Results 1 to 40 of 40
    Jan 14 2018
    Audi
    Question How much of body creak / creaking noises you have?
    Hi all,
    After a couple moths I got my 2014 CPO B8.5 I've started noticing some weird noises. They are hardly noticeable when there is music playing or cruising on high speeds. When I got to a dealer, they told me it's okay, it just body creak and that's fine when a car gets older. But it is super annoying and makes you feel driving a long truck creaking at any blow of air. My car still has factory warranty and I really want them to look into this problem. Just a couple days back I drove thru a serpentine in a forest at like 30 mph. All these creaking/rubbing/freaking sounds are super noticeable. I pretty much don't hear them going straight, but sharp turns, going sidewise over bumps/driveways or when a road has changing camber giving me them 100%.
    Could you please give me any advice? Maybe you know a good Audi service advisor in Bay Area who is really looking into and solving customer's problems?
    Btw I've recently driven a loaner - A4 2018 2.0 and ofc it is super silent car w/o any "normal" creaking sounds.
    Thank you!
    Senior Member Three Rings tominabox1's Avatar
    Nov 08 2017
    DFW
    My door seals on the back doors creak like crazy. I have tried [I]everything[/]
    teflon spray
    s100 wax
    gummi pflege
    I'm out of ideas.
    2014 A4 Quattro // Sport Package, Black Optics, Bang and Olufsen
    IE Stage 2, CR-15 Strut Brace, USP High Flow Cat, Spulen turbo inlet pipe, aFe filter
    Veteran Member Three Rings cjw's Avatar
    Aug 11 2015
    Alberta
    Back passenger door creak is the main one.
    I get the odd dash noise as well. I've jammed so much felt tape on the main dash plastic piece and that helped.
    2013 Lava Grey S4 S-Tronic
    Injen, EPL DP (3.2 ratio) +TCU, Magnaflow Catback Back to Stock, PLM HX
    Jan 14 2018
    Audi
    I've had pretty bad squeacking noise since the first day. It was coming from a back right handle in the celing so they've identified and replaced it for a new one (they said it became loose). But all those minor creaks still remain. And when there are a lot of minor creaks they are not minor anymore.
    Veteran Member Four Rings fmzip's Avatar
    Aug 21 2017
    Quote Originally Posted by cjw View Post
    Try using clear non-silicone caulk on the back...worked wonders for me, no creaks. Applies, white, dries clear
    Quote Originally Posted by gmurom View Post
    I have a rear gremlin...might need to look at this
    BMW M850i
    Aug 17 2015
    California
    Quote Originally Posted by tominabox1 View Post
    teflon spray
    s100 wax
    gummi pflege
    I'm out of ideas.
    Adjust the striker plate on the frame (the latch the door hooks into when closed). Adjust it a few mm inward and it will hold the door tighter and prevent rubbing of the weather seals.
    When loosening the 2 bolts that hold the striker plate, do not remove them! They might fall behind. Just loosen slightly. [Unconfirmed but this is something I've read online that can happen].
    I had the dealer adjust my striker plate under warranty and the creaking was gone for a solid 2.5 years. It just came back lol. Best 2.5 years of my life.
    Nov 08 2017
    DFW
    Quote Originally Posted by A4x View Post
    Adjust the striker plate on the frame (the latch the door hooks into when closed). Adjust it a few mm inward and itnwill hold the door tighter and prevent rubbing of the weather seals.
    I tried this too but I didn't feel any play in any direction on the plates. Unless I'm totally missing something, mine simply do not move like that. The plates don't have slotted holes.
    Established Member Two Rings badazzstang's Avatar
    May 10 2017
    13 S4, 90 Mustang GT Convertible, 94 LS400, 07 F150 Supercrew, 2010 GX460
    Waco, Tx
    My rear seat to striker has a ever so slight vibration/buzz that I hear every once and a while. Its RPM dependant bases on the resonation of the exhaust coming through the body. I only found out where it was coming from be I was rising in the back seat on a rode trip. I am thinking a small dab of thick grease on the striker might help.
    2013 Glacier White Metallic S4 DSG/Black Nappa - EPL Stage 2
    Oct 31 2010
    Lafayette, Colorado
    +1, especially when cold.
    teflon spray
    s100 wax
    gummi pflege
    I'm out of ideas.
