    Junior Member Two Rings PrestigeA4's Avatar
    Nov 11 2017
    Westbury, NY
    Trunk won’t open - fuses all good - replaced Actuator Still nothing - now what?
    I’ve researched for days, I’ve tried every version of this that I’ve read so far - I just spend 2 hours retrieving the cable through the under panel trying to put everything back together in the dark. Here are the facts.
    Door soft touch - nothing no sound
    Rear outer button - nothing no sound
    Key fob button - nothing only sound is 3 clicks from region near fuses in the trunk - pulled every fuse because I can’t find an accurate fuse chart and they’re allllll good.
    Replaced actuator - still nothing - so since it’s not that I have a perfectly good working actuator I’m willing to sell since I won’t need 2.
    What now ?
    Established Member Two Rings Calderone's Avatar
    May 31 2016
    Valet button pushed in the glove box? That will cause trunk to not open
    Nov 11 2017
    Westbury, NY
    Quote Originally Posted by Calderone View Post
    I ripped the trunk apart 3 times .... I never even knew about the valet button - I’m too pissed off to even be happy about this haha - anyone need a fresh new actuator ?
    Thanks dude.
    May 31 2016
    Quote Originally Posted by PrestigeA4 View Post
    Thanks dude.
    No problem haha. I had the same problem but never really used my trunk so it didn’t bother me. I then read about the valet button somewhere and mine was on so I turned it off and it worked. Sorry to hear you went through all that mess, that kinda sucks. But I’m glad it works now!
    Active Member Four Rings Nano909's Avatar
    Jul 25 2016
    California
    Had this issue too, turned out the Valet button in the glove box was pressed. Depress it and it should open.
