Results 1 to 6 of 6
    Veteran Member Four Rings promoda's Avatar
    May 26 2010
    2015%20Audi%20Q5%2C
    Montreal
    Spacers = Rubbing?
    Hey guys I have a set of spacers from my old b8. I had issues in the past with them causing my wheels to rub, they also tilted the camber a bit to give an aggressive look... but it caused "feathering on the tire..
    I'm curious if I were to put these on my B9 will it fit? Will it rub? And do I need to change the allotment?
    My setup: stock 19" sline rims. The spacers are H&R 10mm
    Sent from my SM-G960W using Tapatalk
    Veteran Member Four Rings fR3ZNO's Avatar
    Feb 09 2013
    WNY
    "If one does not fail at times, then one has not challenged himself." - Ferdinand Porsche
    May 26 2010
    2015%20Audi%20Q5%2C
    Montreal
    Quote Originally Posted by fR3ZNO View Post
    Thanks man ! That was super helpful!
    I'll measure it up tomorrow thanks again
    Veteran Member Three Rings yb28's Avatar
    Mar 06 2013
    2017 B9 A4 2.0T Quattro DSG , 2017 Q5 2.0T Quattro TIP
    Toronto, ON
    you wont rub, we have the same rims, stock is ET43, i run 10mm spacers and lowered on 034 springs, no issues.
    2017 B9 A4 2.0T Quattro S Tronic | Daytona Gray | Xenon to LED Headlights Conversion | Custom Brembo 8 pot BBK |
    Build Thread
    2015 B8.5 A4 2.0T Tip Black
    2003 B6 A4 1.8T Tip DG
    May 26 2010
    2015%20Audi%20Q5%2C
    Montreal
    Quote Originally Posted by yb28 View Post
    Awesome!
    Jan 28 2018
    Ontario, Canada
    Anyone know whats the max we can get away with without rubbing.
    Ideally i would like to run 12.5 front and 15 rear. Anyone know if this would cause issues? I'm running the same rims 19'' sline
