Results 1 to 20 of 20
    Senior Member Three Rings Diesel S5's Avatar
    Nov 28 2017
    PA
    What can you tell me about these brake pads...
    I assume the fronts would be the same... looking to switch to a less dusty pad if possible...
    Senior Member Three Rings altobeast's Avatar
    Apr 09 2018
    WA
    Quote Originally Posted by Diesel S5 View Post
    I believe those are the OEM/Manufacturer recommended... look at the Hawk HPS street pads, same level of noise but I've heard much less dust.
    Veteran Member Four Rings Neil F's Avatar
    Jan 13 2017
    marlton/nj/usa
    Can't tell you what you have but Akebono have little to no dust. Soooooooo much better. I thought I would have to buy stock in Eagle 1 as I was using so much
    Established Member Two Rings tech30six's Avatar
    Sep 22 2016
    Kitchener-Waterloo, Ontario
    EBC Red stuff pads. No competition when it comes to bite and dust.
    Sent from my LG-H915 using Audizine mobile app
    Veteran Member Four Rings Ape Factory's Avatar
    Jun 24 2017
    RS5/Infiniti QX70S stormtrooper/Jeep Wrangler Rubicon 10th Anniversary
    San Antonio, TX
    I use EBC Red Stuff on the rears. Dusting isn't bad at all but I'd think front brakes would be a better indicator since that's where most of the braking is done. Unfortunately (for the sake of this thread anyway) I have ceramic fronts.
    Instagram: redmist5 Youtube; https://tinyurl.com/redmistvideos
    2013 Audi RS5 Misano Red-Klassen ID M10/JHM Tune/AWE Exhaust/Eventuri Intake/Bilstein PSS10/H&R Sways/STERN/CR-15//ECS SS Brake Lines/Rear Diff Bushing/ECS rear diff inserts, front end links/034 Motorsports subframe inserts & Rear End Links/Tranny insert/E-code head, tail lights/Maxton splitter/Red Trim Start Button/black emblems/VCDS.
    Veteran Member Three Rings snocat17's Avatar
    May 12 2017
    2016 S5 Cab, 2016 Mazda CX-5, 2012 Ford F-250
    Steel City, USA
    I went EBC RedStuff on all 4 sets of pads. So far SIGNIFICANT reduction in dust and only notice a slightly drop in bite. Noise is gone too.
    Highly recommend for the price! Order through ECS Tuning for a discount for being a forum member.
    -Joe
    2016 S5 Cabriolet Prestige Glacier White Metallic w/ brown comfort seats and piano wire black wood trim. RED Brake calipers holding EBC RedStuff pads, APR Carbonio Intake, ECS carbon fiber back-pipe, VCDS cable
    Veteran Member Four Rings NaiveTurtle's Avatar
    May 20 2013
    Vancouver, WA
    I have Ferrodo DS3500 on the front and Hawk 5.0 on the rear. The Hawk don't dust too bad but the Ferrodo's are slightly worse.
    2008 GMG World Challenge 6MT []S5 Ibis White Matte Metallic Purple/Black Alcantara
    [Mods - GIAC 91 Tune | GMG WC Sport Downpipes | GMG WC Sport Cat-Back | GMG WC Front & Rear Sway Bars | AP Racing 6-Piston Front BBK | 20x9.5 HRE P40's | Accuair B8 Sport Kit]
    2004 Ocean Blue Metallic A4 Avant
    Instagram: @NaiveTurtle
    Veteran Member Four Rings SLU_S5's Avatar
    Sep 06 2014
    Rochester, NY
    Quote Originally Posted by tech30six View Post
    EBC redstuff are a solid pad especially for the money.
    I prefer my Hawk HPS 5.0 to EBC though (yes, I’ve tried both). More expensive, but great wear rate, very quiet, minimal dust, and fantastic bite.
    2010 S5 Prestige 6MT: B.Black:
    APR: Intake // AWE: Touring + non-res DPs, S-Flo filter // CR-15: Brace // ECS: LWFW, Diff Mounts, SS Brake Lines // Eurocode: AK, Sways // JHM: Tune, Short Shifter // KW: H.A.S. // OEM+: B8.5 S-Line Competition+ Bumper, BO S5 Grille, Ecodes, RS5 BBK, 20" RS5 Rotors// SBC: Stg 2 Daily // 034 Motorsport: Intake Pipe, Trans & Motor Mounts, ACAs // Others...
