    Account Terminated Two Rings
    Sep 28 2014
    your moms
    Wheel hub/bearing hardware question!!
    Ok so I am about to put the new hub and bearing on the spindle, but there is this circular metal ring that came with the new hardware. I know this ring goes in between the axle and the wheel bearing but I am unsure of the way it faces. I’ve seen many people not even mention this ring in DIYs. Help me out please!!
    Veteran Member Four Rings fR3ZNO's Avatar
    Feb 09 2013
    WNY
    Front or rear?
    "If one does not fail at times, then one has not challenged himself." - Ferdinand Porsche
    Veteran Member Four Rings RDA990's Avatar
    Jan 07 2013
    Germantown, Maryland
    My kit came with one as well, but I didn't use it.
    Brilliant Red B6 A4 1.8T quattro Ultrasport
    Frankenturbo F21L | Motoza Tuning | FMIC | Test Pipe | Bosch 550cc | 710n DV | Podi Boost Gauge | 21 PSI
    Dolphin Grey B6 A4 1.8T quattro
    Brilliant Red B7 A4 2.0T quattro
    Sep 28 2014
    your moms
    Front. It looks like some kind of cover maybe? I called ECS and they didn’t know either. I guess i just won’t use it. There was an old one I took out though. So I don’t know if it has any real purpose.
    Dec 03 2016
    nowhere
    It's a dust cover for the bearing. You need to just place it on the hub, flat side facing the hub, and the bearing over it before you press. You should use it to prevent the bearing internals from the elements better.
    HEAR
    APR stage 2
