Results 1 to 38 of 38
    Veteran Member Four Rings apatchin's Avatar
    May 28 2008
    PDX/DEN
    About to drop the SQ
    Hello ya'll. New posting on the "Q" forum but have B7 A4 Avant since 08 so im a bit more frequent on that forum.
    Background on the SQ:
    I bought my first SQ back in 2015, My original was (GIAC Tuned / AWE pulley / non res downpipes / exhaust / CTS intake) It completely sold me on the 3L
    I traded out for a late model 2017 last summer. for some reason there was a updated ECU that was not supported by GIAC or many tuning companies yet. I go in tomorrow to get my ECU # and hopefully find a reputable tuner.
    2015
    2017
    So my real question right now is: I am getting the KW HAS Kit installed tomorrow, as well as SPC control arms. Those who are lowered could you please measure F&R height from center of center cap to fender lip and post profile shots.
    Thank you!
    Sep 28 2010
    NW NC / DE
    May 28 2008
    PDX/DEN
    Thank you good sir! much appreciated!
    Sep 28 2010
    NW NC / DE
    Quote Originally Posted by apatchin View Post
    For sure! That is the HAS kit too. TONS more pics in the Flickr.
    Veteran Member Four Rings VroomVroom's Avatar
    Jan 03 2007
    SF Bay Area, CA
    Those wheels. That stance. Against Florett. Slurp.
    --Jerry || 2020 SQ7 Pr, GW/Black/BO (His); 2018 S5 Cab Pr, Daytona/Red (Hers)
    Suspension || H&R Springs - 29001-3; Bilstein B8 Dampers - 24-145985 (F) & 24-145992 (R)
    Wheels & Tires || BBS CI-R - CIR 0501 BPO, 20x10 ET25 Satin Black; Continental DWS06 275/40
    ...Formerly: '16 SQ5 '13 Q53.0T '12 Q5 3.2 '08&'06 A4 Avant 3.2.
    Veteran Member Four Rings S-Fore's Avatar
    Sep 17 2007
    Have a purdy set of EC Sways/Links for sale in the classifieds, since you're going lower....
    Thank you!
    Senior Member Three Rings kpykng1's Avatar
    Feb 17 2016
    Ventura, CA
    KW Street Comfort Coilovers
    034 Motorsport Rear Swaybar w/ endlinks
    2014 SQ5 Glacier White - 22" Touren TF01 - AWE Touring w/resonated downpipes - KW SC Coilovers - 034 Motorsports Rear Swaybar w/ endlinks, RSNAV System
    2017 MINI Cooper Countryman S
    Established Member Two Rings messex's Avatar
    Apr 16 2017
    xr400
    los angeles
    When I went that low with my street comfort I got a lot of cabin squeaks. Anyone else experience that. Are the HAS systems softer? I feel SC are too hard even set to softest setting.
    Feb 17 2016
    Ventura, CA
    Only cabin squeaks I get are when I vent the sunroof, but if I open it up the squeaks disappear. So I usually leave it open to the second setting or just keep it closed.
    Senior Member Three Rings KillerQuattro's Avatar
    Dec 15 2016
    Englewood CO
    What were your alignment specs after going that low? Did you go with control arms to correct? Im at the same height and worried about premature tire wear. But the $800 to upgrade just seems like more than i want to spend on such a minor correction.. that said, tires arent cheap either. I guess it depends on how fast the wear was actually happening. Havent had thr drop long enough to know. I need to dig out my alignment specs and see how they look again..
    Sep 28 2010
    NW NC / DE
    Quote Originally Posted by KillerQuattro View Post
    My thoughts have always been... I like my camber, as it gets me the fit and look I prefer. Let's say per set of tires... I give away 10-15% of the life due to camber. On a DWS that might be $150-$180? You get where I'm going. Takes a LOT of tires and miles to ever get there mathematically. But if someone wants perfect wear and correct camber, I get that for sure.
    Dec 15 2016
    Englewood CO
    I share your opinion, and that was exactly the kind of justification I was trying to work out.. I'm not that low, and not so far off overall, especially considering incorrect toe is where the real tire where can be seen. I think I'll leave it alone, and put my money to something else!
    Sent from my SM-N920P using Tapatalk
    Current: 1995 urS6 Avant. RS2 manifold, Stage 1 chip, Apikol FMIC, custom exhaust.
    Sold: 2013 Q5 3.0t- EPL Stage 2, 183mm CP, KW Coils, Eurocode Alu Kreuz, 034 inlet/AWE filter, EBC Brakes w/ SS lines, Hartmann HRS6 20x9, MF #11385 (center res) and Vibrant Ultra-quiet resonators out back.
    Sold: 2007 Ibis Avant- 2.0t 6mt, JHM HFC, TT DP, JHM HPFP, GFB+, B5 perch mod, 19x9 RS6, Hawk slotted rotors and performance pads.
