Results 1 to 27 of 27
    Established Member Two Rings sxC's Avatar
    Feb 12 2013
    2000 S4, 2012 S5
    Santa Monica, CA
    Where is everbody mounting their gauges these days?
    I have an AFR, boost, and aquamist methanol controller gauge to mount in the car but I don't really see any good options anymore for a clean mounting solution. The boost and the AFR gauges are 52mm, the aquamist gauge is smaller, I think 45mm.
    Boost gauge is currently mounted on the steering column with a podi gauge pod, and I thought about doing a dual-pod from them but they don't sell them anymore.
    ECS has a 52mm vent pot for the center vents, but I don't really like the solid plate design which blocks the air flow through the vent. The color also seems off. They have one which does not block the flow through the vent, but that only comes in the smaller size.
    I've tried chopping up the plastic and making my own but it just looks sloppy, hoping for a cleaner solution. Anyone want to post up how they did theirs?
    Jan 01 2018
    utah
    I am mounting 2 on the dash as far to the left as possible and one in a column pod
    Senior Member Three Rings Teck09's Avatar
    May 11 2017
    WA
    I just cut my stock heater vent to fit my gauge. Go slow and it looks fine.
    Established Member Two Rings Dr Awesome's Avatar
    Aug 21 2017
    Minneapolis
    I have an AEM boost and A/F gage each set up behind the wheel. There is also a methanol controller that hangs out on the left side of the wheel coming up from the kick pannel, I want to mount it up to the left of the oil temp sensor with some double stick tape once I re install the system. I have it just sitting there for the picture right now. It's wired but the system is not installed.
    Imgur:
    https://imgur.com/a/96zwlBT
    Veteran Member Four Rings JustManson's Avatar
    Oct 11 2016
    Connecticut
    Quote Originally Posted by Dr Awesome View Post
    Imgur:
    I like that dual pod from ATI.
    Been considering a new pod myself because I need an A/F gauge and that looks like a great option.
    How’s the fit?
    Aug 21 2017
    Minneapolis
    Quote Originally Posted by JustManson View Post
    How’s the fit?
    I can't say how hard it was to fit, the PO put it in. I can say that before this I had a center vent mount AWE boost gage that I liked very much, but this setup has absolutely grown on me. As far as blocking the tach and spedometer, picture #2 is a pretty good indicator, visibility is slightly better than in the picture from where I sit, but the gages can be swiveled about. I don't have any issues with it.
    Nov 16 2014
    ovid ny
    I got my boost and aem wide band in the heater vents. I want one more gauge but I might break down and fiberglass it. But I keep looking at the ash tray as a waste of space and would love to mount them in there
    Just pull the ash tray out and get a peace of dimond plate I think it would be a little small for 52mm gauges. But you could also put it at an angle to see better and give you the inch if more room to you might need.
    Just a thought I wish there was more hours in a day
    A true sign intelligence is not knowledge but imagination
    Aug 24 2014
    Newport Beach, CA
    Here's where mine are, I didn't want to take up any additional vents because it gets hot in Socal and having the AFR gauge right in front of me makes it easier to monitor. I use the Podi steering column gauge pod.
    2024 M3 Comp xDrive
    Senior Member Two Rings WEBER's Avatar
    Jul 01 2008
    Imola B5 S4 ,90 CQ 20vt KTM Superduke
    Portland, OR
    I used all three vents but didn’t like three different gauge styles so I fit a PODI gauge bezel to my aqua mist.
    2001.5 S4 Imola
    Feb 12 2013
    2000 S4, 2012 S5
    Santa Monica, CA
    Quote Originally Posted by christianb5s4 View Post
    I use the PODI column for my boost gauge, what size is your vent pod, 45mm?
    - - - Updated - - -
    Quote Originally Posted by WEBER View Post
    See that looks really clean as well. What size are your gauge pods?
    Veteran Member Three Rings cinimod25461's Avatar
    Dec 04 2013
    CA
    I used two center vents. AWE boost gauge and AEM afr gauge.
    Jun 07 2005
    Shepherdstown, WV
    Quote Originally Posted by jimmer009 View Post
    It would be in my C5 but Ive been thinking about removing the ashtray and then molding a holder for 2 gauges into the space but lending the actual face/surround into the shifter trim to make that one piece.
    80 rabbit pickup, 98 TJ 4bt cummins, 00 180TTQ 6spd, 02 Freelander, 03 Allroad 2.7t 6spd swap now with K04s, 06 A3 2.0T w/GT3071R (2012 JSW TDI and 2015 GSW TDI now in TDI purgatory )
    Jun 14 2007
    2000 S4
    Connecticut
    How do you like the Podi gauge? Have they gotten quicker to react? I remember when I had one I didn't like how laggy the electronic boost gauge was.
    Aug 24 2014
    Newport Beach, CA
    Quote Originally Posted by sxC View Post
    Correct, mine is the ECS product but I can't find it on their site sold individually anymore. Of course many people go the DIY route and trim out a stock vent to accommodate a gauge.
    https://www.ecstuning.com/b-ecs-part...001576ecs01kt/
    2024 M3 Comp xDrive
    Feb 18 2013
    Silicon Valley, CA
    This. I went to Pick-N-Pull, got 3-4 vent sections, and tried a few methods to get it cut just right. Took about 2 hours total, and the gauges were installed very well.
    Senior Member Three Rings dalazybastard's Avatar
    Apr 08 2016
    Orange County, CA
    I haven’t done it personally, but will do it when the time comes on my 1.8t.
    Another option I haven’t seen posted yet is the defroster vent pod.
    Projectb5 has one.
    Also there was a 3d print file going around a few months ago.
    Just a couple B5's, you know.
    Veteran Member Four Rings xalents23's Avatar
    Oct 26 2011
    CA
    Here’s my gauge setups.
    Feb 18 2013
    Silicon Valley, CA
    Quote Originally Posted by xalents23 View Post
    Based on your variety of set-ups, which locations are easier to view/more convenient?
    Oct 26 2011
    CA
    Quote Originally Posted by Tumbler510 View Post
    I would say this was the best setup for my viewing/monitoring. Since, I got everything I needed to monitor in one gauge. But, everyone has there own opinion and preference.
    Jul 01 2008
    Portland, OR
    It definitely not as quick as a mechanical gauge, but it gets the job done. I do prefer mech but like the podi because it just had a small connector and is programmable.
    2001.5 S4 Imola
    Jul 01 2008
    Portland, OR
    - - - Updated - - -
    All 52mm, but no pods just cut out vents
    2001.5 S4 Imola
    Senior Member Three Rings WanaB5's Avatar
    Jun 14 2017
    Manchester, NH
    I have the P3 gauge and love it, looking to add an afr in the center vent or steering column next.
    Jul 04 2012
    Woodbridge, VA
    Home brew
    Feb 12 2013
    2000 S4, 2012 S5
    Santa Monica, CA
    I went ahead and tried cutting up a spare vent, it looks okay. I'd love for all the gauges to look as close to same as possible though, I might try those bezels too. You said you got them from PODI?
    Thanks for all the feedback everyone. I'll post pictures of mine when I'm all done.
    Aug 24 2014
    Newport Beach, CA
    Quote Originally Posted by vavJETTAw36 View Post
    Home brew
    But how are you going to know the date and time now?
    2024 M3 Comp xDrive
    Jul 04 2012
    Woodbridge, VA
    All time is WOT time :D
    Jul 01 2008
    Portland, OR
    I bought a matte black bezel from PODI, then unscrewed the bezel from my aqua mist gauge and turned it down some till it fit inside the podi bezel and epoxied them together.
    2001.5 S4 Imola
