Results 1 to 14 of 14
    Veteran Member Three Rings srcrash715's Avatar
    Jul 15 2011
    VW MQB Tiguan, VW Rabbit. HD Street Bob, Mercedes E320 CDI
    Frederick/Maryland
    B7 S4 JHM Valvetrain, Heads, Tools, Timing and such
    Up for sale is all of the parts I bought to rebuild the engine that had scored walls, I ended up buying a new (used) motor and going that route as I just didn't have the time to do a full engine rebuild. Prices do not include shipping. To give you an idea on shipping I am at 21701.
    JHM Intake and Exhaust Valves - $700
    - I finished installing these on one head and fully reassembled it but it was never installed and/or ran
    JHM Retainers and Springs - $850
    -Same as the valves, one head has them installed the rest are in the the bags as they came
    B7 S4 Cylinder Heads - $400 for the pair
    - I can finish installing the valvetrain on the 2nd head and we can work out a price there if you are interested
    - Both heads have intake and exhaust valve seals on them
    - Have been kept in plastic bags and were removed for pictures
    JHM Reseal kit for upper oil pan - $300
    -got a new engine so dont need these
    -currently at the shop doing the work so wont be able to get until this weekend possibly the next
    JHM Camshaft Adjuster Pair -$600
    -engine had new camshaft adjusters in it so wont be using these, also these are at the shop that is doing the work so cant get them until the weekend possibly the next
    OEM Piston Rings for 8 pistons -$600
    -were installed on pistons but never ran
    ECS Tuning Timing Tool - $100
    CTA Valve Spring Compressor Tool -$55
    Steel Tie Tightening Tool -$make offer
    BHF Core -$ make offer, will not ship
    -spare core I bought to swap everything over too, good shape no issue with cylinder walls
    Crankshaft -$make offer will not ship
    Cam tower bolts- $make offer
    -enough for 1 head, may get used to complete 2nd cylinder head
    I also have the valley pan, oil filter housing, PCV valve, intake manifold, throttle body, MAF, coil packs, fuel injectors (cleaned with new orings and flow tested), fuel rail, timing chain tensioners, timing chain tensioner gaskets, SAIC gaskets, timing chain tensioner control housing, front and rear crank seals, new head gaskets, valve covers, everything from the bottom end and a fuel filter. Feel free to make offers on any of those and I can also send pictures of them as well.
    I have additional parts that I will list as I finish going through everything.
    Current: Sprint Blue MT B7 S4 Avant
    Mods: OCarbon Reflexive Silver Trim | VMR 701 19x9.5 with 265/30 Yokohama Advan Neova's with a wee bit of rub
    R.I.P. 2005.5 BAT Quartz Gray Tip
    Jul 15 2011
    Frederick/Maryland
    Spacers and timing tools pending sale
    Sent from my SM-G950U using Tapatalk
    Veteran Member Four Rings Pat_McGroin's Avatar
    May 09 2010
    Downey Ca
    Interested in coil packs, are they new or used and what brand?
    Rick
    B5 S4 StageIII
    Sold:Brilliant Black 2008 S4 Avant Tip.
    Gone but never gottin - Ibis 2010 A3 2.0T
    Jul 15 2011
    Frederick/Maryland
    I have been out for a bit so apologies for the late replies to everyone. All PM's have been answered.
    The timing tools and spacers are available.
    @Pat_McGroin the coil packs are OEM and used, they have 10k miles on them.
    May 09 2010
    Downey Ca
    Quote Originally Posted by srcrash715 View Post
    No worries brotha. Sweet, will the spacers included the extended bolts?
    Rick
    B5 S4 StageIII
    Jul 15 2011
    Frederick/Maryland
    Quote Originally Posted by Pat_McGroin View Post
    They sure do.
    May 09 2010
    Downey Ca
    They sure do.
    Incoming PM...
    Rick
    B5 S4 StageIII
    Jul 15 2011
    Frederick/Maryland
    Spacers pending sale
    Active Member Two Rings PolskaWagon's Avatar
    Jun 26 2018
    South Bend IN
    Interested in the timing tool and Jhm cam adjusters. Does the tool kit include the crankshaft lock pin tool?
    Mar 21 2017
    PM sent!
    May 16 2018
    Center Valley, pa
    Cam adj still avail?
    Aug 03 2016
    Cam adjusters? Pm me
    Jul 15 2011
    Frederick/Maryland
    TTT
    Original post updated, life got in the way so apologies if you messaged/responded here and I didn't get back to you.
    Dec 19 2014
    Salt Lake City
    Pm incoming
