! View Post
    I run 10s all around with stock wheels and brakes. I had to remove one screw in the wheel well, drivers' side front, to prevent rubbing.
    Sent from my SM-G930V using Tapatalk
    Current: 2008 RS4, Misano Red, Titanium package, Piano black inserts
    Previous: 2000 Jetta VR6
    Veteran Member Four Rings MugelloB7RS4's Avatar
    Feb 06 2015
    Quote Originally Posted by my_RS4 View Post
    I also ran 10mm front/ 12mm rear with a 275/30/19 without any rubbing issues. Car is also lowered.
    Veteran Member Four Rings b6bydesign04's Avatar
    Nov 14 2005
    Charlotte, NC
    I'm lowered on V3's, originally was running the 10mm flush kit from ECS Tuning all around but recently purchased 12.5's for the rear. Also removed the top screw in the front wheel wells to prevent rubbing.
    -Sean
    '06 Lexus GX470 | Dobinsons | fifteen52 | BFGoodrich | Prinsu | Gobi | Orangeboxx | RSG
    '11 BMW E90 M3 | ESS S/C | Recaro | M Performance | iPE | BC Racing | BPM | Volk | Coby
    F.T.W.L.T.B.D.W.I.C.T.W.
    Veteran Member Four Rings CoreyRS's Avatar
    Aug 07 2009
    Ca
    10mm MTM all around with 275/30/19s on stock suspension here also.
    Veteran Member Four Rings musanoadsaba's Avatar
    Jan 24 2009
    2007 Ibis RS4
    Rockies
    I would stagger them, give the back a few mm more