    Aug 17 2017
    2001 Audi TTQC 225, 2003 VW GTI 20thAE, 2016 SQ5
    Atlanta, GA
    It's a steel unibody. They flex, especially with age. Plastic's properties change over time, meaning they flex less and rattle more. If you want to get rid of the noises you're describing, either cage it (it won't flex anymore, not practical for most), install braces (CR15, AK, etc), or install sound dampening or a louder stereo (which will mean taking interior panels apart, creating more noises/rattles, or your new speakers rattling everything loose themselves).
    Jan 14 2018
    Audi
    In that case, how come my previous car (Ford Focus) same age same mileage was super comfortable, silent w/o any squeaks and creaks?
    Established Member Two Rings nowakm99's Avatar
    Jan 21 2018
    2016 Audi S4, 2012 Cayman S, 2025 Integra Type S
    Toronto, Canada
    I have a 2016 S4 with 40,000 km (approx 30,000 miles) and the creeks and rattles are definitely noticeable. I recently sold a 2011 BMW 328 and have a 2012 Cayman and both those cars felt much more solid than the S4.
    That said, the rattles are bearable and not really an issue when the music is on. Bottom line: I still love the car and enjoy driving it.
    2016 S4: IE Stage I, IE CAI, AWE Touring Exhaust, CR-15, H&R Rear Sway bar w/ Moogs end-links, 034 Motorsport transmission mounts, Vorsteiner V-FF 103s in Machined Titanium
    Mar 16 2017
    San Francisco, CA
    Add another for noisy rear door seals, or possibly the rear window seals. Tried cleaning them all and applying gummipflege, but made no difference.
    Veteran Member Three Rings SForePlayin''s Avatar
    Jan 11 2014
    2015 Toyota Camry SE, 2015 Lexus IS 250 AWD, 2018 Honda CRV LX
    North Carolina
    Try my suggestion here - Post 14 and 16.
    2014 S4 Ice Silver Metallic|Black Optic|DSG|Sport Diff|ADS|Fine Black Nappa|MMI Nav +|B&O|Carbon Atlas Inlays|Supercharged Badges|Advanced Key|OEM Floor and Trunk Mats|Michelin PSS A/S 4|Lamin-x Yellow|deAutoLED|Carista|
    2003 A4 Sedan | Light Silver Metallic | MT6 | 3.0 Quattro | - Traded In
    Instagram - sforeplayin
    Veteran Member Three Rings fstr n u's Avatar
    Jan 20 2015
    I have a low mileage 2015 S4 and the back (seems like passenger area) creaks when i go over undulations or train tracks (for example) all the time. Super annoying. Will see if it's the rear door jamp adjustment and go from there.
    2019 Audi SQ5 Navarro Blue Technik w Black Optics Pkg - stock for now
    2015 Audi S4 6MT Glacier White w Black Int (IE Stg 2, Merc Hx, CTS Turbo CAI & CTS S/C Pulley) - my DD
    2006 Subaru STI Hawkeye Murdered Out - larger turbo 400hp - son's car
    1998 Chev Camaro 6MT, LS2 Rear mount Turbo (710+rwhp/710+rwtq @ 14# boost wheels) - summer hooligan
    http://www.youtube.com/@musclecarfan1
    https://www.instagram.com/ryan_baliski/
    https://www.tiktok.com/@winewithryan
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    My 2010 S4 with 59000 miles is bank-vault quiet......
    Nov 08 2017
    DFW
    Quote Originally Posted by S4'ed View Post
    Senior Member Three Rings MME1122's Avatar
    Mar 26 2016
    2011 Jeep Liberty
    I had a lot of creaking over speed bumps, driveways etc. The dealer actually replaced my lower control arms. It seemed to help but I'm honestly not sure if that was the problem or a placebo. I got a CR-15 brace and that helped immensely, I have an AK too that I haven't installed yet. As for rattles I have plenty too but haven't attempted to really address them yet. I believe there's a TSB for the rear shelf rattle which is probably the worst one I have, I may have the dealer look at that as well.
    Veteran Member Four Rings jygesq's Avatar
    Aug 22 2014
    1986 Honda CH 150 D scooter bought new
    bloomfield,ct
    Quote Originally Posted by fstr n u View Post
    before you adjust the door jam, try a few wraps of plastic electrical tape around the the door jam. It worked well on my 2000 BMW.
