Results 1 to 10 of 10
    Account Terminated Two Rings
    Sep 28 2014
    your moms
    Front brake caliper locked up
    Just replaced the hub and bearing today and put everything back together. Now the brake is locked up on that side. I used a C clamp to compress the piston and opened the reservoir to get the caliper back on over the rotor. I got in the car, started it and pushed the pedal down a few times with reservoir closed. The pedal was soft but now is rock hard. I tried opening the reservoir but it made now difference. I’m sure I made a mistake somewhere. Any ideas? I’m gonna take the caliper back off tomorrow, possibly bleed it on that side.
    Sep 28 2014
    your moms
    ESP light also came on
    Veteran Member Four Rings Denio24's Avatar
    Jan 23 2013
    Chicago
    Perform an abs function test.
    Sent from my SM-G920P using Tapatalk
    Garage: 2008 Quartz Gray Audi A4Q 6MT
    Tuning: JHM Tuned Stage 2 93 Octane w/ IE HPFP
    Sep 28 2014
    your moms
    I would if I could drive the car. The brake caliper piston will not release at all. I cannot drive the car at all.
    Veteran Member Four Rings vvenom800tt's Avatar
    Dec 04 2011
    Kansas City, KS
    See if you twisted the brake line, of you flipped the caliper over you may have pinched the line, much like a garden hose.
    2005.5 Audi A4 Quattro 2.0T 6MT - APR - 034 - Custom 3" single exhaust - 17z Brembo - GFB - Alzor - Kumho - ST - Injen - Swift - Hyperco - ECS - Saikou Michi - PowerFlex - Podi
    Jun 27 2011
    if there is corrosion inside the piston, it could be binding in the bore now.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    I say remove the caliper and rebuild. It may be easier to replace however. A remanufactured caliper is ~$100.
    2019 SQ5 Prestige
    Dec 04 2011
    Kansas City, KS
    Also, did you clean off the slide pins and apply new UREA lube?
    DO NOT use brake pad grease on slide pins.
    And like Charles said piston might be corroded. Rebuilding is easy though
    Oct 16 2008
    South Florida - Ft Lauderdale
    Quote Originally Posted by texasboy21 View Post
    $43 to be exact + core
    Phil
    Sep 28 2014
    your moms
    Thanks for suggestions guys. It turned out to be a dumb mistake on my part. I forgot to put the wheel spacer on and the caliper did not clear the wheel. Luckily there was not too much damage done.
