Originally Posted by
brianup
Are your battery terminals clean? Will it start with jumper cables?
After checking ground wires, connections, relays, I think you might be onto something with the battery.... battery doesn't have enough juice to turn over the starter if I let the car sit for 15-30 minutes... If the car stays in a spot for over 4 hrs, it seems it has enough juice to turn over the ignition...
I have had the Braille 21lb battery for 1.5 years now. The car was in the shop for a good month without the battery in the car, I am not sure if the battery not be used that long could have SHORTENED its lifespan?
I managed to test the car 3 times today when it wouldn't turn over. Two tests consisted of jumping the car, both times and it immediately fired up. The other test was charging battery with a trickle and once again it fired up once the charger read "ready".
I do have some draw from my RNS-E after I turn off car and that typically lasts for 5 minutes til it finally shuts off... I pulled the fuse to the stereo so I am going to see if thats the culprit.. Its a long shot but all I can do is trial and error