    Sold: 1992 urS4- Garret 3071R, 034 tuning, RS2 goodies, 993TT BBK
    Sep 28 2010
    NW NC / DE
    I approve 👍🏼
    Man I suck at selling parts! 😛
    Apr 26 2014
    2012 R8 GT; 2016 SQ5; 2017 Q7
    DFW
    Sure you do. LOL Where's my wheels?
    Sep 28 2010
    NW NC / DE
    Quote Originally Posted by SQive View Post
    HA!
    Is the tracking working yet?
    Apr 26 2014
    DFW
    HA!
    Yes, but they still haven't left Taiwan.
    Sep 28 2010
    NW NC / DE
    They probably have, but haven't hit the first scan?
    Happy to get with them to see!
    May 28 2008
    PDX/DEN
    Thanks for all the responses, it was very helpful. I dropped it off yesterday afternoon and ended up referencing a few photos you all posted as well as the TAG motorsports SQ5.
    I was informed by my shop before that the camber wear on the tires would/could be severe and if i did not use adj. control arms to prevent the wear on the tires. I figured the money is well spent if I dont have to rotate often and or buy a new set of rubber. They highly recommended the SPC arms, and said they wouldn't even touch the 034 ones. According to MATRIX (the shop) the sets of 034 arms they tried in the past were very hard to adjust after installation, and would have to take them off, adjust, and re-install. Just a warning for people looking for control arms. Obviously thats there opinion, to each there own.
    I had a few other things getting worked on including sway and mounts so the car should be done this afternoon and will post some photos up after i pick it up.
    Thanks again for the photos and help.
    Established Member Two Rings drivenagain's Avatar
    Sep 05 2016
    MD
    Just picked up KW HAS, following this thread, everyone Q looks sick!!....is there a tutorial for install somewhere so I can save my mechanic some time??
    2013 Q5 3.0T | 57mm | 194mm | EPL DP Tune | Injen Intake
    2009 Aprilia Dorsoduro | TI Fuel Exhaust
    Established Member Two Rings notaclue's Avatar
    Sep 16 2015
    ATL GA
    Just trolling in the Q5 forum...I have the SPC on my A7 and they are much easier to adjust than the 034. My first set of DWS only lasted about 20k without - bad inner wear. You won't regret the purchase to get the front end squared up again. I hope to use all the info from this forum for my SQ future purchase...one day...
    2016 Sepang S6
    Aug 14 2015
    So. Cal
    Here are my alignment specs. FTG = 30" on H&R VTF and stock control arms.
    Veteran Member Four Rings V8Star's Avatar
    Jun 08 2010
    Quote Originally Posted by schmove View Post
    That is a lot of toe in up front with that much camber - almost -2* left front. And right front at -1.3*
    I'd get a set of adjustable arms on that bad boy to bring camber back to an even amount.
    Run a little less front toe in and watch those tires last forever.
    R8 V10 Supercharged
    8V.2 RS3 grocery getter
    B5 'RS4' Limo & 8L S3
    A few A4 Avants
    May 28 2008
    PDX/DEN
    Sorry for late camber spec post and photos. Have not had a chance to get a good place to take any quality shots yet, but ill post some when i do.
    As I stated earlier the SQ went into the shop for a few improvements
    KW HAS kit / SPC control arms / 034 Trans mount / 034 RSB / Uni Stg 1+
    Car feels awake again and couldnt be happier with the stance. Ride quality has definitely suffered, but not like that ever stopped me. Had a little fun with a Macan GTS the other day, forgot how much power our cars have when you wake them up. I eventually will get to the pulleys and a few other details. After selling my 14' with Stg.II im not in a rush. I will play around with the uni tune for now and see how i like it compared to the GIAC tune I had on the 14'. Never had a Unitronic tune on any of my Audi's but have close buddies who have, so I figured what the hell. plus the reported figures looked pretty good.
    Camber Spec: https://ibb.co/fGxTdn
    2017 Lava Grey Pearl / KW HAS Kit on Painted Stock 21's w/ 18MM spacer Rear & 13MM Front
    Jan 03 2007
    SF Bay Area, CA
    That looks fantastic!
    Sep 28 2010
    NW NC / DE
    Wow... agreed! Looks badass!
    Established Member Two Rings alpineaudi's Avatar
    Aug 05 2016
    Nor Cal
    What FTG did you end up with..30?
    2011 BBlack 3.2 Q5 S-Line (Traded in)
    2014 Glacier SQ5 (Crashed and Totaled by a Drunk while parked in front of my place)
    2016 Daytona SQ5
    May 28 2008
    PDX/DEN
    Quote Originally Posted by alpineaudi View Post
    what ftg did you end up with..30?
