Results 1 to 13 of 13
    Senior Member Three Rings altobeast's Avatar
    Apr 09 2018
    WA
    Very rough idle RS5
    I have a 40k miles RS5 that I recently acquired, had inspected by 3rd party and got the green light mechanically. I have noticed that for the first 20-30 seconds on cold start, there is this harsh rattling noise as if something mechanical is rubbing or being shook around. Others have noticed this noise, but it goes quiet as a mouse after 30 seconds, into a pleasant and constant idle, no surging or pulsing or vibration. The start up is not accompanied by vibration, belt/chain noise, or anything like that.
    Is this normal to have something like occuring? Would my Audi dealership be able to take a look and get this fixed or is it generally a problem that they'll say "happens" and charge me the diagnostic? I might try and run a Vagcom to see if any misfires are occuring, but have not yet.
    Anybody else in the same boat?
    Jul 28 2007
    RS5
    gta, ontario
    Sounds like a normal cold start.. ?
    Mar 24 2018
    Private
    Can you post a video or audio clip?
    Apr 09 2018
    WA
    I wasn't sure, I just recently got this vehicle and upgraded from a econobox, so this whole thing is new to me. It sounds rougher than I would like, but I have not had a reference to compare to.
    I'll get a noise clip once it cools down from my commute in a few hours.
    Mar 24 2018
    Private
    I wonder if this is exhaust rattle if something is loose. Try revving it up in park and see what you hear. Drive with the windows down and listen carefully. Pop the hood, fire it up, and listen. Check for smells and leaks under the car. If everything checks out and you aren’t throwing codes, depending on how bad it sounds, I may not worry about it. Cars will have some rattle to them.
    Apr 09 2018
    WA
    Quote Originally Posted by 2012s5cj View Post
    Thank you, I will do just that! No codes, may actually be exhaust rattle which is aggravated by the vibrations during a normal cold start. No leaks that I can see and I will smell today.
    Mar 24 2018
    Private
    No problem, man. Hold off going to the stealership until you try some of this stuff and save your $$$. The audio clip should be very telling.
    Veteran Member Three Rings Delasangre4231's Avatar
    Nov 22 2012
    Portland, Oregon
    I just got my first RS5 too and when I cold start mine it does kinda make a weird sound while it holds the RPM at 1500 or so for the first 30 seconds, to me it almost just seems like a miss-fire or like a little pop in the exhaust from the extra cold start fuel, I assume its normal as the car is amazingly smooth after the first 30 seconds.
    -2016 VW GTI Autobahn Performance pack DSG
    Michelin Pilot Super Sports, APR Carbon Fiber Intake, APR Stage 1 ECU tune
    -2003 VW Golf 2.0 5-speed SOLD
    -2013 Audi RS5 Phantom Black Pearl SOLD
    Michelin Pilot Sport 4S, ECS Brake lines with Motul RBF600, ECS X-Pipe, Leyo Motorsports paddle extensions
    -2003 Audi A4 Avant, 6MT, 3.0 V6 SOLD
    B6 S4 front brakes, JHM stainless brake lines, Straight Pipe - http://youtu.be/7zsiB7rT1fo
    Veteran Member Four Rings namvar's Avatar
    Jul 10 2014
    2024 SQ8 Prestige, 2018 A4
    SF Bay Area
    mine's pretty smooth. At 40K it should still be under warranty.
    2015 RS5: Mythos Black, Tech Package , Dynamic steering, Black Optics, Folding side mirror upgrade, internal LED lights, Eventuri Intake, Akrapovič exhaust, KW DDC ECU, lots of CF
    2013 3.0T Prestige Q7: Sport pedals, LED interior lights
    Apr 09 2018
    WA
    Quote Originally Posted by namvar View Post
    It's fairly smooth, just cold started again but didn't get a video :( . It is not under warranty due to time, but it seems more like fan and blower noise, I was in a garage before and it definitely amplified the noise. Some mechanical noise, but nothing super excessive, I believe it's a loose exhaust which is making some noise.
    Veteran Member Three Rings Sazexa's Avatar
    Jul 15 2017
    Colorado
    If it's idling rough at that mileage, and more so at start up, it could be an indicator of carbon build up.
    Apr 09 2018
    WA
    Quote Originally Posted by Sazexa View Post
    Smooth as silk normally, just the first 30 seconds. How would I go about diagnosing that, I know that Audi has put up resistance on that problem.
    Veteran Member Four Rings Ape Factory's Avatar
    Jun 24 2017
    RS5/Infiniti QX70S stormtrooper/Jeep Wrangler Rubicon 10th Anniversary
    San Antonio, TX
    It's most likely just the cold start routine. Depending on what ECU firmware you're running, you'll get pops and crackles as it's dumping in fuel to heat the cats up quickly. The gas can ignite on the catalyst. The rattle could be a heat shield. But it definitely mean and grumbly on cold start and then should settle into a nice smooth idle.
    Instagram: redmist5 Youtube; https://tinyurl.com/redmistvideos
    2013 Audi RS5 Misano Red-Klassen ID M10/JHM Tune/AWE Exhaust/Eventuri Intake/Bilstein PSS10/H&R Sways/STERN/CR-15//ECS SS Brake Lines/Rear Diff Bushing/ECS rear diff inserts, front end links/034 Motorsports subframe inserts & Rear End Links/Tranny insert/E-code head, tail lights/Maxton splitter/Red Trim Start Button/black emblems/VCDS.