    IG: @SLU_S5
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Hawk HPS and now 5.0 have been my "go to" pads for years. Low dust, great bite, no fade.
    Nov 28 2017
    PA
    So I think I’ll go with the Hawk 5.0 this time around and see how they fare...
    Thanks for the suggestions fellas...
    Oct 15 2017
    New England
    Let us know if the noise improved as well
    Veteran Member Three Rings mikedizzzo's Avatar
    Nov 03 2016
    So Cal
    Saw a guy do a review on this. I think he stated that it has a better bite.
    https://www.fcpeuro.com/products/aud...audi-vw-523351
    -MikeDizzzo
    2016 S5 Premium Plus | Florett Silver | Black Optic Plus Package | DSG | ADS | Carbon Atlas | B&O
    Mods: GIAC Stage 2 | TCU | SC Pulley | Bilstein B16 Ride Control Coilovers | AWE Touring Exhaust 90mm | Maxton V1 Front Lip | 034 Transmission Insert | Brakes - Hawks Pro with slotted/dimpled rotors | Relak Paddle Shifters | Ceramic Pro 9H | LED interior | 2 x Audizine 5' stickers | Audi All Weather Mats
    Established Member Two Rings AWDfreak's Avatar
    Jun 02 2016
    I'm a big fan of Red Stuff based on previous cars--virtually no dust, quiet, and good bite. Have not tried them on the Audi yet...
    2012 B8 S5 Prestige 4.2, 6MT, Phantom Black/Black
    Nov 27 2007
    NoCal
    So between EBC Red Stuff and Hawk HPS5... what has lower dust? and what would you pick overall?
    Jun 24 2017
    San Antonio, TX
    Most likely a crap shoot. I'd look at the specs, if available, and make a guesstimate based on those. It's tough to compare brake pads as most change them fairly infrequently and not back to back. Especially on a daily driver It's fairly rare that one would swap various brake pads in short order, enough so to have an opinion on quantifiable differences (opinion or otherwise) between two pads. I wish I had the time and disposable income to test various pads back to back.
    Senior Member Two Rings AWEs5's Avatar
    Jul 18 2017
    Gardena CA
    I have the Hawks HPS 5.0. Mated them brakeperformance.com slotted/dimpled rotors. I don’t like the pads. I had really high expectations since these were highly recommended by a few members on AZ and was really excited to try the new material. I don’t think the bite is all that great. They’re also noisy and squeaks a lot. The braking is spongy.
    Going from oem rotors and pads, which were almost near 5% of life left, I honestly don’t feel that much of a difference with the new set up. Maybe squeak a little less but it still feels spongy. Not sure about brake dust for the 5.0. I had them installed on Wednesday and haven’t washed my car yet. I’ll be cleaning them tomorrow and see how it dust is. I really feel like I wasted $1000 on parts and labor for the new set up though. Oh well. I’ll be going back to oem.
    2013 Audi S5 Premium Plus | H&R springs | AWE S-Flo CF intake | AWE Touring Exhaust 102mm Diamond Tips | AWE non-resonated downpipes |
    Nov 28 2017
    PA
    I ended up going with the EBC reds but won’t have them installed until next week... will report back...
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by AWEs5 View Post
    I'm really surprised to hear your poor review of the Hawk pads. I have always been very pleased with Hawk products. I have to ask, did you follow the recommended break in procedure? Clicky click®
    As to any noise from the pads, I have used this stuff for decades whenever I change pads and I have never heard a peep out of a brake pad.
    Jul 18 2017
    Gardena CA
    Had a reputable shop install them, also recommended from members on AZ. The mechanic bedded them in. I’d be surprised if they messed up installing brakes. What is the recommended brake in procedure? Like you said, I’ll give it another few weeks or so. But again not very impressed with the bite of these HPS 5.0.
    Dec 28 2006
    Western Maryland
    Check the Clicky click®. The purpose of the brake-in procedure is to put a deposit of brake pad material on the rotor. Go ahead and do it yourself. I suspect it may make a noticeable difference.
