Results 1 to 11 of 11
    Junior Member Two Rings YCDBINC's Avatar
    Aug 03 2014
    Long Island, NY
    I'm sure this was asked 100 times, but im on a time crunch. Tire Size inquire RS5
    I have NICHE 20 x 10.5 and ran PZero 275-30-20 with a mild stretch on the tire. After getting used to the look, it was ok.
    Now I need new tires and want to know if a 285-30-20 on a 20x10.5 wheel will rub up front?
    2013 RS5 Cab
    Also, if I say no to PZeros, what tire for Summer and Wet only would you recommend. thank you all very much..
    2013 Audi RS5 Cab - Misano Red - B/O - Titanium - Capristo - Niche 20x 10.5 - Tint
    Veteran Member Four Rings Cloudg8's Avatar
    Oct 10 2012
    Jeep
    Chicago/IL/USA
    Quote Originally Posted by YCDBINC View Post
    2013 RS5 Cab
    Mops is the man to ask. I know for sure you can do 285/30/20. Lots of people run that size.
    I’m going 275/30/20 on my 20x10’s. Et 25 w/ 5mm spacers.
    Not sure about the tires in your question tho
    Mar 18 2015
    2015 GL450
    IL
    Agree on checking with Mops. If you PM him you should hear back pretty quickly.
    I almost ran the 285’s on my S5 and was advised that it wouldn’t be an issue.
    As to tires, if you have the budget, the new Pilot Sport 4S’s are fantastic. I’m running them in 275/30/20 and am very happy with them.
    Sent from my iPhone using Tapatalk Pro
    2016 S5 6MT - Brilliant Black, P+, High Gloss Black, Sport Dif, B&O, Tech, Nappa
    Engine: GIAC Stage 2 & SC Pulley / ECS Carbon S-Flow Intake
    Suspension & Wheels: H&R Street Performance Coilovers / Vorsteiner VFF-103 (Carbon Graphite)
    Exhaust: AWE Touring
    Cosmetic: OEM RS5 Grill / PPF & CQuartz Finest Coating / 35% Pinnacle Tint
    Oct 10 2012
    Jeep
    Chicago/IL/USA
    Quote Originally Posted by RVJ View Post
    +1 for the PS-4’s
    Aug 03 2014
    Long Island, NY
    Thank you all.
    Senior Member Two Rings ffearless's Avatar
    May 22 2017
    2007 Tundra, 2017 RDX
    Quincy, WA
    Some of the answer depends on the offset of your wheels. I am running 285 30 20 Pilot Sport 4S on Ray's TE 37 10 x 20 +25s and they work very well. It would be difficult to find a better handling tire for summer and rain.
    2014 Estoril Blue RS5, loaded, 034 Motorsport X-Brace and rear anti sway bar, CR-15 strut tower brace, Ecstuning transmission and differential inserts, carbon fiber mirror housings, LED backup lights, VAG COMM mods, mid-resonator delete, true dual exhaust
    Senior Member Three Rings Diesel S5's Avatar
    Nov 28 2017
    PA
    Offset on wheels is key...
    I run a 285/30 +30 offset with no issues...
    Sep 28 2010
    NW NC / DE
    Even with ET25, 285 will be fine up front.
    Senior Member Two Rings T_Glass_27's Avatar
    Jan 21 2013
    1988 Porsche 944S
    Mooresville, NC
    I have a 285 with a 20x10.5" +27mm and no issue.
    Junior Member Two Rings Brad Williams's Avatar
    May 18 2017
    Philadelphia
    I have 285 x 30 x 20 pilot sports on my 20 x 10.5 niche wheels. No rubbing at all. I don’t know the offset of the top of my head assuming +30. Lowering next week. I’ll let you know how it goes.
    May 18 2017
    Philadelphia
    Just lowered her, no rubbing at all with plenty of room to go with these size wheels/tires.
