Hey guys I have 2008 a4 b7 with the 3.2 manual 6 speed in it with 162 k km. Car has been running fine other then occasional misfire on cylinder 6. I get the famous won't start on first try occasionally. So today I went and refueled cause tank level got to just under quarter tank. Filled up until it clicked off. Then my ocd kicked in cause I saw 54.2 l on pump and I continued to fill till I saw 55 even. Anyhoo immediately after tried starting and it just cranked over so i reset key and it fired up. Got about 20 ft and car starting stumbling and jerking with no power so i coasted to empty area to let It idle where it then proceeded to run rough and stall. Reset key started it and idled just fine and I drove off. No cel light or any other after affects.
I have recently done intake chemical clean,oil change, air filters, tightened my valve covers down which were leaking into spark plug holes,changed all driveline fluids. Coils are the d series p/n
Any ideas if I should be looking at evap system or ignition as possible Culprit?
Sent from my SM-G950W using Audizine mobile app
