Results 1 to 39 of 39
    Apr 23 2018
    Ottawa, ON, Canada
    RS4 shopping - questions
    Hi all,
    New here... I am in the market for a B7 RS4 and have test driven a few. I found one I like, but I'm curious about the condition of the carbon fibre engine covers.... they are definitely yellowed which I understand is normal, but they also seem quite "chipped". Is this in any way normal for this car?
    I've tried to attach a photo - hopefully it comes through.
    Any thoughts / comments are appreciated.
    Cheers.
    Dec 09 2016
    Charlotte NC
    Wow how many miles?? Those are in rough shape!
    2008 black rs4
    2001 nardo miata
    Charlotte, NC
    Dec 09 2016
    Charlotte NC
    My thing is if the engine bay isn't in good shape kept up with and clean what else isn't kept up with and clean?? Someone who is very picky about their engine bay chances are they are picky about everything as well
    2008 black rs4
    2001 nardo miata
    Charlotte, NC
    Apr 23 2018
    Ottawa, ON, Canada
    102k miles. It is a US car, was imported to Canada in 2009.
    Lot of work done to it very recently (nearly $5k), I have the invoice. Pretty sure it was neglected in a very recent past life.
    Veteran Member Four Rings dsgray16's Avatar
    Jun 11 2013
    Why do you like this car? What are the basic details?
    That’s one of the filthiest engine bays I have ever seen.. wouldn’t touch for that reason alone. Speaks volumes about care and maintenance of previous owner(s)
    And yes, that carbon is peaking and yellowed worse than normal IMO.
    Events: Time to register for Avantoberfest 2018!: www.avantoberfest.com
    Instagram: Audisport_Wagon
    Cars: Full B7 RS4 Avant swap http://www.audizine.com/forum/showth...S4-Avant-Build
    B7 RS4 sedan in Phantom Black - just a clean OEM+ daily driver
    Dec 12 2016
    Southeast
    These engine bays are HOT due to being sealed up mostly from the top. Those engine covers are known to yellow and even bubble/delaminate to a degree. I wouldn't take that as the single indication for an abused engine/car. My car has 50k on it and they don't have that grey carbon look that they have when they are new - just a little yellow. The rest of the engine bay looks new.
    Apr 23 2018
    Ottawa, ON, Canada
    - replaced both axle boots
    - replaced both left and right side valve cover gaskets (oil leak)
    - decarb while intake was off
    - new pads, rotors machined
    - replaced side engine mount, sensor was broken off, and sensor had been bypassed
    - installed new crank seal (oil leak from front crank shaft seal)
    - installed new aluminum intake manifold linkage pair, rebuilt intake plenum
    Not sure whether I should be happy this was all completed or scared that this was all completed
    Dec 09 2016
    Charlotte NC
    What's the history before all of that?any history??
    2008 black rs4
    2001 nardo miata
    Charlotte, NC
    Apr 23 2018
    Ottawa, ON, Canada
    Quote Originally Posted by dsgray16 View Post
    That's why I am asking. I'm new to this world, so not sure what's normal and what's not normal.
    The fact is, there are only about a dozen RS4s available for sale nationwide here - this one has a clean carpoof / carfax - a few others have frame damage; $20k accident damage; multiple reported accidents; a thousand owners.
    Thank you again, I do appreciate any input. Still learning.
    Apr 23 2018
    Ottawa, ON, Canada
    Quote Originally Posted by Keithpul View Post
    I don't have any prior history. Just saying that out loud, I'm realizing that's not good.
    Jun 11 2013
    Quote Originally Posted by steve-0101 View Post
    All good..
    Check out the car that just hit BringaTrailer.com. Looks clean.
    What’s your budget?
    Dec 09 2016
    Charlotte NC
    Carfax doesn't have any history on it? Like for maintenance? And yeah seems like your best bet lol I mean at least all of that stuff is new so that's the major things brakes and carbon cleaning, I had the same situation when buying mine had to eliminate the worst of the worst and settle for one that seems best haha
    2008 black rs4
    2001 nardo miata
    Charlotte, NC
    Jun 11 2013
    This is my 147k mile car.. the carbon is yellowed, but the bay is clean.. you want to look for a car with an extensive maintenance history, preferably with multiple documented carbon cleaning services done.
