Results 1 to 11 of 11
    Established Member Two Rings 2stroke's Avatar
    Jun 01 2009
    SWEDEN
    Question Ignition Coil advice... ?
    Hi !
    I'm in need of some Ignition Coil advice
    My 1.8T have the Audi/VW part # 06B 905 115 R Ignition Coils.
    Now I have some trouble with two of them and I was thinking I should replace them all but to what ?
    Should I just repalce with the same or should I looking for some other version ?
    // Regards from Sweden.
    Apr 12 2018
    Camarillo/CA/USA
    The Audi part number is good, since you are in Sweden, there are probably plenty of aftermarket replacements available and s/b around $100 USD. In the USA we have Ebay and preferrably Amazon and here is what that part number search returned to me
    http://www.amazon.com/s/ref=nb_sb_no...=06B+905+115+R
    Jun 01 2009
    SWEDEN
    Question
    Quote Originally Posted by AudiA4B61.8T View Post
    The Audi part # is good, since you are in Sweden, there are probably plenty of aftermarket replacements available and s/b around $100 USD.
    In the USA we have Ebay and preferrably Amazon.
    I have no trouble finding where to buy the Ignition Coils !
    According to Audi/VW dealer the version that I have # 06B 905 115 R is not valid any more !
    It's superseeded with # 06B 905 115 D which is the latest version.
    ...but on many Audi/VW Forums I read that many owners of 1.8T engines recommends and prefer the bolt down type of Ignition Coil # 06B 905 115 E instead.
    ( That part # is still valid )
    Can someone enlighten/explain more for me ?
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Save your money and get the D version. They will perform just fine
    Jun 01 2009
    SWEDEN
    They will perform just fine.
    They have the same price, so the price is not crucial.
    Veteran Member Three Rings mariosa4's Avatar
    Sep 26 2009
    peugeot 106 xr
    Greece - Korinthos-Athens
    Get the R8 coils with code 06E905115E together with a spacer, they won't fail under boost or heat even on bt setups
    Dec 28 2006
    Western Maryland
    Coil packs used to be a common problem with the earlier B6 1.8T's. I went through several revisions before I purchased a set of D's which is still the latest "official" coil pack. I installed them back in 2009 and they have performed flawlessly ever since. Clicky click®. I ran them with the GIAC big injector file and I am still running them today with my current F21L set-up.
    R8 coil packs and hold downs will certainly work but on a stock or lightly modified 1.8T I really don't think it will make any performance difference at all. Same price? Go for it. Otherwise the D's will perform just fine.
    Veteran Member Three Rings 9744RR's Avatar
    Sep 01 2005
    2016 A6 3.0T, 2003 A4 1.8T Tip, GTRS Elim, REV0, 440 injectors, ASP front mount, etc Porsche 356
    I agree w/OG ^^^ Go with the D's. Been using "D" version (w/sidefire Bosch plugs) for years on my GTRS Stage 3 and have had no problems.
    2016 A6 3.0T Stock
    2003 A4 1.8T Q TIP not stock
    Porsche 356 Stock
    Apr 12 2018
    Camarillo/CA/USA
    Do you have need for the mounting ears of the “e” if not just stick with the “d” part...JMHO
    Mar 05 2013
    CA
    Post-recall 3.0L coils might end in 'M'. I wonder if it's just because they're red, to look cool on a V6 engine where they're visible.
    Whereas black or grey ones on a 1.8T, are hidden underneath the engine cover up top.
    Curious to know how OP figured out his have issues.
    Currently running NGK Iridiums on a stock engine.
    I feel like I've seen those bolt-down ones on older Audis. B5 1.8T, 2.7T, etc.
    Jun 01 2009
    SWEDEN
    Save your money and get the "D" version.
    Quote Originally Posted by 9744RR View Post
    Go with the D's.
    Do you have need for the mounting ears of the "E" ?
    If not just stick with the "D" version.
    I have ordered four new 06B 905 115 D