    30.5 r / 30 f
    Feb 17 2016
    Ventura, CA
    I'm starting to get a spongy sound now when going over speed bumps or in/out driveways, coming from the rear driver's side. On the freeways it's ok cause of the regular road noise so I don' t really hear it as much.
    What would be the first thing to check? Swaybars? Bump stops?
    I don't see how the coils themselves could cause the noise.
    Veteran Member Four Rings buggravy's Avatar
    Jun 25 2016
    Mountain bikes and snowboards
    Calabasas, CA
    Quote Originally Posted by kpykng1 View Post
    I can pretty much promise you it's the bushings on the 034 RSB. They just need to be greased (and will again once or twice a year, or after driving in heavy rain).
    '23 S4 Prestige - Chronos Grey
    '24 Q4 55 e-tron Glacier White
    '24 Q5e District Green
    TOTALLED: '21 Q5 P+ - Glacier White (wife's)
    SOLD: 21 S4 - Mythos Black
    SOLD: '19 SQ5 - Quantum Gray
    TOTALED: 21 SQ5 - Ultra Blue
    SOLD: '19 e-tron - Typhoon Gray
    SOLD: '16 SQ5 - Sepang Blue w/Black Optics
    IG: @gravysq5
    May 06 2007
    Michigan
    Over the winter I hit a massive pothole (more of a crater) and feared my tires or wheels were toast. Somehow the wheels and tires survived, but the next day I heard a squeaking noise coming from the right rear every time I went over a bump in the road.
    Turns out I blew out both my rear strut mounts. The repair was cheaper then getting new wheels/tires. My KW SC coils survived the impact.
    2013 Daytona Grey RS5
    Prev
    2014 Ice Silver SQ5
    2012 Monsoon Grey S4
    2010 Brilliant Black A5
    2003 Denim Blue A4
    Feb 17 2016
    Ventura, CA
    Quote Originally Posted by mlux24 View Post
    I did hit a huge dip in the road that caused me to bottom out for the first time and it slowly started since then. Thanks I'll have to check that out to, thank you.
    Quote Originally Posted by buggravy View Post
    I'll check the fittings too on the RSB, I did pressure wash the undercarriage twice before I packed up all my garage stuff. Thanks
    Veteran Member Four Rings 1RAudiSQ5's Avatar
    Mar 08 2007
    Ashburn Va
    Hey man... what tire size are you running on your 22’s? And what are the wheel specs
    Feb 17 2016
    Ventura, CA
    265/35ZR22 Continental Extreme Contact DWS 06 Rubber
    Touren Tf01 Brushed Silver 22X9 5-112 30mm Wheels
    Senior Member Two Rings BklynSQ5's Avatar
    Mar 02 2018
    Manhasset, NY
    Those SQ5s look great with the powdercoated wheels!
    2021 Audi SQ5: Mythos Black/Red, 22" ABL19 wheels, AWE Exhaust, MTM links (wife's)
    2021 BMW Alpina XB7: Blue/White, 23's, Rear entertainment, captains chairs
    2017 MB C63S: Matte White/Brown, Edition 1, Performance seats,
    IG: Bklyngarage
    Established Member Two Rings mchoudhry2k's Avatar
    Jan 10 2011
    San Jose, CA
    Veteran Member Three Rings delz05's Avatar
    May 16 2014
    2013 Volcano Red S5 Cabriolet 2016 Glacier White A8L
    Boston area
    Just to let you know...
    EPL Stage 2 (SC pulley) is a serious upgrade over stock.
    I had been using the Chipwerks Pro, which was nice but not much of an improvement. The EPL tune provides a nice smooth and powerful upgrade.
    In Sport mode it is a beast... according to Tony and Chris, I will not have to flash back to stock for next spring's emission tests... another plus!
    Family comes First!.... Nice cars a close second.
    For topless Summer fun... 2013 Volcano Red S5 Cabriolet Prestige, Black Optics Grill, Rear Valance, Tint, IE Down Pipes... SOLD!
    Semi-Daily Driver: 2016 A8L, Glacier White... Where to begin with the mods??? SOLD!
    Jan 17 2007
    14’ Nardo SQ5 | 14’ S4 PP | 10’ A4 Avant S line
    Wisco
    Quote Originally Posted by delz05 View Post
    Yuuuge upgrade over stock. I'm EPL stage 2 with an APR pulley/CTS intake and it rips. I mix about 5 gallons of E85 with a 93 fill up. Helps with timing quite a bit. I think single pulley upgrades would even benefit from boost coolers. I notice a significant difference in consistant power on 90 degree days vs. a 65-70 degree morning.
    Mine is lowered on H&R sports with Bilstein Sport struts/shocks. Ride quality is slightly stiffer than stock. Lowers about an inch all around.
    IG: @nardosq5
    Apr 26 2014
    DFW
    Be glad. . .the tune for the B9's is $2,500 and is only good for 425/405. My gen.1 is 470/440. Yay superchargers!