    2015 S4, P+, Florett Silver,black /silver nappa leather, S-tronic ,sport diff,B&O ,tech package ,supercharged badges. All season tires ,cargo net, factory dip stick
    Mar 29 2009
    Plenty of rattles coming from back seat area since i purchased CPO at 31k miles. At 58k miles now and rattles keep adding up all from rear area. New creaks in rear now sound like its coming from left and right ceiling area.
    Veteran Member Three Rings TEB's Avatar
    Sep 19 2010
    '70 Cutlass, Yukon, MDX, Pilot
    Ponte Vedra Beach, FL
    This thread is concerning. I don't really have any significant issues, but the roads around here are excellent. Both my B5 and B6 were solid well past 100k (although, the B6 developed something in the left cowl area when I installed the stiffer C/O's).
    2011 S4 6MT Ibis White|Panda Nappa|Titanium|Carbon|NAV|Sport Diff|B&O|H&R Sports|Unitronic 2+|RS5 brakes|034 RSB/Insert|10mm Spacers|Tints
    (Gone)2004 S4 6MT Silver|Black|Carbon|Bilstein|Hawk|Magnaflow|ECS
    (Gone)1998 A4 5MT Black|Black|Bilstein|A8/S4 Brakes|APR Exhaust|AWE DTS|Intrax Extreme|Flik|GIAC|Etc
    Senior Member Two Rings steampunkjunker's Avatar
    Jun 21 2017
    NorCal
    Just noticed a little coming up over driveways etc after adding heavier sway bars.
    Junker’s 2013 B8.5 S4
    • Suspension: H&R ARBs, CR-15, H&R 10/12mm wheel spacers
    • Braking: Endless MX-72 & RF-650 fluid, StopTech cryo slotted rotors, Tyrolsport brake lines & caliper bushings
    • Motor: GIAC - Stage 2, Redline oil
    • Coming soon: GIAC - TCU, Bilstein B12 Pro-Kit
    May 10 2017
    Waco, Tx
    Quote Originally Posted by FriCk View Post
    You might have the same rear seat vibration/sound that I have. I am going to try PTFE grease. All the sound is on mine is the striker and latch vibrating just a hair making a sound so the grease should help. I will report back.
    Veteran Member Four Rings doughboy17's Avatar
    Aug 05 2010
    2007 Audi A4 3.2 Quattro; 2021 Mazda CX-5 Turbo Carbon Edition (my wife's vehicle)
    Central IL
    teflon spray
    s100 wax
    gummi pflege
    I'm out of ideas.
    Have you tried simply treating them with 303 Protectant? ... although with those other coatings on there it may be difficult to get good results.
    2014 Monsoon Gray S4 Prem+ | S-Tronic w/ EPL tune | LH Magma Nappa leather interior | Carbon Atlas inlays | Sports Diff | Adaptive Damping suspension | 19” peelers | MMI Nav | B&O | EPL Stage 2 via JHM 179mm crank pulley | Resonated AWE Touring w/ 102mm tips | ECS silicone intake tube with aFe filter | RKX tranny mount insert | tints | VAG COM mods via OBDeleven | Autostyle Mats
    Sep 19 2010
    Quote Originally Posted by doughboy17 View Post
    FWIW, I have always been told to never put anything on the weatherstrips or they will squeak. No idea if this was just urban legend or not, but I've always followed this advice.
    Nov 08 2017
    DFW
    Keep trying all kinds of things. The teflon spray worked the best but squeaks still came back. Need to go back to square one if I can manage to get them cleaned off. My wife stole my Invisible Glass or I'd have done it already...
    Veteran Member Three Rings Corradobrit's Avatar
    Oct 27 2007
    TX
    I've found that if the drop down arm rest isn't pushed securely back it will creak.
    2014 S4 Premium Plus, Glacier White Metallic, Black Optics, DSG, sport diff, Nappa, B&O, AWE Touring/Res DP, GIAC ECU Stage 1, ECS CF rear diffuser, CR15
    Mar 29 2009
    Quote Originally Posted by badazzstang View Post
    Possibly. For sure its somewhere in the back. I remember reading awhile ago someone having some parts replaced/adjusted in the trunk where the trunk rests on when closed. Thanks
    Mar 29 2009
    Quote Originally Posted by Corradobrit View Post
    Yep I have that issue also lol. Dropping that down reduces a few of the sounds but not all
    Veteran Member Three Rings NAR Mike's Avatar
    Jun 28 2016
    MA
    my sunroof creeks and something vibrates in there...anyone have any suggestions? Don't want to pull off the headliner.