    Jun 11 2013
    Plug for a friend.. super clean well documented car..
    https://www.facebook.com/groups/ACNA...78743472279331
    Veteran Member Four Rings b6bydesign04's Avatar
    Nov 14 2005
    Charlotte, NC
    Yellowing is definitely common, bubbling a little less common.
    [IMG]https://uploads.tapatalk-cdn.com/20180424/c2e9a6c03baf0e4c4ca20d9233e35aa9.jpg[IMG]
    Super clean and well maintained car, and in case OP doesn't have FB, he's posted it here as well: https://www.audizine.com/forum/showt...2K-Miles-CT-MA
    -Sean
    '06 Lexus GX470 | Dobinsons | fifteen52 | BFGoodrich | Prinsu | Gobi | Orangeboxx | RSG
    '11 BMW E90 M3 | ESS S/C | Recaro | M Performance | iPE | BC Racing | BPM | Volk | Coby
    F.T.W.L.T.B.D.W.I.C.T.W.
    Veteran Member Four Rings musanoadsaba's Avatar
    Jan 24 2009
    2007 Ibis RS4
    Rockies
    That is all fairly normal stuff. The rotors being machined is a bit odd. These rotors thin out and usually get replaced rather than being machined.
    The state of that engine bay is brutal though. dsgray's is what I would want to see or a little dirtier, b/c his is really nice.
    Veteran Member Four Rings R&Cs4's Avatar
    Oct 19 2009
    Damn Dan, what do you use for detailing the black trim?
    '11 S4 6MT
    '58 Auto Union 1000
    '60 Auto Union 1000 SP
    '54 Corvette
    '64 GAZ 69M
    '47 Lincoln Club Coupe
    Atlas R-Line
    IG @this_is_r0b
    Jun 11 2013
    Quote Originally Posted by R&Cs4 View Post
    A good degreaser and then Adam’s VRT
    Apr 23 2018
    Ottawa, ON, Canada
    Thanks - I'd rather not get into importing as that is another can of worms, not to mention our Canadian dollar is not so hot.
    - - - Updated - - -
    Wow. That thing shines!
    Apr 23 2018
    Ottawa, ON, Canada
    Here are a few other pictures of it that I took... Seems clean (except for the engine bay), though the wheels have been refinished in black (which I rather like).
    Veteran Member Four Rings CoreyRS's Avatar
    Aug 07 2009
    Ca
    Engine bays can be cleaned, I would be more concerned with the state of carbon buildup.
    Dec 09 2016
    Charlotte NC
    Quote Originally Posted by CoreyRS View Post
    He said it got carbon cleaning with all that other maintenance
    2008 black rs4
    2001 nardo miata
    Charlotte, NC
    Apr 23 2018
    Ottawa, ON, Canada
    Invoice says carbon was cleaned when intakes were off, which was a few hundred miles ago... that’s all I have to go on.
    Dec 09 2016
    Charlotte NC
    Looks clean in these pictures, I mean if only bad thing you can find is some yellowed carbon covers and not spotless engine bay I think you're doing pretty good.
    2008 black rs4
    2001 nardo miata
    Charlotte, NC
    Jun 11 2013
    That’s kind of my point.. if the owner didn’t bother to do that, what else didn’t they bother to do?
    Jun 11 2013
    Car looks clean.. didn’t realize you were in Canada.
    Dec 09 2016
    Charlotte NC
    Is your search limited to distance?? There are some decent ones out there and personally better than black, mines black and I wish I could have found one in any other color but if you like black then it works
    2008 black rs4
    2001 nardo miata
    Charlotte, NC
    Apr 23 2018
    Ottawa, ON, Canada
    I’d like to stay within Canada if possible. Luckily, most cars are near Toronto, about 4 hours from me. The one I posted above is local.
    For reference, that car is listed at $28k CAD, or around $22k USD. Most cars here are $20-35k CAD ($15-$27k USD).
    Dec 09 2016
    Charlotte NC
    Yeah that's about average here as well, and I see yeah I guess it limits you a little bit more
    2008 black rs4
    2001 nardo miata
    Charlotte, NC
    Active Member Two Rings In4cus's Avatar
    May 18 2016
    2009 A6 Prestige, 2010 BMW 328xi, 2017 Ford Flex
    Dingmans Ferry Pa
    Your going to find very few used cars that have had OCD owners. If that's what your looking for, then your going to have a hard go at it. Buying used, usually means your going to be fixing or replacing something yourself. If you don't want that, then you'll have to buy new. That particular unit LOOKS good. It is a roll of the dice man, you have to look at yourself and decide if your ready for it. How is the interior? That's another indicator of a neglected car.
