Results 1 to 16 of 16
    Apr 21 2013
    st louis, mo
    Tons of extra parts for sale
    Set of stock headlights(one has factory ballast other one has aftermarket ballast missing one headlight bulb) all tabs intact have another aftermarket ballast to go with it. $100. SOLD
    H&R front coil springs$50 SOLD
    Stock ko3 turbos (one in good shape other oil seal blown out 130000miles on both) and stock exhaust manifolds$100
    Black grill insert $30
    6 factory rims(1 plastic dipped in black 5 silver some tires ok some tires bad) with lugs $200
    Silver trunk license plate lights $30 SOLD
    Box of miscellaneous parts(hoses fuel filter timing belt heat Shields) $20
    Stock ecu$100 SOLD
    Jhm tcm( does not work but all you have to do is send it in to them to get it fixed no charge they said)$50
    License plate bracket front $10
    Factory plastics engine covers$50 sold
    Buyer pays shipping or pick up PayPal only
    Can text email you pictures. Not on here much so quickest way to get ahold of me is by text
    6one8seven794one49
    Rob
    Established Member Two Rings TooDamnFresh's Avatar
    Feb 05 2018
    Bay Area
    What type(letter) model is the ECU?
    2001 Audi S4 - Nogaro / Alcantara - Weekend/Project
    2017 Toyota 4runner TRD PRO - Cement - Daily
    Apr 21 2013
    st louis, mo
    It’s a j code
    Junior Member Two Rings vitaha's Avatar
    Jul 15 2010
    Sacramento, CA
    Do you have oem downpipes for a 6 speed?
    Apr 21 2013
    st louis, mo
    Quote Originally Posted by vitaha View Post
    Not to be rude but is there pipes for sale in the add? So no
    Apr 21 2013
    st louis, mo
    Make offer want goes guys
    Established Member Two Rings WolfGanG13's Avatar
    Jul 15 2017
    Long island,New York
    Pics of stock rims?
    Apr 21 2013
    st louis, mo
    Quote Originally Posted by WolfGanG13 View Post
    Pics of stock rims?
    Can you message me your number and I’ll text you a few pictures. That will be the easiest way
    Apr 21 2013
    st louis, mo
    Bump. License plate light rear sold.
    Apr 21 2013
    st louis, mo
    Stock ecu sold
    Apr 13 2017
    '02 B5 S4 ,'00 ML 430, '91 Honda Nighthawk
    Germantown, Md
    Quote Originally Posted by rlelly327 View Post
    Stock ecu sold
    Still have headlamps?
    Apr 21 2013
    st louis, mo
    Quote Originally Posted by kraut_burner View Post
    Yes I do.
    Apr 13 2017
    Germantown, Md
    I really just need a ballast. Any of those? Shipped to 20874 if you do. Thanks
    Apr 21 2013
    st louis, mo
    Headlights are sold
    Senior Member Two Rings Isaac313's Avatar
    Aug 15 2017
    2008 Ford F350 Diesel - 2000 Audi S4 - 1994 Ford F150 Lightning
    Michigan
    Are the H&R springs lowering? How low? I would definitely be interested in those. Hopefully they have about the same spring rate as stock?
    Apr 21 2013
    st louis, mo
    Bump. Make offer on parts