    2014 AUDI Q5 3.0T
    2015 PORSCHE MACAN S
    Mar 16 2017
    San Francisco, CA
    Quote Originally Posted by SForePlayin' View Post
    I'll look into it again. The last time I messed with it I am pretty sure I ruled it out to being the rear doors. The creaks would still happen if windows were down but not if doors were not latched all the way.
    The noise isn't bad, not a tinny or rattly sound. More like a very deep low freqency creaking. And just when the car is getting twisted at an angle on driveways and bumps on one side of car and such.
    Aug 22 2014
    bloomfield,ct
    Do you get noise with hood open? if not try some felt tape on the four plastic hood bumpers. That was the fix for my creaking noise.
    Jun 28 2012
    North NJ
    I have the door seal rattles. Gummi pfledge helps mine for a few months at a time. Door seal on driver's side was replaced under warranty 1 year in but it didn't make a difference. The B8 is definitely much creakier than my B6 even after it was repaired when a deer went through windshield and folded back a foot of my roof. From day one, the B6 felt like a much more solid car.
    2012 S4 Prestige - Ibis and Titanium - 6MT - MMI - B&O - Rear Parking - Advanced Key
    - Clear Bra - Vag Mods - 8500 Hardwire - Intercooler Screen - Roc-Euro Short Shifter - Eurocode Rear Sway Bar - CR-15 - Matte black rear valence - Show N Go Front Plate
    1991 Ducati 851 - 888cc High Compression Pistons - Big Valve Corsa Heads - High Flow Fuel Injectors - Open Airbox - Braided Steel Lines - Corbin Seat - Fast by Ferracci Chip and Mufflers - Carbon Fiber bits
    Hex-Can-USB in Northern NJ
    Apr 05 2009
    1984 Audi 4000S Quattro, 1989 Toyota MR2 SC, 1960 Alfa Spider
    SF BayArea
    no creaks on my 2012, but it developed quite an annoying buzzing in the driver's door. took it all apart, think it was a wiring harness rattling against the plastic. zip tied some stuff and put sound deadening in there wherever I could fit it. it went away now
    on a car that is quiet as these (unless you have some rowdy exhaust droning away) you really notice any rattles and squeaks
    Mar 16 2017
    San Francisco, CA
    The seals and stops on the trunk are surprisingly noisy as well. I had a bunch of creaks, groans, and pops, especially when driving slow and the car frame twists or gets knocked by small bumps.
    I coated all seals and stops on the trunk with a bit of krytox and holy crap it is way quieter.
    Had no idea they could produce that many noises, I had thought my suspensions bushings were going bad.
    Veteran Member Three Rings dimonblr's Avatar
    Oct 02 2018
    Boston
    Damn license plate bolt or whatever the hell fell into the inside of the trunk behind the rear plate frame is rolling around in there.
    B8.5 S4 | B9 Q5 | IG: @dmzb8s4
    May 01 2017
    Seattle/WA
    The metal grate in the fuel filler pipe rattles and I have no idea how to remove it.
    Jun 04 2018
    Orange County, California
    2016 S4
    I have the sunroof squeak/rattle.... everyone says I’m insane but it wasn’t there when I bought the car.
    Otherwise I get a little suspension noise in the rear when going over speed bumps
    Junior Member Two Rings Merlintwist's Avatar
    Feb 27 2019
    Scotland
    +1. 2014 S4 with 30k on the clock.
    Drivers door squeaks quietly (possibly weather sealing)
    Passanger doors rattle.
    Rear drivers side door used to vibrate like crazy on a cold start but that seems to have somehow sorted itself out. Not heard it in months.
    2014 B8.5 S4 Black Edition - Phantom Black Metallic | Alcantara
    IE Stage 2 | 187mm CTS Crank Pulley | Porsche Macan Calipers | Merc Racing HX | Eibach Pro | 034 RARB | VBT G-Hook Discs | DS2500 Pads | CR-15 Strut Brace | 034 Billet Underbrace | Billet Trans Mount Insert | Carbon Mirrors | ECS Carbon Inlet | Leyo PD Paddles | 5% Rear Tints | 50% Front Tints | Michelin PS4S
    Mar 16 2017
    San Francisco, CA
    Last bit of noise is gone after lubing the hood latch mechanism and contact points.
