Results 1 to 5 of 5
    Established Member Three Rings JWebb_C7_Comp's Avatar
    Jan 11 2018
    2018 A6 Comp, 2017 Q7
    Chicago Burbs
    2018 A6 3k Miles using oil
    Hey guys, I checked my oil today at 3,000 Miles; and, the car has already used 1/3 of the acceptable range (I am assuming = 1/3 liter).
    Iíve had a few BMWs and Hondaís in the household and none of them used any oil until more than 100k on the odometer, and then you could see it leaking....
    Does the 3.0 motor in these cars really use oil normally or do I have an issue on my hands?
    Stage 2 Banner Advertiser Two Rings
    Apr 03 2018
    Los Angeles, CA, USA
    Hey, sometimes itís normal, best is to check your owners manual for acceptable oil consumption, in some cases Iíve seen it saying up a quart/1k (! Yeah :-)) is normal.
    Bestiale - incredible quality tuning and full service for Audi, Porsche, VW and Bentley backed with 101 year labor warranty
    8651 Washington blvd., Culver City, CA 90232
    562-448-2599, Grigor@bestiale.net, www.bestiale.net
    Registered Member Two Rings
    Apr 12 2018
    Camarillo/CA/USA
    Oil consumption during engine break in is a little accelerated as the rings, pistons and valve train run in...it will decrease by the next 3,000 miles...
    Jan 11 2018
    Chicago Burbs
    Quote Originally Posted by AudiA4B61.8T View Post
    Thanks guys; Iíll keep an eye on it!
    Jan 11 2018
    Chicago Burbs
    UPDATE: Changed oil w/ 5000 on the clock and have driven another 2500 miles since then. Total mileage =7500. Since the oil change, the car has use maybe 1/8 of the acceptable range (1/8 liter?). At this rate - assuming 5k changes - I won't need to add oil between oil changes as I won't likely use more than 1/4 to 1/2 of the acceptable range.
    Quote Originally Posted by JWebb_C7_Comp View Post