    Sent from my 5049W using Audizine mobile app
    Apr 23 2018
    Ottawa, ON, Canada
    Quote Originally Posted by In4cus View Post
    Interior is clean. It's actually in very good shape.
    At this point, the things that are an issue for me are:
    - US vehicle (affects resale here in Canada)
    - No service history, except the latest invoice mentioned
    - CF engine covers look like they were acid washed
    Other than that, it seems to drive well.
    I think I know the answer to this already, but are the CF engine covers available anymore? I can't seem to find them anywhere.
    Apr 23 2018
    Ottawa, ON, Canada
    One other question, regarding steering. The steering feels very heavy at anything above, say, walking speed. Is this normal? It's heavier steering than I've experienced before.
    Nov 14 2005
    Charlotte, NC
    I believe they are available thru ECS Tuning, just currently back ordered (and also quite expensive):
    Front Cover - https://www.ecstuning.com/b-genuine-...nt/079103950a/
    Rear Cover - https://www.ecstuning.com/b-genuine-...ar/079103926m/
    Also worth noting, sometimes they pop up on eBay or here on the forums. This decently clean set recently sold for $120.50 on eBay:
    https://www.ebay.com/itm/Audi-RS4-In...53.m1438.l2649
    I think @KuhlRennsport might also be working on a aftermarket option as he's done something similar for the RS5, see this post:
    https://www.audizine.com/forum/showt...1#post12959865
    -Sean
    Veteran Member Four Rings Fourplay's Avatar
    May 01 2010
    Atlanta
    The steering is assisted at low speeds to make maneuvering easy. Above 10mph or so, the assist falls away so the ratio/heft is more appropriate for a performance car.
    2005 Ferrari F430
    2007 RS4 Daytona Grey | 2008 RS4 Mugello w/Ti Package | 2007 RS4 Avus Silver (ex-Audi Corporate) | 2008 RS4 Avus Silver w/Exclusive Package
    B6 S4 Avant 6MT Dolphin Grey
    B5 S4 Avant 6MT Laser Red Stage 3+
    B5 S4 Sedan 6MT Silver Stage 1
    Apr 23 2018
    Ottawa, ON, Canada
    Quote Originally Posted by Fourplay View Post
    The steering is electronically assisted at low speeds to make maneuvering easy. Above 10mph or so, the assist falls away so the ratio/heft is more appropriate for a performance car.
    Makes sense... thanks!
    Apr 23 2018
    Ottawa, ON, Canada
    Just wanted to say thanks for everyone's input. Yesterday I became the proud owner of my 2007 Mugello Blue RS4.
    Sent from my SM-N950W using Tapatalk
    Nov 14 2005
    Charlotte, NC
    [IMG]https://uploads.tapatalk-cdn.com/20180512/f6d07440f827c087877aa9be22d2d962.jpg[IMG]
    Congrats and welcome man! Any immediate plans?
    -Sean
    Apr 23 2018
    Ottawa, ON, Canada
    Quote Originally Posted by b6bydesign04 View Post
    I'm gonna drive it like I stole it! :)
    Veteran Member Four Rings jonan's Avatar
    Nov 25 2006
    2X B7 RS4 - STG III B6 A4 (gone, but still in the family) - Mini R56 S - '15 Macan S - 997.1
    Austin, TX
    nice, welcome to the club, car looks clean!
    Want my guns??? ΜΟΛΩΝ ΛΑΒΕ!!!
    B6 Mods:
    Fully Built Motor w/ GT2860RS and all supporting mods : My Build Thread
    RS4 Mods (sprint):
    RNS-e MKII : ECS SS : JHM Spacers : Deflapped IM : UM Tune : KW V3s : Tubi Rumore : Hotchkiss F&R SBs : 034 Diff Inserts : Phil Special Headlights w/ STI Lenses : 10 Layers : Spare 07BNS (#masterrace) : Apikol Diff & Trans Mount
