Results 1 to 3 of 3
    Established Member Two Rings bguild's Avatar
    Apr 30 2014
    Massachusetts
    Rear brake line removal question
    Gentlemen, searched through the first 10 pages of results on caliper replacement and couldn't find a clear answer so I'll ask here.
    When replacing the rear calipers, on the brake line side closest to the caliper, there is a 14mm nut attached to a threaded rod which then attaches to the caliper. This assembly and the brake line itself doesn't seem rotate, causing an interesting predicament where I literally had to rotate the caliper over and over to remove it.
    There has to be a better way to remove this brake line from the caliper. I need to find it as I don't want to risk the powdercoat finish when I reinstall the calipers.
    Any advice?
    Apr 05 2016
    Portland, OR
    You should remove the top part of the brake like first then undo the lower part.
    Geoff
    Apr 30 2014
    Massachusetts
    whiped, thank you, on reflection I thought this might be the answer but I appreciate you weighing in.
