Results 1 to 6 of 6
    Mar 06 2014
    Norway
    A6 C5 Drivers door will not open from outside, just from inside
    So I have a problem with my A6 C5.
    Drivers door will not open from outside, just from inside.
    Do I need to change the lock mechanism, or can it be something else that is causing this?
    Veteran Member Three Rings AudiNike12's Avatar
    Oct 10 2017
    Sweden
    Remove the door panel and see what's going on. Sounds like something is up with the lock mechanism. Maybe the pin between the handle and the latch?
    Audi A6 Allroad 2.7T -04
    Audi A6 2.4 Sedan -04
    Audi A6 3.2 Sedan -05
    Audi TT 1.8T -99
    Veteran Member Four Rings m_haiser's Avatar
    Apr 24 2011
    2012 A6 Prestige, 1998 Jeep Cherokee XJ
    Central Willamette Valley
    yeah no for sure answers until your pull the door panel off. should be fairly obvious once you do
    Sep 11 2009
    NE
    Could be a detached pull cable. But if the door mechanism is shot, like it normally is, you're into some serious disassembly because to replace these is real PITA.
    Mar 09 2008
    Torrington, CT
    Try pushing on the top of the handle as you pull it up. Seems to work for my C5. One of these days I know that’ll stop working though.
    Apr 07 2018
    SF Bay
    On a recently acquired S6 Avant, I have already changed 3 door lock modules and the rear latch module... Anyways, the fault is probably in one or more of the circled areas in the pic.
